    Orbiter 2 extruder mounting for Smart effector with Magball arms
    Smart effector for delta printers
    12
    56
    5.6k
    • Adrian52undefined
      Adrian52 @dc42
      @dc42 I should have done my homework. According to the reprap wiki here , stability decreases linearly with ball gap, but increases with the square of arm gap. So compared to the standard geometry, keeping the arm gap decreases stability almost threefold, whilst the 12mm ball gap with wider arms more than doubles stability. I think I was so impressed with the improvement of direct drive over the bowden that I didn't consider the effect of geometry on stability.
      • vapvapundefined
        vapvap @Adrian52
        @adrian52 As always, great idea!
        And as usual - we are waiting for the addition to "thingiverse".
        Adrian52undefined 1 Reply Last reply Reply Quote 0
        • Adrian52undefined
          Adrian52 @vapvap
          @vapvap Thanks. Posted it now
          https://www.thingiverse.com/thing:5463328
          vapvapundefined 1 Reply Last reply Reply Quote 1
          • vapvapundefined
            vapvap @Adrian52
            @adrian52 Thank you so much for sharing your ideas with us.
            Do you do any additional fine-tuning in the firmware?
            • vapvapundefined
              vapvap
              Can anyone explain how to set this up?
              With "Delta Calibration (G32)", the nozzle began to scratch on the center of the table ...
              weed2allundefined 1 Reply Last reply Reply Quote 0
              • weed2allundefined
                weed2all @vapvap
                @vapvap have you run thru
                https://docs.duet3d.com/en/User_manual/Tuning/Delta_calibration
                https://www.thingiverse.com/weed2all/designs
                • weed2allundefined
                  weed2all @Fred-Y
                  my LGX lite direct drive mount for smart effector for my 3 kossel printers
                  photo_2022-10-18_15-02-52.jpg photo_2022-10-18_15-02-49.jpg photo_2022-10-18_15-02-45.jpg photo_2022-10-18_15-02-39.jpg photo_2022-10-18_15-02-30.jpg
                  PCRundefined 1 Reply Last reply Reply Quote 2
                  • Falkiaundefined
                    Falkia @Fred-Y
                    @Fred-Y I have been thinking of that solution for my Orbiter 2.0. With my 80mm rod spacing adapter the Orbiter can be mounted horizontally.
                    Printer: "Deltacus" Delta with 510mm bed diameter and 925mm build height. Powered by Duet 2 WiFi. Duet Smart Effector with E3D Volcano.
                    Falkiaundefined 1 Reply Last reply Reply Quote 1
                    • Falkiaundefined
                      Falkia @Falkia
                      Made some mounts for the Orbiter 2.0. Works great with my 80mm smart effector adapter. Weight is 12 grams.
                      • PCRundefined
                        PCR @weed2all
                        @weed2all possible to get the stl ?
                        • weed2allundefined
                          weed2all @PCR
                          @PCR yes...of course...I uploaded them to my thingiverse, just click on the signature and you go directly to my thingiverse page!
