    Available WebCam Options 2023
    Third-party add-ons
    10
    14
    688
      T3P3Tony administrators @Marshalldog
      @Marshalldog DuetWebControl connects directly to the IP camera from your browser to display the camera feed. If the newer cameras use the same protocol then I expect they will be compatible. Can you link to an alternative you were considering? @chrishamm can confirm the compatible protocol(s).
      Marshalldogundefined chrishammundefined 2 Replies Last reply Reply Quote 0
      • DIY-O-Sphereundefined
        DIY-O-Sphere @Marshalldog
        @Marshalldog
        You need a camera that can output a mjpeg stream. Some cheap cameras can only stream rstp, but this cannot be displayed directly in the browser (DWC).
        (UTC+1)
        • Marshalldogundefined
          Marshalldog @T3P3Tony
          @T3P3Tony @chrishamm I was looking at this camera: https://www.aliexpress.com/item/1005001798613203.html?spm=a2g0o.productlist.main.33.4e59483axyk4vt&algo_pvid=57b29110-2cea-4f22-b34e-495f7193e38b&algo_exp_id=57b29110-2cea-4f22-b34e-495f7193e38b-16&pdp_ext_f={"sku_id"%3A"12000017628395472"}&pdp_npi=2%40dis!AUD!68.56!41.13!!!!!%40212248ba16733466556902032d06a2!12000017628395472!sea&curPageLogUid=4ChpGEAFpG2k
          but i am unsure if this is compatible
            dc42 administrators @Marshalldog
            @Marshalldog that page gives the model number as I71BD. The second row of the table at https://www.ispyconnect.com/camera/sannce suggests that it does support providing a still JPEG image, which is what DWC needs.
            • Exerqtorundefined
              Exerqtor
              Would be awesome if it was some small formfactor cams (or ones that we could tear down and make new housings for), so we would make some neat "easy to tuck away" soulutions! "All" the ones that's verified working are so huge their borderline impossible to mount inside a build chamber.
              Something like this for instance
              gloomyandyundefined 1 Reply Last reply Reply Quote 0
              • chrishammundefined
                chrishamm administrators @T3P3Tony
                @T3P3Tony @Marshalldog Most webcam work well with Linux SBCs, they just need to implement the USB UVC standard. I think most newer cameras do this.
                Duet software engineer
                • gloomyandyundefined
                  gloomyandy @Exerqtor
                  @Exerqtor Maybe an esp32cam based solution would work? https://forum.duet3d.com/topic/24024/cheapest-wifi-webcam-esp32-ov2640-camera?_=1673342139324
                  Exerqtorundefined 1 Reply Last reply Reply Quote 0
                  • Exerqtorundefined
                    Exerqtor @gloomyandy
                    @gloomyandy
                    Interesting, as long as i don't have a huge monstrosity or have to use a SBC i'm happy 🤣
                    • mrehorstdmdundefined
                      mrehorstdmd
                      When I must use a camera, I use an old cell phone that is programmed to shoot a photo every minute or so (with time stamping on each image), or trigger the camera with a bluetooth button that snaps a picture at every layer change. I use an Android phone so the photos get uploaded to Google Photos as soon as they are snapped, so I can see the images anywhere, with any web browser. The phone camera is better than any web cam or RPi camera module and this use keeps the phone out of the landfill. The still photos can easily be turned into time lapse video.
                      https://drmrehorst.blogspot.com/2019/08/putting-old-cell-phone-to-good-use.html
                      https://drmrehorst.blogspot.com/2020/04/fancy-no-hack-layer-synchronized-time.html
                      • Topengaundefined
                        Topenga
                        Where i may find all necessary information in one shot or rather follow up how to configure and what has to be respected to the WebCam addOn?
                        Many thx
                        Danijel
                          droftarts administrators @Topenga
                          @Topenga see https://docs.duet3d.com/User_manual/Reference/DWC_webcam
                            Marshalldog
                            Update:
                            I received the camera "sannce I71BD" but I can't get the device to connect to wifi. I'll provide another update if anything changes
                              Marshalldog
                              Weird Issue with the sannce I71BD,
                              I've been trying to get the camera to connect to my router and I got it to work (under weird conditions). Usually, I have my wireless network 2.4ghz security set to WPA2 (which the camera SUPPOSEDLY supports). I tried for hours to get the camera to connect to the wifi network but it consistently failed. I changed the network security to WPA + WPA2 the camera connected and worked immediately. That implies that the camera only works with WPA (which is insecure). I've contacted the manufacturers to figure out the problem but won't be hearing back from them until the end of the Chinese new year (according to the automatic email). I'll provide another update if anything changes
