    Trouble with M201 and M566 settings
    2.5k
    • Jeredundefined
      Jered
      Before I run this next test, you can see from the info above and my attached config, there is a discrepancy. Why?
      M201 reports 3000 when you can see in the config that it is set to 500.
      config.g
      • Jeredundefined
        Jered
        Ok, the second test is done. Which was to remove the M204 500 command. Below are the results.
        I don't understand what is going on. The Z and E have the correct accel. What happened to the x and y? Also, what is this max accel doing at 20,000! Do I need to add this to my config?
        I have also attached my config so you don't have to search for it.
        config.g
        Jeredundefined Norderundefined 2 Replies Last reply Reply Quote 0
        • Jeredundefined
          Jered @Jered
          @Jered
          The command was M204 P500 Just to be clear. I left the "P" out of the reply from above.
          • Norderundefined
            Norder @Jered
            @Jered
            I find the config.g OK now, couldn't find any errors there.
            Except...
            I would change the following command line, meaning...
            M557 X15:450 Y15:450 S50 ; define mesh grid
            An area of ​​435mm x 435mm is to be scanned there (450mm - 15mm = 435mm)
            On this 435mm there should be a measuring point every 50mm (S50), which means... 435 : 50 = 8.7
            However, 8.7 measuring points cannot be used because this always has to be a whole number, so a slightly wider edge is not used on the right and upper side of the print bed.
            Therefore you should change the command line as follows...
            M557 X15:450 Y15:450 P9 ; define mesh grid
            The parameter P9 allocates this 435mm exactly 9 measuring points and calculates the distance automatically.
            The complete area of ​​435mm x 435mm is scanned by the probe.
            If you always enter an odd number here, the center of the print bed will also be probed automatically.
            So P5, P7, P9...
            Google Translate
            -- Original Text --
            Ich finde die config.g jetzt OK, konnte da keine Fehler entdecken.
            Außer...
            Folgende Befehlszeile würde ich ändern, gemeint ist...
            Dort soll ein Bereich von 435mm x 435mm abgetastet werden (450mm - 15mm = 435mm)
            Auf diesen 435mm sollen alle 50mm ein Messpunkt sein, was bedeutet... 435 : 50 = 8,7
            Es können aber keine 8,7 Messpunkte da dieses immer eine ganze Zahl sein muss, daher wird an der rechten und oberen Seite des Druckbettes ein etwas breiterer Rand nicht genutzt.
            Daher solltest Du die Befehlszeile wie folgt ändern...
            Der Parameter P9 teilt diese 435mm genau 9 Messpunkte zu und berechnet den Abstand automatisch.
            So wird der komplette Bereich von 435mm x 435mm von der Sonde abgetastet.
            Wenn Du hier immer eine ungerade Zahl eingibst, wird automatisch die Mitte des Druckbettes mit sondiert.
            Also P5, P7, P9...
            DDA5X... 0.9° Stepper... Linearrails... Duet 2 Wifi... PT100 Board... Duet IR-Probe... Dyze Pro Kit up to 500°C.. etc
            Thingiverse
            • Jeredundefined
              Jered @Norder
              @Norder
              Thanks, I will make that change.
              • Norderundefined
                Norder @Norder
                @Norder
                Please post a few screenshots of your printer settings in the slicer.
                I think the solution is to be found there, why 3000 are reported although 500 are set.
                You are now also talking about the SuperSlicer here, previously there was only talk of Simplify3D.
                Are you now using Simplify3d and the SuperSlicer?
                Please write which slicer you use.
                And if you use both slicers, please also write whether both slicers have this error in their slice.
                Google Translate
                -- Original Text --
                Poste doch bitte ein paar Screenshots von Deinen Druckereinstellungen im Slicer.
                Ich glaube dort ist die Lösung zu finden warum 3000 gemeldet werden obwohl 500 eingestellt sind.
                Du sprichst hier jetzt auch vom SuperSlicer, vorher war nur von Simplify3D die Rede.
                Nutzt Du jetzt Simplify3d und den SuperSlicer ?
                Bitte schreibe welchen Slicer Du nutzt.
                Und wenn Du beide Slicer benutzt, dann schreib bitte auch ob beide Slicer diesen Fehler in ihrem Slice haben.
                Thingiverse
                Norderundefined 1 Reply Last reply Reply Quote 0
                • Norderundefined
                  Norder @Norder
                  Screenshots from Simplify3D, there could be a few.
                  In order not to make the comment too long, which could damage the overview, you are welcome to show the entire settings page in a video.
                  That only as a tip. 😉
                  Thingiverse
                  Jeredundefined 1 Reply Last reply Reply Quote 0
                  • Jeredundefined
                    Jered @Norder
                    @Norder
                    I will try to get to this. I am using Simplify.
                    gloomyandyundefined 1 Reply Last reply Reply Quote 0
                      You could share an example sliced gcode file so we can see what it is doing.
                      Also share or check your other files that get called when a print starts like homeall.g, start.g, etc. See if there are any stray commands in there.
                      • gloomyandyundefined
                        gloomyandy @Jered
                        @Jered Can I suggest that you do the following....
                        1. In the console run the following command: M98 p"config.g" if you get any errors reported these need to be fixed.
                        2. Reboot your printer
                        3. run M201 check the value of the X and Y accelerations
                        4. Home your printer
                        5. run M201 check the value of the X and Y accelerations
                        You basically need to go through all of the steps that you normally go through when starting a print, so if you level the bed using G32 then run that and check M201 again, if you create a mesh with G29 then run that and again check with M201 after is. Basically you are trying to identify any changes to the acceleration setting.
                        If things look correct at each of the above stages then you need to look closely at your generated gcode....
                        Jeredundefined 1 Reply Last reply Reply Quote 1
                        • Jeredundefined
                          Jered @gloomyandy
                          @gloomyandy
                          I didn't even think to check those files. You are right!
                          The accel was being changed in home x, y, and home all! I have changed them all to match the config and all is well!
                          Thanks so much for bringing this up. I am so use to the "out of the box" printers that I didn't even think to check those files.
                          Thanks To All Of You Guys!
                          It can't be easy dealing with us noobs 😉
                          engikeneerundefined 1 Reply Last reply Reply Quote 2
                          • Phaedruxundefined Phaedrux has marked this topic as solved
                          • engikeneerundefined
                            engikeneer @Jered
                            @Jered FYI, it might be worth creating a macro called 'motor_settings.g' which contains your default acceleration limits etc. You can then call that in config, and at the and of your homing files etc so you only have one place to change your machine limits. I do this on my printer.
                            Alternatively you could achieve something similar using global variables but I have not been adventurous enough to try them out yet!
                            i3 clone with a bunch of mods
