    not able to get a good first layer using 3PL and bed mesh
    3.2k
    • moth4017undefined
      moth4017 @gloomyandy
      @gloomyandy
      so the front of the bed is supported at each corner and the back is supported in the middle. (i have 3 z axis)
      so the main error im concerned about is at the front as these 2 points should be the same height to keep the bed level.
      im always probing and measuring at the same points (see drawing above) , so the left front point always seem to be around 0.3mm further away from the nozzle then the front right point after a 3PL.
      i even took apart the x axis today just to make sure nothing was loose/broken/cracked etc at least i got to re-greese the x mgn.
      did another test same error, so now i have re-trammed y rails rebuilt x axis , ive also removed the belts on the z axis to make sure there is no debris around the bottom pulley's . as you can see im clutching at straws , i know its going to be something simple at the end of this so lucking forward to kicking myself in the future 😣
      • o_lampeundefined
        o_lampe @moth4017
        @moth4017
        Did you mention, what type of z-probe sensor you're using? If it's an inductive or capacitive sensor, all sorts of issues can occur.
        moth4017undefined 1 Reply Last reply Reply Quote 0
        • moth4017undefined
          moth4017 @o_lampe
          @o_lampe I'm using a micro switch which is picked up and dropped off,
          • gloomyandyundefined
            gloomyandy @moth4017
            @moth4017 said in not able to get a good first layer using 3PL and bed mesh:
            M291 P"Probe will be tested 12 times and return mean and standard deviation. Ok or Cancel?" R"WARNING" S3 ; User must click OK or cancel.
            M98 P"/macros/ProbePickUp"
            G30 P0 X27 Y27 Z-9999
            G30 P1 X283 Y27 Z-9999
            G30 P2 X155 Y283 Z-9999
            G30 P3 X27 Y27 Z-9999
            G30 P4 X283 Y27 Z-9999
            G30 P5 X155 Y283 Z-9999
            G30 P6 X27 Y27 Z-9999
            G30 P7 X283 Y27 Z-9999
            G30 P8 X155 Y283 Z-9999
            G30 P9 X27 Y27 Z-9999
            G30 P10 X283 Y27 Z-9999
            G30 P11 X155 Y283 Z-9999 S-1
            M98 P"/macros/ProbeDropOff"
            M402
            result
            G32 bed probe heights: 0.116 0.063 0.092 0.097 0.091 0.095 0.097 0.098 0.095 0.098 0.095 0.096, mean 0.095, deviation from mean 0.011
            These results seem to indicate that there is something odd happening with the first 2 probes compared to the later ones at the same point. This may indicate some sort of backlash problem or perhaps there is still something pulling on the printhead and causing some (small movement) perhaps only when the head is moved in a certain way. The other possibility is that the probe is not fully in place after being picked up and is moving slightly during the probing process. What happens if after probing three points you return to the point you use for the probe pickup/dropoff and then repeat the three probes again? Do you get the same readings or do they change like they are doing above?
            moth4017undefined 1 Reply Last reply Reply Quote 1
            • moth4017undefined
              @gloomyandy
              OK so this time i did the 3PL and without dropping of the probe went straight into the corner repeatability test
              M98 P"0:/macros/3 corner deveation"
              G32 bed probe heights: 0.003 -0.003 0.006 0.003 -0.003 0.003 0.000 0.000 0.003 0.003 0.000 0.000, mean 0.001, deviation from mean 0.003
              ProbeDropOff
              12/20/2022, 9:10:04 AM Leadscrew adjustments made: -0.030 0.007 -0.006, points used 3, (mean, deviation) before (-0.009, 0.012) after (0.000, 0.000)
              3PL finished
              so as you pointed out the first 2 readings being different to the rest could have been probe not fully located.
              • moth4017undefined
                moth4017
                now with a drop off and pick up
                ProbeDropOff
                3PL finished
                • moth4017undefined
                  moth4017
                  im not sure if this is a valid test or not can someone let me know
                  also i have M561 to clear / disable bed mesh leveling.
                  i added these lines to my gcode at the begining and end of the print file
                  M569 P0.4
                  M569 P0.5
                  M569 P0.6
                  to check to see if the stepper motors were moving during the print
                  Finished printing file 0:/gcodes/300x300_0.25mm_PLA__3m.gcode, print time was 0h 6m
                  12/21/2022, 11:50:54 AM Drive 4 runs forwards, active low enable, timing fast, mode spreadCycle, ccr 0x00053, toff 3, tblank 0, hstart/hend/hdec 5/0/0, pos 680
                  Drive 5 runs in reverse, active low enable, timing fast, mode spreadCycle, ccr 0x00053, toff 3, tblank 0, hstart/hend/hdec 5/0/0, pos 264
                  Drive 6 runs forwards, active low enable, timing fast, mode spreadCycle, ccr 0x00053, toff 3, tblank 0, hstart/hend/hdec 5/0/0, pos 712
                  12/21/2022, 11:48:16 AM Drive 4 runs forwards, active low enable, timing fast, mode spreadCycle, ccr 0x00053, toff 3, tblank 0, hstart/hend/hdec 5/0/0, pos 104
                  Drive 5 runs in reverse, active low enable, timing fast, mode spreadCycle, ccr 0x00053, toff 3, tblank 0, hstart/hend/hdec 5/0/0, pos 828
                  Drive 6 runs forwards, active low enable, timing fast, mode spreadCycle, ccr 0x00053, toff 3, tblank 0, hstart/hend/hdec 5/0/0, pos 158
                  the POS numbers are different , does this mean the stepper motors have been moving even though it was only printing a single layer?
                  • o_lampeundefined
                    o_lampe @moth4017
                    @moth4017
                    I don't know what the POS number means, but it's much too short for a position variable or step counter.
                    • moth4017undefined
                      moth4017
                      Reprinting parts for new x axis going to put them on the surface table before reinstalling to check for twist .
                      • moth4017undefined
                        moth4017
                        could not find a repeatable way to check the twist that i was happy with , so printed some more Y carrier parts as my others had cracks in them, reassembled did the 300 x 300 print test again, the same issue nozzle on the left-hand side of bed was further away then the right. look like about the same amount , not measured it yet
                        • moth4017undefined
                          moth4017
                          OK i think i have solved the issue :-
                          Its to do with 3PL , i have always measured 3 points in the 3PL , but have discovered today if you do a 4 points it levels much better .
                          I now do this
                          ;3PL
                          echo "3PL"
                          M561 ; cancels any bed-plane fitting as the result of probing
                          M564 S0 ; allow movement outside boundaries
                          G30 P0 X27 Y27 Z-99999 ; probe FR
                          G30 P1 X283 Y27 Z-99999 ; probe FL
                          G30 P2 X283 Y283 Z-99999 ; probe RL
                          G30 P3 X27 Y283 Z-99999 S3 ; probe RR S3 = 3 z axis
                          G90 ; Set to Absolute Positioning
                          echo "3PL finished" ;send Diagnose to console
                            dc42 administrators @moth4017
                            @moth4017 thanks for updating us.
                            Exerqtorundefined 1 Reply Last reply Reply Quote 1
                            • dc42undefined dc42 marked this topic as a question
                            • dc42undefined dc42 has marked this topic as solved
                            • Exerqtorundefined
                              Exerqtor @dc42
                              Whats best practice regarding this btw @dc42 ? To tram with 3 or 4 probe points on a bed with three points of pivot/adjustment?
                              moth4017undefined dc42undefined 2 Replies Last reply Reply Quote 0
                              • moth4017undefined
                                moth4017 @Exerqtor
                                @Exerqtor i used to probe 3 points but since going to 4 i can not get a good first layer doing a 300mm x 300mm print, my bed is supported on 3 points i would recommend it my bed is 320 x320 .
                                Exerqtorundefined 1 Reply Last reply Reply Quote 0
                                  dc42 administrators @Exerqtor
                                  @Exerqtor said in not able to get a good first layer using 3PL and bed mesh:
                                  You can use between N points (where N = number of Z motors) and 32. RRF will minimise the RMS error over all the points. If the bed is flat and the gantry doesn't sag then 3 or 4 points should work well. If it isn't then a higher number may be better.
                                  You may find it beneficial to run bed tramming more than once, if your mechanics don't match the model assumed by RRF. You can do this using a loop in the bed.g file.
                                  • moth4017undefined
                                    moth4017
                                    Good point DC42 makes about the loop, i spent time on this yesterday now only probes the amount of times required to get within your desired tolerance.
                                    ;G32  Auto calibration routine for large bed
                                    M561                    ; clear any bed transform
                                    ; If the printer hasn't been homed, home it
                                    if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed
                                    G28
                                    M98 P"/macros/ProbePickUp"	; probe pick up
                                    ; Probe the bed and do auto calibration
                                    G1 X14 Y44 Z25 F20000        ; go to just above the first probe point
                                    while true
                                      if iterations = 5
                                        abort "Too many auto calibration attempts"
                                      G30 P0 X17 Y17 Z-99999               ; probe starboard bow
                                      if result != 0
                                        continue
                                      G30 P1 X293 Y17 Z-99999              ; probe port bow
                                      if result != 0
                                        continue
                                      G30 P2 X293 Y283 Z-99999             ; probe port stern
                                      if result != 0
                                        continue
                                      G30 P3 X17 Y283  Z-99999 S3          ; probe starboard stern   S3 = 3 z axis
                                      if result != 0
                                        continue
                                      if move.calibration.initial.deviation <= 0.04
                                        break
                                      echo "Repeating calibration because deviation is too high (" ^ move.calibration.initial.deviation ^ "mm)"
                                    ; end loop
                                    echo "Auto calibration successful, deviation", move.calibration.final.deviation ^ "mm"
                                    G1 F6000 X155 Y185					; probe to center bed
                                    G30 F2000							;Single Z-Probe
                                    M98 P"/macros/ProbeDropOff"	; probe drop off
                                    G10 Z30 F10000                ; get the head out of the way
                                    instead of having to always do x rounds of G32 i usually can get away with 2 , results like this
                                    1/15/2023, 9:20:14 AM	ProbeDropOff
                                    1/15/2023, 9:20:06 AM	Leadscrew adjustments made: -0.041 -0.023 0.019, points used 4, (mean, deviation) before (-0.008, 0.023) after (0.000, 0.008)
                                    Auto calibration successful, deviation 0.008mm
                                    1/15/2023, 9:19:20 AM	Leadscrew adjustments made: 2.404 -0.150 -0.937, points used 4, (mean, deviation) before (0.137, 1.350) after (0.000, 0.002)
                                    Repeating calibration because deviation is too high (1.350mm)
                                    1/15/2023, 9:18:49 AM	Probe Pickup complete
                                      @moth4017 it may be an artefact of inserting the file in your post, however it appears that the G28 command in line 6 may not be indented with respect to the if-command.
                                      • Exerqtorundefined
                                        Exerqtor @moth4017
                                        I got the feeling you went from 3-probes to 4-probes, not the other way around? 😅
                                        And that going to 4 solved the issues, not the other way around? 🤔
                                        @dc42 said in not able to get a good first layer using 3PL and bed mesh:
                                        Ok, gotcha. I thought the number of probe points had to be equal to the number of pivot points/steppers for some reason.
                                        Allready running two passes with the first being a coarse'n quick pass just to get it trammed-ish then a second run inside a loop that breaks when the deviation goes bellow aset tolerance or if it does more than a set number of iterations.
                                        Sorry for the edit, managed to press "post" rather than "minimize" earlier so i only got the first line lol.
                                        • moth4017undefined
                                          moth4017 @Exerqtor
                                          @Exerqtor i did go from 3 to 4 probes 🙂
                                          my bed is on 3 points of support , (maxwell coupling )
                                          • moth4017undefined
                                            moth4017 @dc42
                                            @dc42 just a little change required in the next update when it does the bed adjustment and report "Leadscrew adjustments made: i dont have lead screws i have belts 🙂 can it be changed to Z adjustment or Bed or just something more generic. Cheers
