    Z 0 is positive
    Smart effector for delta printers
    1.1k
    • tecnoundefined
      tecno @Phaedrux
      @Phaedrux
      https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_testing
      Calibrate the Z probe trigger height
      • luca Massimilianoundefined
        luca Massimiliano @Phaedrux
        @Phaedrux said in Z 0 is positive:
        Can you give us some more context to your method?
        SEND ME MORE MATERIAL
        tecnoundefined luca Massimilianoundefined 2 Replies Last reply Reply Quote 0
        • tecnoundefined
          tecno @luca Massimiliano
          @luca-Massimiliano
          Hi Luca, what material?
          tecnoundefined 1 Reply Last reply Reply Quote 0
          • tecnoundefined
            tecno @tecno
            M558 B1 P8 R0.4 C"io3.in+io4.out" H15 F1500 T12000
            G31 P100 X0 Y0 Z-0.557
            M557 R225 S100
              How are you setting Z0 before measuring the probe offset?
              How are you determining Z0 before creating the mesh?
              • tecnoundefined
                tecno @Phaedrux
                @Phaedrux
                home
                move z down to get 0
                g92z0
                A few g30 s-1 to see that it is same
                open config.g
                edit G31 line with offset
                save and M999
                See to that no compensation is active M561
                G29
                luca Massimilianoundefined Phaedruxundefined 2 Replies Last reply Reply Quote 1
                  luca Massimiliano @luca Massimiliano
                  @luca-Massimiliano NO IT'S NOT ENOUGH I WANT TO SEE THE POINT QUOTAS OF YOUR PRINTING PLATE EACH POINT YOU SEE CORRESPONDS TO 3 CORDINATES OK?
                  luca Massimilianoundefined 1 Reply Last reply Reply Quote 0
                    luca Massimiliano @tecno
                        @luca-Massimiliano EVERY POINT IS THE POINT WHERE THE PROBE BEATS OK FRIEND?
                            @luca-Massimiliano FRIEND SORRY I HAVE TO GO NOW EXCUSE ME BYE
                              @luca-Massimiliano Phaedrux KNOWS MUCH MORE THAN I
                                Phaedrux Moderator @tecno
                                @tecno said in Z 0 is positive:
                                save and M999
                                G29
                                Try doing a single G30 at the center of the bed before sending G29 to create the mesh.
                                You should probably also redo your G32 first.
                                • tecnoundefined
                                  tecno @Phaedrux
                                  @Phaedrux
                                  After a lot of tweaking this looks to be the best I can get.
                                  Every adjustment of the plate (3-points) a G32 is a must, G30 and then G29.
                                  Picture below is with 60°C heated bed.
                                  New 8mm thick fine milled cast aluminium plate Ø600mm, what can I expect to get in flatness?
                                  Cheers
                                  Bengt
                                  • infiniteloopundefined
                                    infiniteloop @tecno
                                    @tecno
                                    That’s a good flatness, except of the front/left and rear/right - hmmm - "corners"?. For a Delta, a square grid as you’ve pictured is inappropriate. See M557: Set Z probe point or define probing grid for details. Instead of defining the grid by X/Y, use R to set a radius.
                                    • tecnoundefined
                                      tecno @infiniteloop
                                      @infiniteloop
                                      M557 R225 S75 it is
                                        infiniteloop @tecno
                                        @tecno
                                        M557 R225 S75 it is
                                        Within the radius of 225 mm, some points cannot be reached by the probe without mechanical problems. These are not related to the bed but probably to issues with your motion system - to spot these areas, narrow-down your mesh to an S value of 20 or similar. In the next step, you can either solve the issues (but maybe these are inherent to a Delta) or minimise the probing radius in order to get a proper mesh which merely represents the surface of your bed, excluding other factors. Else, you can’t use the result for mesh bed levelling.
                                        • tecnoundefined
                                          tecno @infiniteloop
                                          Can somebody explain what @infiniteloop is trying to say as I can not grasp this?
                                          @infiniteloop said in Z 0 is positive:
                                            infiniteloop @tecno
                                            Can somebody explain …
                                            Sigh! Let me explain: you published this grid:
                                            That grid is square - to be precise, it has a dimension of 5x5 points. This doesn't match your circular bed very well. That's why I think you might get a better picture using smaller S values, something like this: M557 R225 S20
                                            OK, that's just to draw a better map of your casted print plate. It should cover a larger area than what you get with your current 75 mm raster. Had you ever followed the hint from my first post, you would know what I'm talking about 😊
                                            Now, let's talk about the mechanics:
                                            These two spots don't match the idea of a cast aluminum plate. There must be other reasons. If you follow my advice to generate a more narrow grid, chances are high that you will see even more of these "deviations".
                                            Well, I think these "anomalies" at the edge of your printable area point at mechanical problems (or physical limitations) of your Delta …
                                            … which puts our conversation into kind of a loop (as my nick name implies, I love these): after you have performed and published a better (more narrow) mesh, let's have a new look at my latest post (11.Dec 2022, 17:49).
