    Non Duet Hardware with RRF ?
    32
    2.3k
      A Former User
      This post is deleted!
      jay_s_ukundefined R4ffersundefined 3 Replies Last reply Reply Quote 1
        jay_s_uk @A Former User
        @Herve_Smith said in Non Duet Hardware with RRF ?:
        @jay_s_uk
        @R4ffers
        I just drew up a modified version of the "tap" that is lighter, uses less hardware and uses a pair of cross roller guides instead of a linear rail for stability
        Cross roller guides? Do you have a link to those?
          A Former User
            @Herve_Smith thanks. I've ordered a set in preparation
              A Former User @jay_s_uk
              • R4ffersundefined
                R4ffers @A Former User
                @Herve_Smith awesome thanks for this, just ordered a set
                Mb6hc + 3hc + 1lc on Voron V2.4, Mini 5+ exp 2+ on Vzbot 235 AWD, Duet 2 wifi on Ox CNC and Mini 5+ on Millennium Milo v1.5 mini mill.
                • R4ffersundefined
                  @Herve_Smith which sensor have you used and is that a spring?
                    A Former User @R4ffers
                    R4ffersundefined jay_s_ukundefined 2 Replies Last reply Reply Quote 1
                    • R4ffersundefined
                      @Herve_Smith that's them ordered too. many thanks
                        @Herve_Smith Are you able to share your files?
                          • pixelpieperundefined
                            pixelpieper @A Former User
                            @Herve_Smith I have this experimental one which mounts the 1LC in the flap, leaves just enough room to allow for the chain and exposes the two buttons which I have programmed to extrude/retract 3886AEBE-800D-4DBB-B3EE-9650EE6690A2.jpeg D858E30F-9E9E-4D2B-A3CE-4E7DBDA6595B.jpeg
                            Voron V2.434 / Duet 3 Mini5+, Duet 3 Expansion Mini 2+, Duet 1LC V1.1 Toolboard
                            Voron V0.250 / Duet 2 Maestro
                            toxsundefined The_Mechanicundefined 2 Replies Last reply Reply Quote 3
                            • toxsundefined
                              toxs @pixelpieper
                              @pixelpieper do you share your cad files somewhere? 🙂
                              • FlyingAspectundefined
                                FlyingAspect @A Former User
                                @Herve_Smith where can I find the stl file for this stealthburner duet 1LC cover? Would love to do the same.
                                • The_Mechanicundefined
                                  The_Mechanic @pixelpieper
                                  @pixelpieper
                                  Are there any news on your project or is it possible to continue working on it (if you may share the files)?
                                  I really like your approach and want to use is for my Voron Switchwire.
