    Driver Motor Encoder and wiring
    • lormalundefined
      lormal
      I have this motor: maxon motor 316359 swiss made
      It have two wire red and black to supply the voltage and the other connector is the encoder.
      It is possible to control it with DUET 3mini 5+?
      What type of driver and wiring should i do?
      Thanks
        droftarts administrators @lormal
        @lormal It looks like it is at least a DC motor, possibly brushless. The drivers on Duet boards are for stepper motors, so you can't connect it directly to them. You can probably get it to spin (see https://docs.duet3d.com/User_manual/Connecting_hardware/Motors_servos#connecting-dc-motors) but I can't find any specification information for it, so be careful that it doesn't draw too much current when connecting it to I/O headers. Even if you knew the encoder pin out, there is no way to control the position using the encoder. It may be possible to use an external driver board so it works like a servo motor, but as I can't find any specification on the motor, I can't really advise on what would be compatible.
        lormalundefined 1 Reply Last reply Reply Quote 0
        • lormalundefined
          lormal @droftarts
          @droftarts Thanks for your reply. It is a dc motor of a stratasys machine but i can't find a external driver to connect and control this DC motor. If it is possibile to control it is better but if i cantieri i find another solution.
          sebkritikelundefined 1 Reply Last reply Reply Quote 0
          • sebkritikelundefined
            sebkritikel @lormal
            @lormal Check out these threads - they converted some Stratasys machines over to Duet 2 Wifi +Duex. Drove the extruder servo with a Geckodrive G320X servo motor controller.
            https://forum.duet3d.com/topic/12647/another-stratasys-uprint-retrofit/42
            https://hackaday.io/project/186419-dueprint
            May be of some help. On my project list to do one of these days...
            Large(ish?) IDEX - 6HC, 1HCL
            Stratasys Dimension 1200es to 6HC Conversion
            • lormalundefined
              lormal @sebkritikel
              @sebkritikel Thanks, now i try do some test, but i find useful information!
                sebkritikel @lormal
                @lormal Hope you get a chance to see this - I was able to control likely the same motors using the G320x method. Hopefully if you see it, it is some help!
                https://forum.duet3d.com/topic/31642/duet-2-wifi-and-geckodrive-g320x-on-stepper-channels-10-and-11/10
                • T3P3Tonyundefined T3P3Tony marked this topic as a question
                • T3P3Tonyundefined T3P3Tony has marked this topic as solved
