Duet mini 5+ freezes and shuts off heaters
@michael-hathaway
Mostly a joke there (board freezingβ¦ leaving it out in the coldβ¦).I can understand why folks would want to keep the boards in heated chambers.
FYI, bringing in a line of compressed air at ~10 psi is helpful to provide local cooling without impacting the overall chamber too much.
@tlas I joked with a friend this morning when I told him I was going to water cool my MCU.
@michael-hathaway Unfortunately, I don't think it's just the MCU, and this issue isn't just limited to the Mini 5+. Other components aren't rated higher than 85C, and running at high temperatures will shorten the life of all the components. We don't give recommended operating temperature limits (though we are talking about it), because the board heating itself up due to FETs/stepper drivers/power supplies on the board is very application specific.
With the 6HC, the higher rating on the stepper drivers mean they run cooler, so don't add as much self-heating to the board, so perhaps that's what you mean when you say they are more robust.
We really don't advise running Duets in heated chambers; it will shorten their life.
@droftarts Yes, this is what I said in my previous statement to you. It is all the components on the board.
The chamber is heated by the bed and hotend. The reason why it prints petg and not the high temp nylon is because the chamber temp rises much higher with the higher temp plastics. Especially on very hot days. I realize now that I cannot print my higher temp plastics until I bring cold air in to cool the electronics.
A small update: The issue has nothing to do with heat of the chamber or the Duet 3 mini. After a ton of testing, I have narrowed the issue down around the extruder.
Exhausting all other tests, I decided to run a print cycle with no filament running through the extruder and it finished the print. I am able to print at high temperature with flexible Nylon, but the stiff carbon fiber nylon throws a reset.
I installed a new stepper and Bontech extruder. I will post results later.
10/25/2022, 1:15:28 AM m122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.4.1 (2022-06-01 21:06:56) running on Duet 3 Mini5plus Ethernet (standalone mode) Board ID: 6MFQS-V096U-D65J0-40KMJ-JS03Z-R72JU Used output buffers: 1 of 40 (22 max) === RTOS === Static ram: 103684 Dynamic ram: 105204 of which 0 recycled Never used RAM 32752, free system stack 168 words Tasks: NETWORK(ready,25.9%,260) ETHERNET(notifyWait,0.3%,568) HEAT(notifyWait,0.0%,358) Move(notifyWait,0.0%,290) CanReceiv(notifyWait,0.0%,942) CanSender(notifyWait,0.0%,372) CanClock(delaying,0.0%,339) TMC(notifyWait,0.7%,81) MAIN(running,72.1%,422) IDLE(ready,0.2%,29) AIN(delaying,0.8%,264), total 100.0% Owned mutexes: === Platform === Last software reset at 2022-10-25 00:59, reason: User, GCodes spinning, available RAM 32752, slot 0 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00489000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x00 MCU revision 3, ADC conversions started 101415, completed 101415, timed out 0, errs 0 Step timer max interval 1486 MCU temperature: min 41.6, current 42.2, max 43.3 Supply voltage: min 23.8, current 23.9, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0 Events: 0 queued, 0 completed Driver 0: standstill, SG min 0, read errors 0, write errors 0, ifcnt 9, reads 5301, writes 9, timeouts 0, DMA errors 0, CC errors 0 Driver 1: standstill, SG min 0, read errors 0, write errors 0, ifcnt 9, reads 5301, writes 9, timeouts 0, DMA errors 0, CC errors 0 Driver 2: standstill, SG min 0, read errors 0, write errors 0, ifcnt 12, reads 5298, writes 12, timeouts 0, DMA errors 0, CC errors 0 Driver 3: standstill, SG min 0, read errors 0, write errors 0, ifcnt 9, reads 5301, writes 9, timeouts 0, DMA errors 0, CC errors 0 Driver 4: standstill, SG min 0, read errors 0, write errors 0, ifcnt 9, reads 5301, writes 9, timeouts 0, DMA errors 0, CC errors 0 Driver 5: not present Driver 6: not present Date/time: 2022-10-25 01:15:24 Cache data hit count 172505060 Slowest loop: 12.16ms; fastest: 0.13ms === Storage === Free file entries: 9 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 1.0ms, write time 9.1ms, max retries 0 === Move === DMs created 83, segments created 3, maxWait 42811ms, bed compensation in use: mesh, comp offset 0.000 === MainDDARing === Scheduled moves 2, completed 2, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 2], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 0 is on, I-accum = 0.6 Heater 1 is on, I-accum = 0.5 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty === Filament sensors === Extruder 0 sensor: ok === CAN === Messages queued 909, received 0, lost 0, boc 0 Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 18 (min 18), ts 506/0/0 Tx timeouts 0,0,505,0,0,402 last cancelled message type 30 dest 127 === Network === Slowest loop: 9.29ms; fastest: 0.03ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions HTTP sessions: 1 of 8 - Ethernet - State: active Error counts: 0 0 0 0 0 Socket states: 2 2 2 2 2 0 0 0
@nikscha
24 Oct 2022, 14:30
Printer runs perfectly without errors with no filament loaded. Petg, non-composite nylon, everything works. Yes my nozzle is grounded to the frame and Earth ground.I now have a Nema 17 x 48mm stepper on a Bontech extruder, pulling from 2.5Kg spool and pushing through 500mm of bowden tube.
Maybe there is too much friction with carbonfiber nylon?
Currently printing test cube with M92 E1.
@Michael-Hathaway said in Duet mini 5+ freezes and shuts off heaters:
If it works OK without filament, it does sound as though it is ESD. Have you checked with a multimeter that there is continuity between the hot end metalwork and Duet ground? Also check that the extruder motor body is connected to the same ground, in case it is the extruder motor building up ESD and flashing over to the phase connections.
Hello and thank you. Where on the Duet mini would be the appropriate place to place an earth ground?
@dc42 Is it safe use the 24v power supply ground on the board?
"At the power supply, you can also connect the DC - terminal to the earth terminal, that way any shorts on the low voltage side to the high voltage side will be shunted to ground as well. If you do this you need to be a bit more careful about ground loops when connecting via USB."
I made some progress.
Everything grounded, and verified. Still failed to print.
And then I purposely added load to the extruder and reproduced the failure. I didn't know that excessive pull force on the extruder, pulling from a large 2Kg spool would trigger a reset.
Increased current to 1200 fail, 1400 fail, 1600 and it almost finished the print. However, 1600 is beyond the capability of the mini 5, so I will have to find another solution to reduce pull resistance from the spool. Other materials work well, but not carbon fiber.
I will test some more and report back.
Larger internal diameter PTFE tube?
The surface texture of the carbon fiber materials is very rough. Lots of friction.
@Phaedrux Exactly.
So because this is Nylon CF I print from a sealed filament box, a big one that can handle up to 8Kg spools, my filament has to pass through bowden tubing before it reaches the print enclosure. I have obtained 6mm OD/ 4mm ID ptfe tubing with PC6 fittings.Also, normally my spools roll on rollers, which is fine because my rollers are 75mm in diameter. Larger rollers are a lower roller-to-spool ratio and less friction. But with this material, the system had too much resistance. So I built a center shaft mount in the enclosure for the larger spools, while still being able to use the convenience of the rollers for my other spools.
I am finally able to finish a print without failure. I lowered my motor current down to 1200ma. I know it sounds rediculous, but I am considering mounting one of my 60mm steppers to the bondtech extruder so that I can have increased torque with lower current draw from the drivers. I am not sure if this will work due to the 60mm stepper being 4 volts and higher impedance. However, I am not looking for speed out of the extruder stepper, just torque.
I thought I had this under control. The new ptfe larger tube made the pull resistance drop to nearly nothing. Still getting failures mid print. I even attempted to print with all of the enclosure doors open. Enclosure temperature 30C.
But it still succeeds with no filament loaded?
@Phaedrux I am not sure, let me try it again.
@Phaedrux Print finished, no errors. So... Too much resistance from the extruder to the hotend.
I ordered some Capricorn tubing, I don't have any in stock. And I had a good laugh while I was bolting on a 60mm super whomper to my extruder. I guess I should order input gear shafts. I am going to replace a few other things while I have the printer apart.
