    Are these parts suitable for this 3D printer design?
    35
    1.9k
    • mahmoudzundefined
      mahmoudz @mrehorstdmd
      @mrehorstdmd
      Despite these many problems, I was convinced to change the architecture of the device to the Hypercube model.
      The point is, if I use anti backlash for Z lead screws , will we be sure that the device will not fall after the power cut? This issue of continuing to print after a power cut is very important to me.
      i see some 3030cm hypercube on "thingiverse" that the manufacturer had used 2 nema 17 to move bed in the Z direction. if i change the bed to 5050cm still can use 2 nema 17 to lift the z axis?
      This is the 30*30cm printer that caught my attention. Do you think I can convert this device to 50x50cm without changing Nima 17 motors, power, board, etc.
      https://www.thingiverse.com/thing:2254103
      And this is the first time I see the printer datasheet.
      In the table on the right side of the picture below, where it says 60x60, does it mean that it is easy to make this device with these specifications up to 60x60 dimensions without changing the parts?
      Or for 60x60, electronic or mechanical parts must be changed
      and this is the datasheet of it:
      And another question that I did not find the answer to is this. How should we know which engine to choose for the bad size we want?
      Sometimes it is light and sometimes it is heavy.
      Do you know the mathematical calculation of this case, how to find out which engine is suitable for our designed printer?
      Thanks alot ๐Ÿ™‚
      deckingmanundefined mrehorstdmdundefined 2 Replies Last reply Reply Quote 0
        deckingman @mahmoudz
        @mahmoudz Anti backlash nuts have nothing to do with whether the bed will drop on power loss. As I said in your other thread, gravity will ensure that the same flanks of the thread are always in contact, regardless off the direction of rotation so your Z axis will not suffer from backlash (assuming you use lead screws without and additional gearing. Also, as I've explained before, auto-rotation on power loss can happen if the lead of the screws is too big, giving a steep helix angle. You've already said that you intend to use 1mm lead screws (although the optimum is 2mm as I explained in the video link I sent you), so the bed will not drop on power loss.
        As for sizing motors and the necessary calculations, I've already sent you links to the appropriate part of the documentation and I've even uploaded the spreadsheet that you'll need to my google drive, for which I gave you gave access link.
        mahmoudzundefined 1 Reply Last reply Reply Quote 0
        • mrehorstdmdundefined
          mrehorstdmd @mahmoudz
          @mahmoudz There is a lead screw torque/force calculator here: https://www.daycounter.com/Calculators/Lead-Screw-Force-Torque-Calculator.phtml
          Anti backlash nuts on the Z axis screws might keep the bed from dropping when power is cut, but it really hard to predict. It will depend on the mass of the bed, the pitch of the screws, the number of screws, and the friction of the anti backlash nuts. You also need to account for the mass of a large print on the bed, since you're building a big printer.
          It looks like the plan you linked is based on 20 and 30 mm t-slot. That seems a little small for size the printer you want to build. Everything flexes. Small cross section things flex more than large cross section things. Again, it is hard to predict, so better to overbuild than underbuild.
          The large bed plate will need a large heater. This calculator will help you calculate the power required to get the bed up to the desired print temperature in a reasonable amount of time: https://jscalc.io/calc/uS8JYjYISgIvzJ1x
          I can't recommend the Arduino/RAMPS controller for any printer. Any board that uses tiny motor driver modules is going to be unreliable, as many of us found out years ago. Those motor driver modules can't dissipate enough heat, among their other problems.
          No one can design this machine for you. You're going to have to invest some time and money in trying things until you find what works for you. Be prepared to make mistakes and changes as you go along. You'd really be better off starting with a small printer, that will teach you about the problems involved. It might save you a lot of money in the long run.
          • percarundefined
            percar
            I have built a 60cm x 30cm printer about 8 yrs ago and have gone through all the trials and errors in order for it to be successful.
            I started with a large cast aluminum build plate.(cast aluminum is known for dimensional stability and is used in precision fixturing.) While heating this plate it would deform and i had a huge problem keeping it level. The next phase was to use borosilicate glass. This solved the problem of deformation during heating and the plate stayed level. I use 2 lead screws for the Z axis and i do a bed level before every print. Keep the x y as light as possible as this is where the effects of weight will slow down the printing. I use a direct drive extruder and my print speed is restricted to around 60mm second. Travel speed is around 90mm sec. Although it is not a speed demon it works for me. I have explored the use of closed loop steppers and have found out that i can increase the speed slightly but in the long run it is not work the complexity at this time. I have performed prints that have duration of mor than 4 days printing time without issues.
            deckingmanundefined mahmoudzundefined 2 Replies Last reply Reply Quote 0
              deckingman @percar
              @percar said in Are these parts suitable for this 3D printer design?:
              .............Keep the x y as light as possible as this is where the effects of weight will slow down the printing. I use a direct drive extruder and my print speed is restricted to around 60mm second. Travel speed is around 90mm sec.....................
              If you are only printing at 60mm sec with 90mm/sec, why do you think that keeping X and Y as light as possible will affect the attainable speed?
              I know the theory behind it that force = mass x acceleration so the lower the mass, the higher the acceleration that can be achieved for a given force (motor torque). But with FDM printing, the speed is limited by how fast the filament can be melted and extruded - the moving mass is not the limiting factor in this case. My own printer is a case in point. My 6 input hot end is heavy so it needs two parallel X rails which adds even more weight. The moving mass in the Y direction is about 2Kgs, yet I have demonstrated printing at 300mm/sec using all 6 inputs to achieve extremely high melt rates and with 1000mm/sec^2 acceleration. My default travel speed is always 350mm/sec - that's with 2Kgs of moving mass. So the concept that reducing mass will allow one to achieve higher print speed is a common misconception (i.e. why reduce mass if the mass itself is already below what would be a limiting factor?).
              • mahmoudzundefined
                mahmoudz @deckingman
                @deckingman
                Hi sir. thank you. Yes, I downloaded it. Thank you very much again for your advice.
                • mahmoudzundefined
                  @mrehorstdmd
                  Hello. Thank you very much for the tips and links you sent me. Yes, you are right that it is better to start with smaller sizes and after I have mastered it, proceed to make bigger printers.
                  • mahmoudzundefined
                    mahmoudz @percar
                    @percar
                    • mahmoudzundefined
                      @deckingman
                      Hi sir. thank you.
                      I think I have to read all the messages again. Since English is not my native language, I am translating my questions and answers with the help of Google. And because in some places Google does not do this translation well, I may not understand some sentences well.
                      • mahmoudzundefined
                        @deckingman
                        hello. sir i have a few more questions.
                        if we use BLTouch and connect it to Zmin, There is no need to use mechanical endstops for the zmin axix?
                        And usually 3 end-stops ( 2 mechanical for x and y and one bltouch for z min) are enough for xycore pritners?
                        I saw a video on YouTube saying that "Power less Recovery feature" in Marlin program may not work well for xycore printers. Thanks to your advice, I realized that if I use a 2 mm lead screw, the bed will not fall. The point is that if the bed does not fall, it is easy to use the power less recovery function in the Marlin program without any problem?
                        thanks.
                          @mahmoudz Yes to all of that.
                          • mahmoudzundefined
                            @deckingman
                            Thanks alot sir.
                            You have taught me many things during this time.
                            Thank you very much..
                            • mahmoudzundefined
                              @deckingman
                              Hi sir. I saw on the internet that some people use a system called V-slot wheels instead of using rails and wagons in 3D printers.
                              Is it worth using this system in the axes of the 3D printer, or will the wheels break down and wear out very quickly? Can you please guide me regarding the friction and life of these wheels and if these wheels are good, which model should I get? (because I realized that these wheels have different materials)
                              Thanks alot ๐Ÿ™‚๐ŸŒธ ๐ŸŒธ ๐ŸŒธ ๐ŸŒธ ๐ŸŒธ ๐ŸŒธ
                              zaptaundefined deckingmanundefined 2 Replies Last reply Reply Quote 0
                              • zaptaundefined
                                zapta @mahmoudz
                                Anybody using successfully resume after power cut?
                                Never tried it and am not sure how that work, considering the model cooling/heating cycle, and the lack of rehoming.
                                I wonder if a UPS would be a more effective solution, to avoid the power cut in the first place, even if just to the steppers if not to the heaters.
                                  @mahmoudz said in Are these parts suitable for this 3D printer design?:
                                  @deckingman
                                  I built my printer entirely from Open Builds V-slot rails and wheels about 6years ago. Since then, it has run for thousands of hours without any problems related to the wheels and guides. I use a heavy mulit-input hot ends so have a moving mass in the Y direction of up to 3Kgs which is very high by most peoples standards, and my default travel speed is 350mm/sec which is also high by many peoples standards. Here is a video of how it looked 3 years ago with a 5 input Diamond hot end. Much has changed since then but the basic rails and wheels remain the same. https://www.youtube.com/watch?v=IG3AGKDzdH4
                                  There are many more videos on my YouTube channel and writes ups in my blog - both of which are linked to in my signature below.
                                  As you'll see from the video, I made many of my own aluminium parts for things like motor mounts but you can buy kits from the likes of RatRig and others - e.g. https://ratrig.com/3d-printing-cnc/3d-printer-kits/all-3d-printer-kits/v-core3configurable.html
                                  My advice would be to use Open Builds solid or Delrin Wheels - not the Mini or Extreme versions. https://openbuildspartstore.com/wheels/
                                  Pay particular attention to how you assemble them - use the Open Builds guides. e.g. https://www.youtube.com/watch?v=pMtHy7sDNG4. Most problems that people have had is because they haven't assembled the wheels correctly. The most common mistake is setting the eccentric spacer too tight. The next most common problem is forgetting to fit the precision spacer between the two bearings or over-tightening the lock nut. Any of these mistakes will prevent the wheel from rotating freely causing excessive wear.
                                    deckingman @zapta
                                    @zapta said in Are these parts suitable for this 3D printer design?:
                                    I did exactly that (fit a UPS). In my case, I chose to use a 24V DC UPS mostly because it seemed a bit daft to convert from a DC battery to AC mains then have the power supply convert the AC mains back down to 24V DC. Doing it that way loses some run time capacity because the conversion process is not 100% efficient. I have two 12V batteries in series giving me 24V. They are only about 20Ahr IIRC, but they will run the printer for many hours. Having said that, the mains powered bed does not get power when running off the batteries. But it's a big 400mm x 400mm x 12mm aluminium plate with 12mm of semi-rigid insulation underneath, so it take a very long time to cool sufficiently for the part to become detached.
                                    Here is more detailed explanation that I wrote up on my blog which has a link to video showing it in action. https://somei3deas.wordpress.com/2019/10/22/fitting-a-dc-uninterruptible-power-supply-ups-and-separate-5v-supply/
                                    • mahmoudzundefined
                                      @deckingman
                                      Thank you very much. Thatโ€™s very kind.๐ŸŒผ ๐ŸŒผ ๐ŸŒผ ๐ŸŒผ ๐ŸŒผ ๐ŸŒผ
                                      • Dad003undefined
                                        Dad003 @mahmoudz
                                        @mahmoudz
                                        here a few time for you as some have say , ive designed and built my printer it used 8mm screw for the bed first , but the screww what bending under the weight of heated bed , replaced it by belt than had the problem of bed goign down on power off , i fixed that problem by changing a few pulley , i have 20>60-20>60-20 for reduction , even when power is off bed stay were it is , it doesnt drop . it is powered in my vace by 2 60mm nema 17,
                                        like many said , it is better to have a light head that move in the X-Y axis than having a heavy bed that move on y or X , bed should only go up or down . think about your design maybe a bit more . other things you should look into is to use 12mm belt for axis not 6mm , 6mm will act like spring in those dimension , my printer started with 6mm belt now it all 12mm and it fixed many of the issue i had with 6mm
                                        • mahmoudzundefined
                                          mahmoudz @Dad003
                                          @Dad003
                                          Thank you
                                          • mahmoudzundefined
                                            mahmoudz @mahmoudz
                                            @mahmoudz
                                            Hello Sir. How are you?
                                            Sir do you know what is "max feedrate" in marlin? how these โ€œmax federateโ€ numbers are calculated?
                                            I checked the Marlin examples folder and checked different models of printers and each of them included unique settings for โ€œ.And because of the uniqueness of these numbers in different printers, I guessed that this section must be very important because different printers use unique numbers.
                                            I did a lot of searching on a topic in Hypercube printers and I couldn't find the answer for how to calculate max feedrate. I even asked this question in Facebook groups and I still haven't found the answer. also, On Marlin's website, there is not much information about this issue.
                                            And forgive me for asking you so many questions during this time. I really search for topics first, and if the topic is unclear, I come and ask questions in forums and groups. thanks a lot for your help. ๐ŸŒธ ๐ŸŒธ ๐ŸŒธ ๐ŸŒธ ๐ŸŒธ ๐ŸŒธ ๐ŸŒธ
                                            Unfortunately, malin website does not explain how the numbers should be calculated. ๐Ÿ‘‡
                                            (And even the numbers in the Marlin firmware are not the same as the numbers in the Marlin manual.).
