    not able to get a good first layer using 3PL and bed mesh
    3.2k
    • moth4017undefined
      moth4017 @moth4017
      @Phaedrux 25 point
      • o_lampeundefined
        o_lampe @moth4017
        @moth4017 said in not able to get a good first layer using 3PL and bed mesh:
        i can still detect a difference of 0.18mm after the 3 point leveling.
        Have you set your leadscrew positions correct? If no leadscrews, then use the pivot points of the bed instead. All the 3PL probing can only work with correct pivot point coordinates
        moth4017undefined 1 Reply Last reply Reply Quote 0
        • moth4017undefined
          moth4017 @o_lampe
          @o_lampe ball joints
          M671 X-10:320:155 Y-10:-10:320 S35
          G30 P0 X27 Y27 Z-99999 ; probe near a leadscrew
          G30 P1 X283 Y27 Z-99999 ; probe near a leadscrew
          G30 P2 X155 Y283 Z-99999 S3 ; probe near a leadscrew and calibrate 3 motors
          ;Mesh
          M557 X27:283 Y27:283 S256
            Looks a bit like a saddle shape as you'd see when the X axis sags slightly. There would also be a little left to right tilt along with that.
            • moth4017undefined
              moth4017 @Phaedrux
              @Phaedrux
              so i carnt work out my my nozel height from the bed is so far off ,
              drawing below the inner 4 points is where i probe for Mesh the other middle point at the back of the bed used for 3PL.
              The outer three points are the pivot points Z ( bottom = Front, Top = back of bed)
              probe repeatability test just to make sure its ok.
              bed probe heights: 0.027 0.027 0.027 0.025 0.025 0.025 0.025 0.024 0.024 0.024, mean 0.025, deviation from mean 0.001
              3PL
              12/17/2022, 10:20:58 AM Leadscrew adjustments made: -0.004 -0.003 -0.002, points used 3, (mean, deviation) before (-0.003, 0.001) after (0.000, 0.000)
              home Z.g
              12/17/2022, 10:20:28 AM Leadscrew adjustments made: 0.002 0.008 -0.002, points used 3, (mean, deviation) before (0.003, 0.003) after (0.000, 0.000)
              3PL
              12/17/2022, 10:19:58 AM Leadscrew adjustments made: 0.090 0.091 -0.004, points used 3, (mean, deviation) before (0.055, 0.035) after (-0.000, 0.000)
              3PL
              12/17/2022, 10:19:27 AM Leadscrew adjustments made: 0.481 -0.045 -0.147, points used 3, (mean, deviation) before (0.083, 0.214) after (0.000, 0.000)
              3PL
              measuring the nozel tip to the bed at the front locations
              g1 x304 y27 z1 F15000 gap from nozel to bed 0.85mm
              g1 x27 y27 z1 F15000 gap from nozel to bed 1.20.mm
              Putting a 1mm shim between the y carrier and mgn block left side ( effect of lowering the left side of the x axis) just to see if it has an effect
              g1 x304 y27 z1 F15000 gap from nozel to bed 0.95mm
              g1 x27 y27 z1 F15000 gap from nozel to bed 0.65.mm
              i dont get why the difference is around 0.4mm
              i created a macro to probe the 3pl points to check if there is any discrepancy
              ; Test repeatability at 3PL bed locations
              M291 P"Probe will be tested 12 times and return mean and standard deviation. Ok or Cancel?" R"WARNING" S3 ; User must click OK or cancel.
              M98 P"/macros/ProbePickUp"
              G30 P3 X27 Y27 Z-9999
              G30 P4 X283 Y27 Z-9999
              G30 P5 X155 Y283 Z-9999
              G30 P6 X27 Y27 Z-9999
              G30 P7 X283 Y27 Z-9999
              G30 P8 X155 Y283 Z-9999
              G30 P9 X27 Y27 Z-9999
              G30 P10 X283 Y27 Z-9999
              G30 P11 X155 Y283 Z-9999 S-1
              M98 P"/macros/ProbeDropOff"
              M402
              result
              G32 bed probe heights: 0.116 0.063 0.092 0.097 0.091 0.095 0.097 0.098 0.095 0.098 0.095 0.096, mean 0.095, deviation from mean 0.011
              ProbeDropOff
              gloomyandyundefined 2 Replies Last reply Reply Quote 0
              • gloomyandyundefined
                gloomyandy @moth4017
                @moth4017 That looks like repeated running of your 3PL script is resulting in an increase in the correction each time. That usually indicates that the motor order for the Z axis does not match the order you have specified in M671 (see: https://docs.duet3d.com/User_manual/Connecting_hardware/Z_probe_auto_levelling) if you run 3PL multiple times you should see the values converge. The other potential issue is that I think you mentioned earlier that you removed the call to home z from your 3PL macro. That is probably not a good idea. when you use the 3PL your Z=0 point will almost certainly no longer be correct, so you should really reprobe the bed after each iteration.
                Other than that I have no idea what is going on with your setup. Sorry.
                • moth4017undefined
                  moth4017 @gloomyandy
                  @gloomyandy
                  the values are reducing oldest value at the bottom, here is the results with the values the other way around, newest at the top
                  12/19/2022, 9:53:55 AM ProbeDropOff
                  12/19/2022, 9:53:45 AM Leadscrew adjustments made: 0.000 0.000 0.000, points used 3, (mean, deviation) before (0.000, 0.000) after (0.000, 0.000)
                  3PL finished
                  home Z.g
                  12/19/2022, 9:53:12 AM Leadscrew adjustments made: -0.003 -0.011 -0.003, points used 3, (mean, deviation) before (-0.005, 0.003) after (-0.000, 0.000)
                  3PL finished
                  3PL
                  12/19/2022, 9:52:48 AM Leadscrew adjustments made: -0.013 0.012 0.004, points used 3, (mean, deviation) before (0.001, 0.008) after (-0.000, 0.000)
                  3PL finished
                  3PL
                  12/19/2022, 9:52:17 AM Leadscrew adjustments made: 0.491 0.261 -0.565, points used 3, (mean, deviation) before (0.027, 0.352) after (0.000, 0.000)
                  3PL finished
                  3PL
                  gloomyandyundefined 1 Reply Last reply Reply Quote 0
                    @moth4017 Ok, well so long as they converge, but I still think you should be resetting Z=0 after using 3PL. Other than that sorry no idea....
                    • moth4017undefined
                      @gloomyandy
                      Thanks il add back in the Z=0 after each 3PL to see if it makes a difference,
                      • moth4017undefined
                        moth4017
                        with the z=0 in between the 3PL i have a 0.3mm differenced between left and right side
                        • moth4017undefined
                          moth4017
                          no matter what probe i use or method of checking the gap of the nozzle to the bed i seem to get around the same offset 0.3 to 0.4mm left side of the bed always further from the nozzle than the right .
                          if the 3 probed points on 3PL always come out around these figures 0.002 0.008 -0.002, im not sure why the nozzle is then 0.35 mm ish off the probe values.
                          yet if i do a probe test om the front and left corners i get these results
                          M98 P"0:/macros/probe test front left"
                          G32 bed probe heights: 0.144 0.141 0.141 0.141 0.141 0.144 0.147 0.147 0.147 0.147, mean 0.144, deviation from mean 0.003
                          M98 P"0:/macros/probe test front right"
                          G32 bed probe heights: 0.163 0.166 0.166 0.166 0.166 0.166 0.166 0.166 0.166 0.166, mean 0.165, deviation from mean 0.001
                          it would suggest that when i move the nozzle to the same points the levels have changed .
                          Open to any ideas or way to test this to find the offset
                          i have done a 3PL with the z sensor , replaced the z sensor with a dial gauge sweeped the bed from left to right max error 0.055
                            @moth4017 Do you see the same nozzle height of 0.3 all the way along the left side of the bed or does it change? TRy measuring the nozzle height at several points along the left edge front to back.
                            What point are you probing when you get a "front left" result of 0.141 and "front right" result of 0.166? Why are these readings different to the results you are getting from the front points in your 3PL probes? If you position the probe at the same point as used for your 3PL operation what readings do you get there?
                            • moth4017undefined
                              @gloomyandy
                              so the front of the bed is supported at each corner and the back is supported in the middle. (i have 3 z axis)
                              so the main error im concerned about is at the front as these 2 points should be the same height to keep the bed level.
                              im always probing and measuring at the same points (see drawing above) , so the left front point always seem to be around 0.3mm further away from the nozzle then the front right point after a 3PL.
                              i even took apart the x axis today just to make sure nothing was loose/broken/cracked etc at least i got to re-greese the x mgn.
                              did another test same error, so now i have re-trammed y rails rebuilt x axis , ive also removed the belts on the z axis to make sure there is no debris around the bottom pulley's . as you can see im clutching at straws , i know its going to be something simple at the end of this so lucking forward to kicking myself in the future 😣
                              • o_lampeundefined
                                o_lampe @moth4017
                                @moth4017
                                Did you mention, what type of z-probe sensor you're using? If it's an inductive or capacitive sensor, all sorts of issues can occur.
                                • moth4017undefined
                                  moth4017 @o_lampe
                                  @o_lampe I'm using a micro switch which is picked up and dropped off,
                                    M402
                                    result
                                    These results seem to indicate that there is something odd happening with the first 2 probes compared to the later ones at the same point. This may indicate some sort of backlash problem or perhaps there is still something pulling on the printhead and causing some (small movement) perhaps only when the head is moved in a certain way. The other possibility is that the probe is not fully in place after being picked up and is moving slightly during the probing process. What happens if after probing three points you return to the point you use for the probe pickup/dropoff and then repeat the three probes again? Do you get the same readings or do they change like they are doing above?
                                    moth4017undefined 1 Reply Last reply Reply Quote 1
                                    • moth4017undefined
                                      @gloomyandy
                                      OK so this time i did the 3PL and without dropping of the probe went straight into the corner repeatability test
                                      M98 P"0:/macros/3 corner deveation"
                                      G32 bed probe heights: 0.003 -0.003 0.006 0.003 -0.003 0.003 0.000 0.000 0.003 0.003 0.000 0.000, mean 0.001, deviation from mean 0.003
                                      ProbeDropOff
                                      12/20/2022, 9:10:04 AM Leadscrew adjustments made: -0.030 0.007 -0.006, points used 3, (mean, deviation) before (-0.009, 0.012) after (0.000, 0.000)
                                      3PL finished
                                      so as you pointed out the first 2 readings being different to the rest could have been probe not fully located.
                                      • moth4017undefined
                                        moth4017
                                        now with a drop off and pick up
                                        ProbeDropOff
                                        3PL finished
                                        • moth4017undefined
                                          moth4017
                                          im not sure if this is a valid test or not can someone let me know
                                          also i have M561 to clear / disable bed mesh leveling.
                                          i added these lines to my gcode at the begining and end of the print file
                                          M569 P0.4
                                          M569 P0.5
                                          M569 P0.6
                                          to check to see if the stepper motors were moving during the print
                                          Finished printing file 0:/gcodes/300x300_0.25mm_PLA__3m.gcode, print time was 0h 6m
                                          12/21/2022, 11:50:54 AM Drive 4 runs forwards, active low enable, timing fast, mode spreadCycle, ccr 0x00053, toff 3, tblank 0, hstart/hend/hdec 5/0/0, pos 680
                                          Drive 5 runs in reverse, active low enable, timing fast, mode spreadCycle, ccr 0x00053, toff 3, tblank 0, hstart/hend/hdec 5/0/0, pos 264
                                          Drive 6 runs forwards, active low enable, timing fast, mode spreadCycle, ccr 0x00053, toff 3, tblank 0, hstart/hend/hdec 5/0/0, pos 712
                                          12/21/2022, 11:48:16 AM Drive 4 runs forwards, active low enable, timing fast, mode spreadCycle, ccr 0x00053, toff 3, tblank 0, hstart/hend/hdec 5/0/0, pos 104
                                          Drive 5 runs in reverse, active low enable, timing fast, mode spreadCycle, ccr 0x00053, toff 3, tblank 0, hstart/hend/hdec 5/0/0, pos 828
                                          Drive 6 runs forwards, active low enable, timing fast, mode spreadCycle, ccr 0x00053, toff 3, tblank 0, hstart/hend/hdec 5/0/0, pos 158
                                          the POS numbers are different , does this mean the stepper motors have been moving even though it was only printing a single layer?
                                          • o_lampeundefined
                                            o_lampe @moth4017
                                            @moth4017
                                            I don't know what the POS number means, but it's much too short for a position variable or step counter.
