ExecOnMcode
Plugins for DWC and DSF
11
76
5.0k
    CrazyCreator @Falcounet
    @Falcounet
    Which version did you load, 32bit or 64bit?
    http://www.crazycreatorcube.com
    undefined 1 Reply Last reply 2 Dec 2022, 21:54 Reply Quote 0
      Falcounet @CrazyCreator
      @CrazyCreator 32bits comes to default so I took that one
      undefined 1 Reply Last reply 2 Dec 2022, 21:55 Reply Quote 0
        @Falcounet
        what you think, should i try 64bit? make it a difference for the plugin? i think not?
        undefined 1 Reply Last reply 2 Dec 2022, 22:00 Reply Quote 0
          @CrazyCreator I believe it will work the same but it is up to you. For the plugin itself, it won't make a difference.
          undefined 1 Reply Last reply 2 Dec 2022, 22:31 Reply Quote 0
            @Falcounet
            After your step 3 i have to make
            sudo apt upgrade?
            undefined 1 Reply Last reply 2 Dec 2022, 22:33 Reply Quote 0
              @CrazyCreator Actually I didn't added that but yes, upgrading system packages would be a good thing
                @Falcounet
                install is running now ... i have to wait
                undefined 1 Reply Last reply 2 Dec 2022, 22:57 Reply Quote 0
                  CrazyCreator @CrazyCreator
                  @Falcounet
                  Yeahhhh ... First Step is complete
                  Second Step 🙂
                  Now i need the synthax for sending this:
                  http://192.168.1.45/relay/0?turn=off and/or http://192.168.1.45/relay/0?turn=on
                  undefined 1 Reply Last reply 4 Dec 2022, 00:27 Reply Quote 0
                    @Falcounet
                    You have a hint for me?
                    undefined 1 Reply Last reply 4 Dec 2022, 00:28 Reply Quote 0
                      @CrazyCreator I think what you need is BtnCmd plugin but i'm not sure what you need exactly
                      undefined 1 Reply Last reply 4 Dec 2022, 00:31 Reply Quote 0
                        @Falcounet
                        I would like to send an http command to my network when the printer has finished printing.
                        The command I wrote here turns off the smart socket and thus the printer.
                        I think is anything with curl or so ...
                        @BtnCmd: What is this and what can is do for me?
                        undefined 1 Reply Last reply 5 Dec 2022, 10:11 Reply Quote 0
                          @CrazyCreator You can try adding a M1203 command doing curl http://192.168.1.45/relay/0?turn=off and then adding M1203 to your end-gcode.
                          undefined 1 Reply Last reply 5 Dec 2022, 21:51 Reply Quote 0
                            @Falcounet said in ExecOnMcode v0.1:
                            undefined 1 Reply Last reply 5 Dec 2022, 21:53 Reply Quote 0
                              @CrazyCreator The error comes from the relay you are trying to drive. I would suggest you to open a thread for your issue as it is not directly related to this plugin. Thanks
                              To add a bit more details, I think you have either to be identified or to allow an IP address from your network to send this command.
                              undefined 1 Reply Last reply 5 Dec 2022, 21:56 Reply Quote 0
                                @Falcounet
                                maybe the switch need a password or so ... but in the old execonmcode script the same switch worked, without errors. i will see, maybe everyone have a idea what i can try.
                                thanks
                                undefined 1 Reply Last reply 5 Dec 2022, 22:05 Reply Quote 0
                                  @CrazyCreator As said, open a thread and give a bit more informations about your setup (what kind of relay, etc ...)
                                  The 401 HTTP Error comes from this device so if it was working with the old execonmcode, I believe it is either because the config has changed, you were using another url or so.
                                  undefined 2 Replies Last reply 5 Dec 2022, 22:19 Reply Quote 0
                                    @Falcounet
                                    thanks for the hints ... i try tomorrow any thinks and then make a new thread.
                                    Or maybe BtnCmd can help me
                                    • undefined stuartofmt referenced this topic 11 Dec 2022, 16:55
                                      @Falcounet
                                      It works now 🙂
                                      Solution for others reading here:
                                      The shelly 1 switch had a password-protected web interface. So it didn't work.
                                      Without a password I now get a warning in ioBroker, but it works for now 😉
                                        Falcounet
                                        ExecOnMcode V0.2 is released.
                                        No plugin improvements has been added on that version.
                                        Only change is the module imports to use dsf-python v3.4.5
                                        See https://forum.duet3d.com/topic/30761/dsf-python-3-4-5-released for more details
                                        undefined undefined 2 Replies Last reply 16 Dec 2022, 20:30 Reply Quote 1
                                          @Falcounet
                                          Just installed the v0.2 over the v0.1 ... worked without any problems.
                                          Which is impractical, my created commands are gone now 😉
                                          undefined 1 Reply Last reply 16 Dec 2022, 21:09 Reply Quote 0
                                          43 out of 76
