    Issues with pressure advance since RRF 3.4
    308
    39.3k
    • Argoundefined
      Argo @CCS86
      @ccs86
      You can see here what happens when PA is far too high:
      • brunofportoundefined
        brunofporto
        I am having several issues with PA too.... The test using the python script have bulges AND under extrusion even on very high values of PA.
        Here an example for PLA from 0.5 to 0.9 - The bulge NEVER disappear even when the under extrusion after starts to show.
        In the past there always a clear transition where the slow segments had the same width and no under extrusion after.
        Also I simply cannot find a value of PA + Retract that lead to good results. It starts to to cause excessive retraction and blocking issues much before solving any oozing.
        I reviewed all my hardware looking for possible issues and after finding this thread I think it is related.
        It is very severe with small details and curved surfaces (like round small posts for retraction tuning) it is so severe that sometimes and entire layer is mission while others spurts excessive material. For straight lines - like a small cube walls - only the bulge is apparent and the under extrusion after the bulge for higher PA.
        I had not updated my board for a long time and the issues started after the update to 3.4 - I do not remember what older version I had before.
        But the issues are the same: Excess extrusion even with very high PA with under extrusion right after for higher PA. I had not of these issues before.
        I will test 3.4.2 now and then roll back to 3.3 and repeat the Python script test to compare.
        brunofportoundefined dc42undefined 2 Replies Last reply Reply Quote 2
          brunofporto @brunofporto
          @brunofporto
          Ok... No differences at all from the same gcode from PA 0.5 to 1.3 with 3.3 and 3.4.2 😄
          Phaedruxundefined gloomyandyundefined 2 Replies Last reply Reply Quote 0
            Phaedrux Moderator @brunofporto
            @brunofporto How bout 3.2?
            brunofportoundefined 1 Reply Last reply Reply Quote 0
            • gloomyandyundefined
              gloomyandy @brunofporto
              @brunofporto Are you using a toolboard, or other can-fd board to control the extruder?
                brunofporto @Phaedrux
                @phaedrux I'll try!
                  brunofporto @gloomyandy
                  @gloomyandy Nope. Duet 2 Ethernet v1.02 (the one before the on board fuses).
                    dc42 administrators @brunofporto
                    @brunofporto said in Issues with pressure advance since RRF 3.4:
                    I'm looking forward to seeing your comparative results for RRF 3.3 and 3.4.2.
                    How long is the Bowden tube between the extruder drive and the hot end?
                    Argoundefined 1 Reply Last reply Reply Quote 0
                    • Argoundefined
                      Argo @dc42
                      Small update for RRF 3.4.2. (stable) release.
                      PA was set to 0.052, printing PLA.
                      LDO Orbiter 2 extruder
                      Input shaper ZVDD used (M593 P"zvdd" F40.5 S0.03)
                      New test object (from a duet_rrf Voron channel user) to demonstrate the created overhang by the bulging corner which you can see when you flip it over:
                      gloomyandyundefined 1 Reply Last reply Reply Quote 0
                        gloomyandy @Argo
                        @argo I'm not totally sure what it is we are looking at here. Can you post a picture that shows the full object partially from the side (rather than directly above) so we can get a better idea about the test print you have used?
                        • Argoundefined
                          Argo @gloomyandy
                          @gloomyandy
                          Here's the object from another perspective. Imo it's a rather good test to see the actual material that overshoots when flipping the object. In my last post, when viewing the second picture in full screen you can see overshooting edge.
                          Second picture from last posting but cropped so you can see what I mean:
                          Unfortunately the bulging makes the printer unusable for me atm because I can only print round objects. For now the printer stays at RRF so I can share test prints when a new FW version gets released but I plan to move to Klipper in the near future (when I find the free time) if the issue remains.
                          Also the stl:
                          bulgecheck.stl
                            dc42 administrators @Argo
                            @argo most slicers have a parameter to set the degree of overlap between infill and perimeters. What slicer are you using, and what overlap parameter?
                            Argoundefined 1 Reply Last reply Reply Quote 1
                            • Argoundefined
                              Argo @dc42
                              I tried following slicers: Prusa Slicer, Super Slicer, Ideamaker and tried infill/perimeter overlap between 10% and 25%.
                              • ArminPundefined
                                ArminP
                                Think i have the same problem with corners.
                                My System :
                                Hardware:
                                • Duet 3 6HC
                                • Duet 3 Tool Board 1LC
                                • Orbiter 2 Extruder
                                Firmware 3.4.3
                                SuperSlicer:
                                PA 0.2 on PETG
                                • Argoundefined
                                  Argo
                                  @ArminP
                                  Tbh I'm not expecting a fix anymore. Too few are having issues and I understand that a problem that can't be reproduced is not fixable...
                                  R4ffersundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                                  • R4ffersundefined
                                    R4ffers @Argo
                                    @argo I have it too
                                    Mb6hc + 3hc + 1lc on Voron V2.4, Mini 5+ exp 2+ on Vzbot 235 AWD, Duet 2 wifi on Ox CNC and Mini 5+ on Millennium Milo v1.5 mini mill.
                                    • ArminPundefined
                                      ArminP
                                      I think i found my problem
                                      I used the wrong parameter.
                                      SET_PRESSURE_ADVANCE ADVANCE=0.2
                                      M572 D0 S0.13
                                      • Argoundefined
                                        Argo @ArminP
                                        @arminp
                                        Iā€˜m glad you fixed your problem.
                                          Phaedrux Moderator @Argo
                                          @argo said in Issues with pressure advance since RRF 3.4:
                                          @ArminP
                                          It's true that it's not easy solving a problem that can't be reproduced, but we have not given up either.
                                          Argoundefined 1 Reply Last reply Reply Quote 2
                                          • Argoundefined
                                            Argo @Phaedrux
                                            @phaedrux
                                            What would be different in your environment to mine? I mean what if a Duet test machine does show the problem. Is there a debugging firmware involved that does provide more data?
