Possible corrupt sd card, G29 Network Error
1.3k
    Dizzwold @jay_s_uk
    @jay_s_uk
    The sd card that came with the 6HC does exactly the same. I've not touched this card until ow, so that should be Fat 32???
    Original sd card;
    RepRapFirmware for Duet 3 MB6HC version 3.4.4
    Warning: Cannot initialise SD card 0: Card is unusable
    Ethernet is disabled.
    RepRapFirmware for Duet 3 MB6HC is up and running.
    M552
    Ethernet is disabled, configured IP address: 0.0.0.0, actual IP address: 0.0.0.0
    ok
    M552 S1 P192.168.1.70
    ok
    MEthernet running, IP address = 192.168.1.70
    552
    Ethernet is enabled, configured IP address: 192.168.1.70, actual IP address: 192.168.1.70
    ok
    M552
    ok
    M39
    Error: M39: No SD card mounted in slot 0
    ok
    undefined 1 Reply Last reply 27 Oct 2022, 08:45 Reply Quote 0
      jay_s_uk @Dizzwold
      @Dizzwold in which case looks like a warranty might in order
      when and where did you purchase the duet?
      hopefully @Phaedrux or maybe @droftarts will authorise
      undefined 1 Reply Last reply 27 Oct 2022, 08:58 Reply Quote 0
        Dizzwold @jay_s_uk
        @jay_s_uk
        Originally purchased 29/1/21
        Replaced 11/2/21 as the original had a broken connector retainer.
        I was going to install the board then, but then I had to move house, so nothing has been done until September, except for opening and checking to makes sure there were no broken connectors etc.
        Just waiting for the new sd card to be formatted with the link you sent, doing an overwrite....
        undefined 1 Reply Last reply 27 Oct 2022, 08:59 Reply Quote 0
          jay_s_uk @Dizzwold
          @Dizzwold see what the duet guys say then. in the mean time can you take a high res picture of the sd card socket and the pins that are soldered to the board?
          undefined 1 Reply Last reply 27 Oct 2022, 09:53 Reply Quote 0
            Dizzwold @jay_s_uk
            @jay_s_uk
            Okay, just formatted the sd card with a full overwrite, Popped it in the 6HC;
            undefined 1 Reply Last reply 27 Oct 2022, 09:54 Reply Quote 0
              jay_s_uk @Dizzwold
              @Dizzwold nothing more i can do now. There's obviously an issue with the SD card slot
              will leave it to the duet guys
              undefined 1 Reply Last reply 27 Oct 2022, 10:05 Reply Quote 0
                Dizzwold @jay_s_uk
                @jay_s_uk
                Seriously, a big Thank you for your help @jay_s_uk .
                I'm really grateful for your time and guidance.
                  Sorry to see you're still having some issues with that board. The SD slot appears to have failed. Perhaps a marginal solder joint. As you were using the SBC before, you wouldn't have noticed.
                  Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
                  I don't think this is related to your other issues when using the SBC, as the SD card slot on the duet is obviously unused in that setup, but perhaps there is something else weird going on with it. Regardless, this would give you a fresh start.
                  undefined 1 Reply Last reply 8 Nov 2022, 13:46 Reply Quote 1
                    Dizzwold @Phaedrux
                    @jay_s_uk @Phaedrux
                    Hi Guys,
                    Well a new 6HC arrived yesterday.
                    Got things started today "getting connected" etc. This time, I'm not going to bother with a RPi.
                    Now with a blank file system and updated firmware, can I just upload my original files from the DWC Upload System Files, should I upload all of these?
                    undefined 1 Reply Last reply 8 Nov 2022, 13:59 Reply Quote 0
                      jay_s_uk @Dizzwold
                      @Dizzwold I wouldn't bother with the config.json and the dwc-settings.json.
                      The rest you should be fine with
                      undefined 1 Reply Last reply 9 Nov 2022, 15:58 Reply Quote 0
                        Dizzwold @jay_s_uk
                        @jay_s_uk
                        Thank you.
                        I've also just noticed something in my config.g that I thick, with looking in the dictionary ,is causing conflict. In M950 shouldn't my bed heater be H0 (H zero), rather than T0 (T zero), and my nozzle be T0 (T zero) instead of T1?
                        ; Configuration file for Duet 3 MB 6HC (firmware version 3.3)
                        ; generated by RepRapFirmware Configuration Tool v3.3.13 on Mon Sep 19 2022 16:04:20 GMT+0100 (British Summer Time)
                        M575 P1 S1 B57600                                  ; enable support for PanelDue
                        G90                                                ; send absolute coordinates...
                        M83                                                ; ...but relative extruder moves
                        M550 P"Duet 3"                                     ; set printer name
                        M669 K1                                            ; select CoreXY mode
                        M552 P
                        ; Bed Leadscrew Positions
                        M671 X5:278 Y146:146 P2.0						; middle left, middle right
                        G4 S1												;wait for expansion boards to start
                        M569 P0.0 S0                                       ; physical drive 0.0 goes backwards
                        M569 P0.1 S0                                       ; physical drive 0.1 goes backwards
                        M569 P0.2 S1                                       ; physical drive 0.2 goes forwards
                        M569 P0.3 S1
                        M569 P121.0 S0                                       ; physical drive 0.3 goes forwards
                        M584 X0.0 Y0.1 Z0.2:0.3 E121.0                           ; set drive mapping
                        M350 X16 Y16 Z16 E16 I1                            ; configure microstepping with interpolation
                        M92 X80.00 Y80.00 Z400.00 E333.40                  ; set steps per mm
                        M566 X900.00 Y900.00 Z60.00 E120.00                ; set maximum instantaneous speed changes (mm/min)
                        M203 X6000.00 Y6000.00 Z180.00 E1200.00            ; set maximum speeds (mm/min)
                        M201 X500.00 Y500.00 Z20.00 E250.00                ; set accelerations (mm/s^2)
                        M906 X900 Y900 Z900 E800 I30                       ; set motor currents (mA) and motor idle factor in per cent
                        M84 S30                                            ; Set idle timeout
                        M208 X-2 Y-8 Z0 S1                                 ; set axis minima
                        M208 X330 Y330 Z400 S0                             ; set axis maxima
                        M574 X1 S1 P"!121.io1.in"                              ; configure switch-type (e.g. microswitch) endstop for low end on X via pin !io1.in
                        M574 Y1 S1 P"!io2.in"                              ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin !io2.in
                        M574 Z1 Z1 S2									   ; set endstops controlled be probe
                        M558 P8 C"^!121.io0.in" H5 F120 T6000                 ; set Z probe type to switch and the dive height + speeds
                        G31 P500 X-46 Y-19 Z2.45                            ; set Z probe trigger value, offset and trigger height
                        M557 X19:244 Y-2:304 P9                           ; define mesh grid
                        M308 S0 P"temp0" Y"thermistor" T100000 B4138       ; configure sensor 0 as thermistor on pin temp0
                        M950 H0 C"out0" T0                                 ; create bed heater output on out0 and map it to sensor 0
                        M307 H0 R0.187 K0.192:0.000 D1.89 E1.35 S1.00 B0   ; disable bang-bang mode for the bed heater and set PWM limit
                        M140 H0                                            ; map heated bed to heater 0
                        M143 H0 S120                                       ; set temperature limit for heater 0 to 120C
                        M308 S1 P"121.temp0" Y"thermistor" T100000 B4138       ; configure sensor 1 as thermistor on pin temp1
                        M950 H1 C"121.out0" T1                                 ; create nozzle heater output on out1 and map it to sensor 1
                        M307 H1 R2.498 K0.275:0.349 D6.79 E1.35 S1.00 B0 V24.0  ; disable bang-bang mode for heater  and set PWM limit
                        M143 H1 S280                                       ; set temperature limit for heater 1 to 280C
                        M950 F0 C"121.out1" Q500                               ; create fan 0 on pin out4 and set its frequency
                        M106 P0 C"Print Cooler" S0 H-1                     ; set fan 0 name and value. Thermostatic control is turned off
                        M950 F1 C"121.out2" Q500                               ; create fan 1 on pin out5 and set its frequency
                        M106 P1 C"Extruder Cooling" S1 H1 T45              ; set fan 1 name and value. Thermostatic control is turned on
                        M563 P0 S"Hemera" D0 H1 F0                         ; define tool 0
                        G10 P0 X0 Y0 Z0                                    ; set tool 0 axis offsets
                        G10 P0 R0 S0                                       ; set initial tool 0 active and standby temperatures to 0C
                        ; Emergency Stop
                        M950 J1 C"io4.in"
                        M851 P1 T0 S0 R0
                        T0
                        M501
                        So far so good with using the ethernet, and without fully commissioning I ran a G32 once with no problems, no running a second scan for unknown reasons and no network error.
                        Without further testing I can't say if this was linked to the previous board, found to have an sd card issue or not.
                        Sorry "I thick" , * I think.
                        undefined 1 Reply Last reply 9 Nov 2022, 16:12 Reply Quote 2
                          Phaedrux Moderator @Dizzwold
                          @Dizzwold said in Possible corrupt sd card, G29 Network Error:
                          No.
                          T When creating a heater: temperature sensor number, required (see M308). When creating a LED strip: LED type (optional): 0 = DotStar, 1 = RGB Neopixel (default), 2 = RGBW Neopixel. DotStar LEDs can normally be assigned only to an output intended for them.
                          https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m950-create-heater-fan-spindle-or-gpioservo-pin
