    [3.5b1+] Inaccurate print dimensions
    Beta Firmware
    2.3k
    • IndeX4Dundefined
      IndeX4D @Diamondback
      @Diamondback
      I have a similar problem on 2 different machines. Both were working correctly with 3.4.5 , now I have some Z high issues on both.
      Multiple / 4 z-axis at work.
      Richard
      • Diamondbackundefined
        Diamondback
        Here's two example prints, same gcode, 3.5b1+ printed first, then back to 3.4.5. Both were printed directly after the other as quickly as possible, no changes to config etc, purely the firmware was changed.
        3.5b1+:
        3.4.5:
        The height difference is fairly small here (~0.6mm) compared to my previous issues with the MFM housing, so it looks like the issue somewhat depends on the actual print file.
        @IndeX4D since you also mention multiple Z steppers, maybe something related to that?
        IndeX4Dundefined 1 Reply Last reply Reply Quote 1
        • IndeX4Dundefined
          @Diamondback
          I had 2 prints with machine 1 (GeneralG) where I had little extrusion problems..... after a little pause, the nozzle crashed into the model.
          Objekt high 90mm. Problem started at about 50mm.
          Extrusion problems -> may missing z steps?
          Nozzle crash into model after PAUSE --> missing offset or much more z steps were missing? (about 4mm-->like other problem with machine 2)
          I thought somthing is wrong with my axis and because I wanted to change the x gantry, I stopped printing with machine 1 (Generalg).
          Then --->
          1.--> Machine 2 (Black Flamingo) lost steps after every print, because I had to readjust z every print start something between 0.2 and
          0.6mm. Missing z steps in this case are NOT shown in the model but It was a 10mm high print only. May it´s losing steps by any other action. Finish print or start print?
          It´s definetely not normal to readjust z offset after every 45min print. Print looks nice but Z offset needs to readjust? Strange
          --> 2 . Nozzle crashed into heatbed when executing ´´print again´´ - I think printer ´´forgot´´ the z offset. (4mm). Tool was already coupled from print before.
          R.G.
          • IndeX4Dundefined
            IndeX4D
            EDIT: when resuming after pause, the offset? is not applied anymore... nozzle crash.
            Maybe --> same behaviour when execute print again or tool change. I Will test a bit more.
            • Philippe71undefined
              Philippe71
              I have exactly the same problem with a Duet3-6HC + exp3HC + 3.5b1+.
              Same problem as on the pictures.
              I went back to version 3.4.5, everything works again (same GCode, same configuration).
              Currently my machine is printing, I will switch back to 3.5b1+ and send an M98 P "config.g" and M201, M203, M566 and M906 when it is finished.
                dc42 administrators @Diamondback
                @Diamondback it looks to me that at some layers Z has not moved as far as it should, hence the extrusion bulges. Can you tell if it is all three Z motors that have not moved, or just one of them? If you can't tell, are you able to print e.g. a large hollow cuboid so thay you can tell?
                @Philippe71 do you have a single Z motor, or more than one?
                Diamondbackundefined Philippe71undefined 2 Replies Last reply Reply Quote 1
                  Diamondback @dc42
                  @dc42 The bulged lines go around the whole print at the same heights, so I would guess that it's all 3 motors? Do you want the cube in vase mode or normal? What wall thickness?
                    Hi @Diamondback, vase mode is different (Z changes continuously) so it might not show the same effect.
                    Diamondbackundefined 2 Replies Last reply Reply Quote 1
                      Diamondback @dc42
                      @dc42 So I printed a 75x75x50 empty cuboid on 3.4.5 (came out perfectly as expected) and I am now printing the exact same gcode on 3.5b1+.
                      Interestingly there does not appear to be any issue whatsoever this time around. The print looks exactly the same.
                      Things to note:
                      • Wall thickness of 1.2mm/3 walls @0.4mm
                      • There's no retractions going on (the previous prints with issues did have retractions)
                      • I do not use Z-hop with retractions, Z only ever changes with completed layers and the active mesh leveling
                        Diamondback @dc42
                        @dc42 Two more images. The first shows the difference between a "well" printed (3.4.5) MFM housing variation and a faulty (3.5b1+) one, note the stark difference in the height of the posts, this is not a result of the viewing angle. Also note the bulging extrusion again. (one is rotated 180°, so don't be confused by the different sides being visible)
                        This one is the faulty one alone, note how clearly the hole in the front is not round at all, again this not an illusion from the photo.
                        (Sorry for the weird colors in the photos, looks like my phone is doing some over the top HDR stuff or something...)
                          Philippe71 @dc42
                          There are 2 Z motors
                          MaxGyverundefined 1 Reply Last reply Reply Quote 1
                          • MaxGyverundefined
                            MaxGyver @Philippe71
                            I can confirm the problem. With 3.5b1+ layers seem periodically “squished” in Z direction, almost like Z-Wobble.
                            My setup:
                            Duet36HC with 4 Z-Leadscrews.
                            Bed tramming is performed before every print, and mesh compensation is active.
                            I also redid the mesh probing after updating, just to be sure.
                              Diamondback
                              @dc42 anything else we can do to help you diagnose/replicate the issue? Looks like so far, everyone here has more than one Z stepper and is using active bed tramming?
                              • oliofundefined
                                oliof @Diamondback
                                @Diamondback maybe try printing without bed compensation to see if that triggers the same issue. Use a raft if required to ensure bed is not causing issues.
                                  dc42 administrators @oliof
                                  @oliof said in [3.5b1+] Inaccurate print dimensions:
                                  An excellent idea! Right now I don't know what is causing this issue. Knowing whether bed compensation is implicated would help me to narrow it down.
                                    Diamondback
                                    Ok cool, I can disable both mesh compensation and active leveling. (the leveling part before each print is not really needed anymore anyway since I upgraded my spindles to finder pitch)
                                    • oliofundefined
                                      oliof @Diamondback
                                      @Diamondback if you disable two things, please make three runs: One without both, and one where either or is disabled
                                      @dc42 the reason I thought of that is that elsewhere I recently helped debug an issue that looked like bad segmentation, but it was low Z jerk and acceleration combined with bed compensation that looked like the bulging corner issue.
                                      • IndeX4Dundefined
                                        IndeX4D
                                        My print dimensions are correct, but when start a new print the z axis is exactly 0.2mm to deep.
                                        After pause, It seemed like the z offset has completely gone. Should I make a new thread about this?
                                        -4 z-axis
                                        -Axis compensation active
                                          dc42 administrators @IndeX4D
                                          @IndeX4D said in [3.5b1+] Inaccurate print dimensions:
                                          My print dimensions are correct, but after every print, but every new print hast the Z axis 0.2 to deep.
                                          Yes please! Include your config file, and whether you are using babystepping or any other use of M290.
                                            Diamondback
                                            Ok so, here are the results from 3.5b1+:
                                            • Active leveling before the print + mesh bed compensation active -> Broken
                                            • Only mesh bed compensation -> Broken
                                            • Only active leveling -> No issue
                                            So it appears that mesh bed compensation is indeed related in some way.
                                            dc42undefined 2 Replies Last reply Reply Quote 1
