not able to get a good first layer using 3PL and bed mesh
3.2k
    moth4017 @gloomyandy
    @gloomyandy
    G28,G32 print first photos are at the mid point of each side 0.8mm nozzle 0.3mm layer height , 3 rounds of 3 point leveling on the g28 ,
    on the right hand side of the print the extruder was starting to skip steps.
    the order below front, right hand ( was skipping steps), rear, left hand
    undefined 1 Reply Last reply 12 Dec 2022, 06:53 Reply Quote 0
      moth4017 @moth4017
      @moth4017
      @gloomyandy
      G28, print first photos are at the mid point of each side 0.8mm nozzle 0.3mm layer height , 3 rounds of 3 point leveling on the g28 ,
      sorry about the quality of photos, the LED lighting in the printer not good..
      undefined 1 Reply Last reply 12 Dec 2022, 07:05 Reply Quote 0
        moth4017 @moth4017
        @moth4017 looks like the G28 prints slightly better
        undefined 1 Reply Last reply 12 Dec 2022, 09:00 Reply Quote 0
          gloomyandy @moth4017
          @moth4017 I really wanted to see an overall picture of the print on the bed to judge how things changed. But if it is not possible to get that a good shot of that never mind. Did you do the test of nozzle height v probe result that I suggested?
          undefined 1 Reply Last reply 12 Dec 2022, 17:48 Reply Quote 0
            @gloomyandy I will do the nozzel height check tonight
              @gloomyandy
              bed size 304 x 304
              did a 3PL and i watch and recorded the z heights as it triggered
              Fl 10.06 x2 y2
              FR 10.06 x 304 y 2
              RC 10.07 x150 y277 ( its 277 not 304 as that the closest i can get the sensor to it)
              i then set the nozzel to the same coordinates and measured the distance nozzel to bed with fealer gauges
              g1 x2 y2 z0 >0.7 <0.8
              g1 x304 y2 z0 <0.0 in to the bed
              g1 x150 y277 z0 > 0.1mm <0.15
              just to check there is no offset with the difference in the 10mm off set im going to set z to 10mm and remeasure
              FL 10.06
              FR 9.81
              RC 10.06
                moth4017
                @gloomyandy
                i think this has fixed the issue but nut sure why, this is the only file i changed .
                before
                ; homeall.g
                echo "Home All.g "
                M98 P"/sys/homey.g" ;P define the parameter and is not part of the name
                M98 P"/sys/homex.g" ;P define the parameter and is not part of the name
                M98 P"/macros/ProbePickUp" ; probe pick up
                M98 P"/sys/homez.g" ;P define the parameter and is not part of the name
                M98 P"/macros/3PL" ; 3 point leveling;M98 P"/macros/3PL" ;3 point leveling
                M98 P"/macros/3PL" ; 3 point leveling;M98 P"/macros/3PL" ; 3 point leveling
                M98 P"/macros/ProbeDropOff" ; probe drop off
                after, added the M561 and G29 s2, also removed the home z inbetween the 3PL
                ; homeall.g
                echo "Home All.g "
                M561 ;clear bed transforms
                G29 S2 ;delete bed mesh
                ;M98 P"/sys/homez.g" ;P define the parameter and is not part of the name
                ;M98 P"/macros/3PL" ; 3 point leveling;M98 P"/macros/3PL" ; 3 point leveling
                M98 P"/macros/ProbeDropOff" ; probe drop offcode_text
                so after some test prints at 300 mm x 300mm its is much better i can still detect a difference of 0.18mm after the 3 point leveling.
                doing a g29 mesh does not improve the first layer at all
                undefined 1 Reply Last reply 16 Dec 2022, 08:37 Reply Quote 0
                  It would help visualize the mesh accurately I think if you used a mesh with a 3x3 grid and used the center point for the same point you set Z0 with a G30. You'll get a truer sense of the actual bed.
                  undefined 1 Reply Last reply 16 Dec 2022, 04:15 Reply Quote 0
                    moth4017 @Phaedrux
                    @Phaedrux 9 point
                    undefined 1 Reply Last reply 16 Dec 2022, 04:39 Reply Quote 0
                      moth4017 @moth4017
                      @Phaedrux 25 point
                        o_lampe @moth4017
                        @moth4017 said in not able to get a good first layer using 3PL and bed mesh:
                        Have you set your leadscrew positions correct? If no leadscrews, then use the pivot points of the bed instead. All the 3PL probing can only work with correct pivot point coordinates
                        undefined 1 Reply Last reply 16 Dec 2022, 10:10 Reply Quote 0
                          moth4017 @o_lampe
                          @o_lampe ball joints
                          M671 X-10:320:155 Y-10:-10:320 S35
                          G30 P0 X27 Y27 Z-99999 ; probe near a leadscrew
                          G30 P1 X283 Y27 Z-99999 ; probe near a leadscrew
                          G30 P2 X155 Y283 Z-99999 S3 ; probe near a leadscrew and calibrate 3 motors
                          ;Mesh
                          M557 X27:283 Y27:283 S256
                            Looks a bit like a saddle shape as you'd see when the X axis sags slightly. There would also be a little left to right tilt along with that.
                            undefined 1 Reply Last reply 16 Dec 2022, 21:59 Reply Quote 0
                              moth4017 @Phaedrux
                              @Phaedrux
                              so i carnt work out my my nozel height from the bed is so far off ,
                              drawing below the inner 4 points is where i probe for Mesh the other middle point at the back of the bed used for 3PL.
                              The outer three points are the pivot points Z ( bottom = Front, Top = back of bed)
                              probe repeatability test just to make sure its ok.
                              bed probe heights: 0.027 0.027 0.027 0.025 0.025 0.025 0.025 0.024 0.024 0.024, mean 0.025, deviation from mean 0.001
                              3PL
                              12/17/2022, 10:20:58 AM Leadscrew adjustments made: -0.004 -0.003 -0.002, points used 3, (mean, deviation) before (-0.003, 0.001) after (0.000, 0.000)
                              home Z.g
                              12/17/2022, 10:20:28 AM Leadscrew adjustments made: 0.002 0.008 -0.002, points used 3, (mean, deviation) before (0.003, 0.003) after (0.000, 0.000)
                              3PL
                              12/17/2022, 10:19:58 AM Leadscrew adjustments made: 0.090 0.091 -0.004, points used 3, (mean, deviation) before (0.055, 0.035) after (-0.000, 0.000)
                              3PL
                              12/17/2022, 10:19:27 AM Leadscrew adjustments made: 0.481 -0.045 -0.147, points used 3, (mean, deviation) before (0.083, 0.214) after (0.000, 0.000)
                              3PL
                              measuring the nozel tip to the bed at the front locations
                              g1 x304 y27 z1 F15000 gap from nozel to bed 0.85mm
                              g1 x27 y27 z1 F15000 gap from nozel to bed 1.20.mm
                              Putting a 1mm shim between the y carrier and mgn block left side ( effect of lowering the left side of the x axis) just to see if it has an effect
                              g1 x304 y27 z1 F15000 gap from nozel to bed 0.95mm
                              g1 x27 y27 z1 F15000 gap from nozel to bed 0.65.mm
                              i dont get why the difference is around 0.4mm
                              i created a macro to probe the 3pl points to check if there is any discrepancy
                              ; Test repeatability at 3PL bed locations
                              M291 P"Probe will be tested 12 times and return mean and standard deviation. Ok or Cancel?" R"WARNING" S3 ; User must click OK or cancel.
                              G30 P3 X27 Y27 Z-9999
                              G30 P4 X283 Y27 Z-9999
                              G30 P5 X155 Y283 Z-9999
                              G30 P6 X27 Y27 Z-9999
                              G30 P7 X283 Y27 Z-9999
                              G30 P8 X155 Y283 Z-9999
                              G30 P9 X27 Y27 Z-9999
                              G30 P10 X283 Y27 Z-9999
                              G30 P11 X155 Y283 Z-9999 S-1
                              M402
                              result
                              G32 bed probe heights: 0.116 0.063 0.092 0.097 0.091 0.095 0.097 0.098 0.095 0.098 0.095 0.096, mean 0.095, deviation from mean 0.011
                              ProbeDropOff
                              undefined 2 Replies Last reply 18 Dec 2022, 21:03 Reply Quote 0
                                @moth4017 That looks like repeated running of your 3PL script is resulting in an increase in the correction each time. That usually indicates that the motor order for the Z axis does not match the order you have specified in M671 (see: https://docs.duet3d.com/User_manual/Connecting_hardware/Z_probe_auto_levelling) if you run 3PL multiple times you should see the values converge. The other potential issue is that I think you mentioned earlier that you removed the call to home z from your 3PL macro. That is probably not a good idea. when you use the 3PL your Z=0 point will almost certainly no longer be correct, so you should really reprobe the bed after each iteration.
                                Other than that I have no idea what is going on with your setup. Sorry.
                                undefined 1 Reply Last reply 18 Dec 2022, 21:22 Reply Quote 0
                                  @gloomyandy
                                  the values are reducing oldest value at the bottom, here is the results with the values the other way around, newest at the top
                                  12/19/2022, 9:53:55 AM ProbeDropOff
                                  12/19/2022, 9:53:45 AM Leadscrew adjustments made: 0.000 0.000 0.000, points used 3, (mean, deviation) before (0.000, 0.000) after (0.000, 0.000)
                                  3PL finished
                                  home Z.g
                                  12/19/2022, 9:53:12 AM Leadscrew adjustments made: -0.003 -0.011 -0.003, points used 3, (mean, deviation) before (-0.005, 0.003) after (-0.000, 0.000)
                                  3PL finished
                                  3PL
                                  12/19/2022, 9:52:48 AM Leadscrew adjustments made: -0.013 0.012 0.004, points used 3, (mean, deviation) before (0.001, 0.008) after (-0.000, 0.000)
                                  3PL finished
                                  3PL
                                  12/19/2022, 9:52:17 AM Leadscrew adjustments made: 0.491 0.261 -0.565, points used 3, (mean, deviation) before (0.027, 0.352) after (0.000, 0.000)
                                  3PL finished
                                  3PL
                                  undefined 1 Reply Last reply 18 Dec 2022, 21:36 Reply Quote 0
                                    @moth4017 Ok, well so long as they converge, but I still think you should be resetting Z=0 after using 3PL. Other than that sorry no idea....
                                    undefined 1 Reply Last reply 18 Dec 2022, 22:34 Reply Quote 0
                                      @gloomyandy
                                      Thanks il add back in the Z=0 after each 3PL to see if it makes a difference,
                                        moth4017
                                        with the z=0 in between the 3PL i have a 0.3mm differenced between left and right side
                                          moth4017
                                          no matter what probe i use or method of checking the gap of the nozzle to the bed i seem to get around the same offset 0.3 to 0.4mm left side of the bed always further from the nozzle than the right .
                                          if the 3 probed points on 3PL always come out around these figures 0.002 0.008 -0.002, im not sure why the nozzle is then 0.35 mm ish off the probe values.
                                          yet if i do a probe test om the front and left corners i get these results
                                          M98 P"0:/macros/probe test front left"
                                          G32 bed probe heights: 0.144 0.141 0.141 0.141 0.141 0.144 0.147 0.147 0.147 0.147, mean 0.144, deviation from mean 0.003
                                          M98 P"0:/macros/probe test front right"
                                          G32 bed probe heights: 0.163 0.166 0.166 0.166 0.166 0.166 0.166 0.166 0.166 0.166, mean 0.165, deviation from mean 0.001
                                          it would suggest that when i move the nozzle to the same points the levels have changed .
                                          Open to any ideas or way to test this to find the offset
                                          i have done a 3PL with the z sensor , replaced the z sensor with a dial gauge sweeped the bed from left to right max error 0.055
                                          undefined 1 Reply Last reply 19 Dec 2022, 08:23 Reply Quote 0
                                          38 out of 70
