    Suddenly extrusion buttons Extrude/Retract are grey!
    RepRapFirmware on other controllers
    1.4k
    • tecnoundefined
      tecno @jay_s_uk
      @jay_s_uk
      No, will do
      What lines in config needs to be changed for T0
        jay_s_uk @tecno
        @tecno said in Suddenly extrusion buttons Extrude/Retract are grey!:
        M563 P1 H1 F0 ; P1 = tool1 H1 = heater1 F1 = fan1
        G10 P1 X0 Y0 Z0 ; set tool 0 axis offsets
        G10 P1 R0 S0 ; set initial tool 0 active and standby temperatures to 0C
        T1 ; select first tool
        change those to these
        M563 P0 H1 F0                                  ; P1 = tool1 H1 = heater1 F1 = fan1
        G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
        G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
        T0
        tecnoundefined 1 Reply Last reply Reply Quote 0
        • tecnoundefined
          tecno @jay_s_uk
          @jay_s_uk
          OK, done that. But still no M302 P1 = all gray buttons
          tecnoundefined deckingmanundefined 2 Replies Last reply Reply Quote 0
          • tecnoundefined
            tecno @tecno
            Updated FW = still same error
              deckingman @tecno
              @jay_s_uk
              If you've changed the tool from T1 to T0, then you need to use M302 P0 not M302 P1.
              Edit. Ignore that crap. Next time I'll try and engage my brain before typing.....
              jay_s_ukundefined tecnoundefined 2 Replies Last reply Reply Quote 0
                jay_s_uk @deckingman
                @deckingman i thought M302 was system wide? https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m302-allow-cold-extrudes
                P1 = allow, P0 = not allow?
                • tecnoundefined
                  tecno @deckingman
                  @deckingman said in Suddenly extrusion buttons Extrude/Retract are grey!:
                  @jay_s_uk
                  2022-08-18 12:57:49	M302
                  Cold extrusion is forbidden (use M302 P1 to allow it), min. extrusion temperature 160.0C, min. retraction temperature 90.0C
                  2022-08-18 12:57:39	M302 P0
                    deckingman @jay_s_uk
                    @jay_s_uk said in Suddenly extrusion buttons Extrude/Retract are grey!:
                    Oh crap - you are right of course - more caffeine needed 🙂
                    tecnoundefined 1 Reply Last reply Reply Quote 1
                    • tecnoundefined
                      tecno @deckingman
                      I hope I have finally found the error, did run RRF Config Tool and copied the config.g and now it looks lite it is working. Do have to finetune motorparameters. I can not see any differences other than speeds.
                      Will report my findings.
                      So it looks like writing data on µSD card is somehow corrupted. Is it possible the write process is too fast and no CRC or whatever to verify is done?
                      deckingmanundefined gloomyandyundefined 2 Replies Last reply Reply Quote 0
                        deckingman @tecno
                        ................ Is it possible the write process is too fast and no CRC or whatever to verify is done?
                        In DWC - Settings - Machine Specific, there is a toggle entitled "Use CRC32 checksums for uploads" or some such. Make sure it's "On".
                        • tecnoundefined
                          tecno @deckingman
                          @deckingman
                          Has always been ON
                          • gloomyandyundefined
                            gloomyandy @tecno
                            What makes you think there is an SD card corruption? Do you have an example of a corrupt file?
                            What make and size of SD card are you using? Try inserting it in a Windows PC and checking it for errors.
                            • tecnoundefined
                              tecno @gloomyandy
                              @gloomyandy
                              Hi Andy,
                              Config.g was damaged obviously as it did work with a new copy written on card.
                              32G from Sandisk, no errors in Win.
                                gloomyandy
                                @tecno So do you have the damaged version of the file? If so please post it....
                                • tecnoundefined
                                  tecno @gloomyandy
                                  @gloomyandy
                                  As requested
                                  config.g
                                  gloomyandyundefined 1 Reply Last reply Reply Quote 0
                                    gloomyandy @tecno
                                    @tecno It seems unlikely that your file has any sort of SD card read/write corruption. I would have expected to see large parts of the file missing, invalid characters, lines oddly truncated, but that file seems to be perfectly formatted and complete.
                                    I did however notice that your tool definition line M563 does not have a D parameter, which means that the tool will have no extruder drive associated with it (and is probably what caused your problem). See: https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m563-define-or-remove-a-tool
                                    "If there is no 'D' field the tool has no drives."
                                    • tecnoundefined
                                      tecno @gloomyandy
                                      @gloomyandy
                                      OK, You found a problem and that is the part Jay was helping with as regards fan issue.
                                      Can very well be so that editing those lines D somehow disappeared with copy/paste.
                                      Thanks for looking into this, as always appreciated.
                                        Phaedrux Moderator @tecno
                                        M563 P1 H1 F0
                                        You don't have a motor assigned to the tool. You need a D value.
                                        EDIT: I see Gloomyandy got you there first.
