    Suddenly extrusion buttons Extrude/Retract are grey!
    RepRapFirmware on other controllers
    1.4k
      jay_s_uk @deckingman
      @deckingman i thought M302 was system wide? https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m302-allow-cold-extrudes
      P1 = allow, P0 = not allow?
      • tecnoundefined
        tecno @deckingman
        @deckingman said in Suddenly extrusion buttons Extrude/Retract are grey!:
        @tecno said in Suddenly extrusion buttons Extrude/Retract are grey!:
        @jay_s_uk
        OK, done that. But still no M302 P1 = all gray buttons
        If you've changed the tool from T1 to T0, then you need to use M302 P0 not M302 P1.
        2022-08-18 12:57:49	M302
        Cold extrusion is forbidden (use M302 P1 to allow it), min. extrusion temperature 160.0C, min. retraction temperature 90.0C
        2022-08-18 12:57:39	M302 P0
          deckingman @jay_s_uk
          @jay_s_uk said in Suddenly extrusion buttons Extrude/Retract are grey!:
          Oh crap - you are right of course - more caffeine needed 🙂
          tecnoundefined 1 Reply Last reply Reply Quote 1
          • tecnoundefined
            tecno @deckingman
            I hope I have finally found the error, did run RRF Config Tool and copied the config.g and now it looks lite it is working. Do have to finetune motorparameters. I can not see any differences other than speeds.
            Will report my findings.
            So it looks like writing data on µSD card is somehow corrupted. Is it possible the write process is too fast and no CRC or whatever to verify is done?
            deckingmanundefined gloomyandyundefined 2 Replies Last reply Reply Quote 0
              deckingman @tecno
              ................ Is it possible the write process is too fast and no CRC or whatever to verify is done?
              In DWC - Settings - Machine Specific, there is a toggle entitled "Use CRC32 checksums for uploads" or some such. Make sure it's "On".
              tecnoundefined 1 Reply Last reply Reply Quote 0
              • tecnoundefined
                tecno @deckingman
                @deckingman
                Has always been ON
                • gloomyandyundefined
                  gloomyandy @tecno
                  What makes you think there is an SD card corruption? Do you have an example of a corrupt file?
                  What make and size of SD card are you using? Try inserting it in a Windows PC and checking it for errors.
                  • tecnoundefined
                    tecno @gloomyandy
                    @gloomyandy
                    Hi Andy,
                    Config.g was damaged obviously as it did work with a new copy written on card.
                    32G from Sandisk, no errors in Win.
                      gloomyandy
                      @tecno So do you have the damaged version of the file? If so please post it....
                      • tecnoundefined
                        tecno @gloomyandy
                        @gloomyandy
                        As requested
                        config.g
                        gloomyandyundefined 1 Reply Last reply Reply Quote 0
                          gloomyandy @tecno
                          @tecno It seems unlikely that your file has any sort of SD card read/write corruption. I would have expected to see large parts of the file missing, invalid characters, lines oddly truncated, but that file seems to be perfectly formatted and complete.
                          I did however notice that your tool definition line M563 does not have a D parameter, which means that the tool will have no extruder drive associated with it (and is probably what caused your problem). See: https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m563-define-or-remove-a-tool
                          "If there is no 'D' field the tool has no drives."
                          • tecnoundefined
                            tecno @gloomyandy
                            @gloomyandy
                            OK, You found a problem and that is the part Jay was helping with as regards fan issue.
                            Can very well be so that editing those lines D somehow disappeared with copy/paste.
                            Thanks for looking into this, as always appreciated.
                              Phaedrux Moderator @tecno
                              M563 P1 H1 F0
                              You don't have a motor assigned to the tool. You need a D value.
                              EDIT: I see Gloomyandy got you there first.
