    Spindle nema 34 duet 2 wifi
    CNC
    10
    45
    2.1k
    • JoergS5undefined
      JoergS5 @o_lampe
      @o_lampe said in Spindle nema 34 duet 2 wifi:
      have to find the same starting point...
      my proposal is to implement it step by step and start with a continuous axis in a separate task. This allows to gather experience wheter e.g. performance is sufficient.
      In longer perspective
      • FreeRTOS trasks are able to inter-process-communicate, i.e. tell each others the status, i.e. synchronize tasks
      • the tasks could be delegated to separate cards then, so step signals don't disturb each other
      • the tasks could execute different kinematics, so multiple kinematics become possible
      • a synchronzation process for all boards through CAN can make sure that a global job scheduler can manage the movements. E.g. by synchronizing the system tick numbers
      paolozampini1973undefined 1 Reply Last reply Reply Quote 0
      • paolozampini1973undefined
        paolozampini1973 @JoergS5
        @JoergS5 said in Spindle nema 34 duet 2 wifi:
        FreeRTOS
        thanks for the answer But honestly I don't want to start writing a program to make a function that in my opinion was a very very very simple function
        • JoergS5undefined
          JoergS5 @paolozampini1973
          @paolozampini1973 no, no, I don't mean that you do it, but one of the developers of RepRapFirmware. I meant this with wishlist: there is a list somewhere what features are wished to be added to future versions.
          A simple requirement, a single continuous axis without synchronization, which is useful for many users have a much higher chance to be implemented than the other ideas I wrote.
            now i understand in the function wishlist But where is this list where you have to make the request?
              dc42 administrators @paolozampini1973
              @paolozampini1973 @CNCModeller if there is enough interest then I can look at providing the option to run a stepper motor as a spindle in a future version of RRF. However, it's likely to be a Duet 3 feature only because of lack of flash memory on Duet 2.
              jay_s_ukundefined CNCModellerundefined paolozampini1973undefined 3 Replies Last reply Reply Quote 1
                jay_s_uk @dc42
                @dc42 it would be a good use case for the 1HCL boards. maintaining a certain RPM with feedback
                • o_lampeundefined
                  o_lampe @jay_s_uk
                  @jay_s_uk
                  That would make sense, if the feedback loop would control the spindle/stepper current. Or do you want to reduce XYZ-speed, when the stepper skips steps due to overload?
                    jay_s_uk @o_lampe
                    @o_lampe thats the thing to work out i suppose. i did think increase current but that would only do so much so slowing things down may make more sense
                    • o_lampeundefined
                      o_lampe @jay_s_uk
                      @jay_s_uk
                      Worst case would be cancelling the job. "Cutting a thread" is not too forgiving in terms of skipped steps.
                        dc42 administrators @o_lampe
                        Will a stepper motor provide sufficient speed and torque? Stepper motors are limited to a few revs/second due to back emf.
                        jay_s_ukundefined paolozampini1973undefined 2 Replies Last reply Reply Quote 0
                          jay_s_uk @dc42
                          @dc42 i have my doubts whether it would
                          • CNCModellerundefined
                            CNCModeller @dc42
                            @dc42 said in Spindle nema 34 duet 2 wifi:
                            @dc42 I'm just speculating on solutions for both threading on a lathe and rigid tapping on a mill. So specifically using a stepper as a spindle drive is just one option.
                            The potential to do limited milling on a lathe using a cross slide mounted milling head with the lathe axis as a rotary would also improve workflow.
                            I'm not sure if any of this would impact performance on my polar printer, especially since I'm using the 1HCL on that axis anyway.
                            In terms of solutions I'm open, just interested in this as one option.
                            Polar Duet3 Mini + 1HCL
                            https://youtube.com/playlist?list=PLWjZVEdMv1BY82izahK45qKh-hp3NFkix
                            Wanhao D4S: Duet2
                            https://forum.duet3d.com/post/296755
                            K40 Laser, Duet2
                            https://forum.duet3d.com/post/312082
                            Wanhao D5S
                            https://www.youtube.com/CNCModellerUK
                              dc42 administrators @CNCModeller
                              @CNCModeller threading and tapping should already be possible, just configure it as a rotary axis.
                                paolozampini1973 @dc42
                                @dc42 @CNCModeller @jay_s_uk
                                a stepper motor can reach 3200 RPM WITHOUT step loss tests done by me personally (nema 17 , 23 , 34 ) and as we know the advantage is the maximum torque at under 500 - 800 rpm and working on the export of materials at low speed leads only advantages because:
                                1. the metal heats up little
                                2. vibrations are very low
                                3. high precision
                                4. for most of the processes it requires very little lubrication and for other processes there is no need to lubricate
                                5. working plastic parts at 200 RPM they work very well having a high torque
                                  VFD motors WORK from 0-22000 RPM i ne or 2 types example: a 3kw at 50 Newton +or- and a 1,5kw disadvantages:
                                6. high current draw
                                7. below 1000 rpm very low torque and does not allow to do some machining especially at 200 RPM
                                8. it takes a lot of lubrication I'LL STOP HERE BECAUSE THERE'S SO MUCH MORE TO SAY ABOUT THE DISADVANTAGES
                                  I CLOSE BY SAYING THAT THE LOW SPEED IS THE BEST IN THE END EVEN IF THE PROCESSING TIMES LONGER
                                OR I READ THAT THERE ARE NUMEROUS PEOPLE INTERESTED
                                I ASK TO ADD TO @DC42 THE FOLLOWING FUNCTIONSIN DUET 2 WIFI, IN ME THE MOST SUITABLE:
                                MILL :
                                1. AXIS FOR CONTINUOUS USE MILLING (ROTATIVE) WHICH HAS THE SAME FUNCTION AS THE VFD
                                  LATHE:
                                2. A OR B OR C AXIS FOR THREADING AND TURNING
                                  I'M SORRY IF I WAS LITTLE SYNTHETIC IN THE EXPLANATIONS AND THANK YOU EVERYONE FOR PARTICIPATING
                                  @DC42 I WOULD LIKE TO HELP
                                  the stepper motor provides high torque at low revs which the vfd motor does not and this brings many advantages for my experience that I have done some technical tests
                                    reading on the forum I saw that there are people particularly interested in the DUET 2 WiFi As for removing plastics with a cutter, I have a lot of experience and also with turning, over time I have understood that high speed has many disadvantages It is better to work at low speed with some strategies you can achieve excellent results without lengthening the times excessively
                                    • oliofundefined
                                      oliof @paolozampini1973
                                      @paolozampini1973 Duet2Wifi will not be able to fit new features due to space constraints.
                                        paolozampini1973 @oliof
                                        @oliof said in Spindle nema 34 duet 2 wifi:
                                        thanks for the answer can it be clearer please Thanks
                                        Nightowlundefined 1 Reply Last reply Reply Quote 0
                                        • Nightowlundefined
                                          Nightowl @paolozampini1973
                                          @paolozampini1973
                                          I think what that means is the memory within the Duet2 doesn't have adequate capacity to store the additional code required.
                                          Few things are more dangerous than taking the advice of someone who thinks he knows what he's doing.
                                          I'm still on my learning curve, so take everything I say with caution!
                                          RatRig 1075, Duet3 MB6HC, Sorotec SFM 1000 PV-ER milling motor, Hobbyist
