    ExecOnMcode
    Plugins for DWC and DSF
    11
    76
    5.5k
    • CrazyCreatorundefined
      CrazyCreator @Falcounet
      @Falcounet
      After your step 3 i have to make
      sudo apt upgrade?
      http://www.crazycreatorcube.com
      Falcounetundefined 1 Reply Last reply Reply Quote 0
      • Falcounetundefined
        Falcounet @CrazyCreator
        @CrazyCreator Actually I didn't added that but yes, upgrading system packages would be a good thing
        CrazyCreatorundefined 1 Reply Last reply Reply Quote 0
          @Falcounet
          install is running now ... i have to wait
            CrazyCreator @CrazyCreator
            @Falcounet
            Yeahhhh ... First Step is complete
            Second Step 🙂
            Now i need the synthax for sending this:
            http://192.168.1.45/relay/0?turn=off and/or http://192.168.1.45/relay/0?turn=on
              @Falcounet
              You have a hint for me?
                @CrazyCreator I think what you need is BtnCmd plugin but i'm not sure what you need exactly
                  @Falcounet
                  I would like to send an http command to my network when the printer has finished printing.
                  The command I wrote here turns off the smart socket and thus the printer.
                  I think is anything with curl or so ...
                  @BtnCmd: What is this and what can is do for me?
                    @CrazyCreator You can try adding a M1203 command doing curl http://192.168.1.45/relay/0?turn=off and then adding M1203 to your end-gcode.
                      @Falcounet said in ExecOnMcode v0.1:
                        @CrazyCreator The error comes from the relay you are trying to drive. I would suggest you to open a thread for your issue as it is not directly related to this plugin. Thanks
                        To add a bit more details, I think you have either to be identified or to allow an IP address from your network to send this command.
                          @Falcounet
                          maybe the switch need a password or so ... but in the old execonmcode script the same switch worked, without errors. i will see, maybe everyone have a idea what i can try.
                          thanks
                            @CrazyCreator As said, open a thread and give a bit more informations about your setup (what kind of relay, etc ...)
                            The 401 HTTP Error comes from this device so if it was working with the old execonmcode, I believe it is either because the config has changed, you were using another url or so.
                            CrazyCreatorundefined 2 Replies Last reply Reply Quote 0
                              @Falcounet
                              thanks for the hints ... i try tomorrow any thinks and then make a new thread.
                              Or maybe BtnCmd can help me
                              • stuartofmtundefined stuartofmt referenced this topic
                                @Falcounet
                                It works now 🙂
                                Solution for others reading here:
                                The shelly 1 switch had a password-protected web interface. So it didn't work.
                                Without a password I now get a warning in ioBroker, but it works for now 😉
                                  Falcounet
                                  ExecOnMcode V0.2 is released.
                                  No plugin improvements has been added on that version.
                                  Only change is the module imports to use dsf-python v3.4.5
                                  See https://forum.duet3d.com/topic/30761/dsf-python-3-4-5-released for more details
                                  CrazyCreatorundefined Garth_42undefined 2 Replies Last reply Reply Quote 1
                                    @Falcounet
                                    Just installed the v0.2 over the v0.1 ... worked without any problems.
                                    Which is impractical, my created commands are gone now 😉
                                      @CrazyCreator I think there is something wrong with the plugin reloading after upgrade.
                                      I just tried and the config file is still there in sd/sys/ExecOnMcode/ExecOnMcode.json after plugin upgrade.
                                      The plugin was in "desactivated" mode. A stop and a start on the plugin fixed it.
                                        @Falcounet strange but right
                                          CrazyCreator
                                          @Falcounet
                                          I think you must make a little update in your plugin 😉
                                          • Garth_42undefined
                                            Garth_42 @Falcounet
                                            I am having trouble installing the newest version on my Duet3. I am getting the following error:
                                            dsf-python is installed on the RPI. Pip3 is recognized in the terminal when I enter "pip3".
                                            Here is an output of M122:
                                            M122
                                            RepRapFirmware for Duet 3 MB6HC version 3.4.5 (2022-11-30 19:35:23) running on Duet 3 MB6HC v1.01 (SBC mode)
                                            Board ID: 08DJM-956BA-NA3TJ-6JTDA-3S06M-9U8GS
                                            Used output buffers: 1 of 40 (13 max)
                                            Static ram: 152760
                                            Dynamic ram: 67548 of which 204 recycled
                                            Never used RAM 130160, free system stack 200 words
                                            Tasks: SBC(ready,0.5%,446) HEAT(notifyWait,0.0%,322) Move(notifyWait,0.0%,351) CanReceiv(notifyWait,0.0%,774) CanSender(notifyWait,0.0%,336) CanClock(delaying,0.0%,339) TMC(notifyWait,7.6%,91) MAIN(running,91.8%,923) IDLE(ready,0.0%,30), total 100.0%
                                            Owned mutexes: HTTP(MAIN)
                                            Last reset 01:16:51 ago, cause: software
                                            Last software reset at 2022-05-29 08:42, reason: User, GCodes spinning, available RAM 132740, slot 1
                                            Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
                                            Error status: 0x00
                                            Step timer max interval 134
                                            MCU temperature: min 25.1, current 27.1, max 27.2
                                            Supply voltage: min 24.0, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
                                            12V rail voltage: min 12.1, current 12.2, max 12.2, under voltage events: 0
                                            Events: 0 queued, 0 completed
                                            Driver 0: standstill, SG min 0, mspos 8, reads 15144, writes 15 timeouts 0
                                            Driver 1: standstill, SG min 0, mspos 8, reads 15145, writes 15 timeouts 0
                                            Driver 2: standstill, SG min 0, mspos 8, reads 15144, writes 16 timeouts 0
                                            Driver 3: standstill, SG min 0, mspos 8, reads 15145, writes 15 timeouts 0
                                            Driver 4: standstill, SG min 0, mspos 8, reads 15145, writes 15 timeouts 0
                                            Driver 5: standstill, SG min 0, mspos 8, reads 15145, writes 15 timeouts 0
                                            Date/time: 2022-12-28 21:41:46
                                            Slowest loop: 1.48ms; fastest: 0.04ms
                                            === Storage ===
                                            Free file entries: 10
                                            DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
                                            === MainDDARing ===
                                            === AuxDDARing ===
                                            Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
                                            Segments left: 0
                                            Movement lock held by null
                                            Telnet is idle in state(s) 0
                                            File is idle in state(s) 0
                                            USB is idle in state(s) 0
                                            Aux is idle in state(s) 0
                                            Queue is idle in state(s) 0
                                            LCD is idle in state(s) 0
                                            SBC* is idle in state(s) 0
                                            Daemon is idle in state(s) 0
                                            Aux2 is idle in state(s) 0
                                            Code queue is empty
                                            === CAN ===
                                            Messages queued 41489, received 36956, lost 0, boc 0
                                            Longest wait 1ms for reply type 6042, peak Tx sync delay 386, free buffers 50 (min 49), ts 23058/23057/0
                                            Tx timeouts 0,0,0,0,0,0
                                            === SBC interface ===
                                            Transfer state: 5, failed transfers: 0, checksum errors: 0
                                            RX/TX seq numbers: 23547/23547
                                            SPI underruns 0, overruns 0
                                            State: 5, disconnects: 5, timeouts: 5 total, 5 by SBC, IAP RAM available 0x2ad20
                                            Buffer RX/TX: 0/0-0, open files: 0
                                            === Duet Control Server ===
                                            Duet Control Server v3.4.5
                                            Code buffer space: 4096
                                            Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0
                                            Full transfers per second: 38.22, max time between full transfers: 66.3ms, max pin wait times: 60.9ms/3.9ms
                                            Codes per second: 0.00
                                            Maximum length of RX/TX data transfers: 3195/64
                                            Let me know if I can help with resolving this issue with any more information.
