    G30 H?
    517
    • Falkiaundefined
      Falkia @tecno
      @tecno Just tested my new delta setup. Changed to linear bearings and 80mm rod spacing and a 80mm adapter for the smart effector. Adjusted the sensitivity of the smart effector so there is a distinct click sound every time the nozzle hits the bed when probing. Not sure about the H parameter but I have H0 on all G30. I think my delta is about the size you have. Points 249, Radius 225. The bed is cast and milled 8mm aluminum.
      God kväll / Fredrik
      Printer: "Deltacus" Delta with 510mm bed diameter and 925mm build height. Powered by Duet 2 WiFi. Duet Smart Effector with E3D Volcano.
      tecnoundefined 1 Reply Last reply Reply Quote 1
      • tecnoundefined
        tecno @Falkia
        @Falkia
        God morgon Fredrik,
        That is what I expected that you have, have those distinct clicks so I think I have my setting close.
        My bed is hardened glass cheap table top Ø600mm and it is not perfectly flat. I had my hopes that this would be taken care of with the levelling data collected.
        Cheers
        Bengt
        • o_lampeundefined
          o_lampe @tecno
          @tecno
          The H parameter is meant to compensate effector tilt. But in your case it looks, like it's an irregular error.
          Do you have a loose rod or too much play somewhere?
          How old is the smart effector? I've read, they change their behaviour over the years.
          tecnoundefined 1 Reply Last reply Reply Quote 0
          • tecnoundefined
            tecno @o_lampe
            @o_lampe
            The SmartEffector is new.
            I do not think I have any loose rod as I have rod pairs axially tensioned with springs.
            But the carbon fibre rods might be flexy with a Ø8mm 600mm long.
              Do you get reliable trigger height in a single position?
              • tecnoundefined
                tecno @Phaedrux
                @Phaedrux
                Yes it looks like it
                • tecnoundefined
                  tecno @tecno
                  When you run G29 on your Deltas does the Z-probe on display always flash red 1000?
                  Been playing around and I can hear every nozzle contact against the glass but not every time I get RED1000
                  o_lampeundefined dc42undefined 2 Replies Last reply Reply Quote 0
                  • o_lampeundefined
                    o_lampe @tecno
                    @tecno
                    DWC not always shows the right z-probe status. It depends on the refresh rate.
                    But there should be an indicator LED on the SmartEffector, IIRC.
                    • tecnoundefined
                      tecno @o_lampe
                      @o_lampe
                      Yes the indicator on SmartEffector lights up, so then it should be OK.
                        dc42 administrators @tecno
                        @tecno said in G30 H?:
                        The Smart Effector sends a pulse a few hundred milliseconds long when it triggers. DWC only reads the status a few times per second, so it doesn't always register it. What matters it that the green LED on the effector flashes when it makes contact, and doesn't flash when the effector is not moving.
                        The readings look very irregular. My guess is that there is a lot of noise in the system, which is causing random variation in the trigger height. Here are some things to check:
                        • Make sure you are using the M558 parameters recommended at https://docs.duet3d.com/en/Duet3D_hardware/Accessories/Smart_Effector.
                        • If you are probing with the bed heater on, try using the M558 B1 parameter to temporarily turn it off during probing. A few types of bed heater produce enough magnetic field to affect Z probes.
                        • Make sure the print cooling fan is off during probing.
                        • If all else fails, try probing with the hot end cold (heater and hot end fan both off) in case the hot end fan is causing the noise.
                        • o_lampeundefined
                          o_lampe
                          Just wondering if there's any conclusion what caused the "Himalayan" landscape?
                          • tecnoundefined
                            tecno @o_lampe
                            @o_lamp
                            I suspect mechanical issues, will add some supports this week.
                            The 3 stands are only bolted to PETG corners.
                            • tecnoundefined
                              tecno @tecno
                              Testing these to see if it gets better (what is the common name?) Vantskruv in Swedish.
