    [3.5b1+] Inaccurate print dimensions
    Beta Firmware
    2.3k
      dc42 administrators @Diamondback
      @Diamondback it looks to me that at some layers Z has not moved as far as it should, hence the extrusion bulges. Can you tell if it is all three Z motors that have not moved, or just one of them? If you can't tell, are you able to print e.g. a large hollow cuboid so thay you can tell?
      @Philippe71 do you have a single Z motor, or more than one?
      Diamondbackundefined Philippe71undefined 2 Replies Last reply Reply Quote 1
      • Diamondbackundefined
        Diamondback @dc42
        @dc42 The bulged lines go around the whole print at the same heights, so I would guess that it's all 3 motors? Do you want the cube in vase mode or normal? What wall thickness?
          Hi @Diamondback, vase mode is different (Z changes continuously) so it might not show the same effect.
          Diamondbackundefined 2 Replies Last reply Reply Quote 1
            Diamondback @dc42
            @dc42 So I printed a 75x75x50 empty cuboid on 3.4.5 (came out perfectly as expected) and I am now printing the exact same gcode on 3.5b1+.
            Interestingly there does not appear to be any issue whatsoever this time around. The print looks exactly the same.
            Things to note:
            • Wall thickness of 1.2mm/3 walls @0.4mm
            • There's no retractions going on (the previous prints with issues did have retractions)
            • I do not use Z-hop with retractions, Z only ever changes with completed layers and the active mesh leveling
              Diamondback @dc42
              @dc42 Two more images. The first shows the difference between a "well" printed (3.4.5) MFM housing variation and a faulty (3.5b1+) one, note the stark difference in the height of the posts, this is not a result of the viewing angle. Also note the bulging extrusion again. (one is rotated 180°, so don't be confused by the different sides being visible)
              This one is the faulty one alone, note how clearly the hole in the front is not round at all, again this not an illusion from the photo.
              (Sorry for the weird colors in the photos, looks like my phone is doing some over the top HDR stuff or something...)
              • Philippe71undefined
                Philippe71 @dc42
                There are 2 Z motors
                MaxGyverundefined 1 Reply Last reply Reply Quote 1
                • MaxGyverundefined
                  MaxGyver @Philippe71
                  I can confirm the problem. With 3.5b1+ layers seem periodically “squished” in Z direction, almost like Z-Wobble.
                  My setup:
                  Duet36HC with 4 Z-Leadscrews.
                  Bed tramming is performed before every print, and mesh compensation is active.
                  I also redid the mesh probing after updating, just to be sure.
                    Diamondback
                    @dc42 anything else we can do to help you diagnose/replicate the issue? Looks like so far, everyone here has more than one Z stepper and is using active bed tramming?
                    • oliofundefined
                      oliof @Diamondback
                      @Diamondback maybe try printing without bed compensation to see if that triggers the same issue. Use a raft if required to ensure bed is not causing issues.
                        dc42 administrators @oliof
                        @oliof said in [3.5b1+] Inaccurate print dimensions:
                        An excellent idea! Right now I don't know what is causing this issue. Knowing whether bed compensation is implicated would help me to narrow it down.
                          Diamondback
                          Ok cool, I can disable both mesh compensation and active leveling. (the leveling part before each print is not really needed anymore anyway since I upgraded my spindles to finder pitch)
                          • oliofundefined
                            oliof @Diamondback
                            @Diamondback if you disable two things, please make three runs: One without both, and one where either or is disabled
                            @dc42 the reason I thought of that is that elsewhere I recently helped debug an issue that looked like bad segmentation, but it was low Z jerk and acceleration combined with bed compensation that looked like the bulging corner issue.
                            • IndeX4Dundefined
                              IndeX4D
                              My print dimensions are correct, but when start a new print the z axis is exactly 0.2mm to deep.
                              After pause, It seemed like the z offset has completely gone. Should I make a new thread about this?
                              -4 z-axis
                              -Axis compensation active
                                dc42 administrators @IndeX4D
                                @IndeX4D said in [3.5b1+] Inaccurate print dimensions:
                                My print dimensions are correct, but after every print, but every new print hast the Z axis 0.2 to deep.
                                Yes please! Include your config file, and whether you are using babystepping or any other use of M290.
                                  Diamondback
                                  Ok so, here are the results from 3.5b1+:
                                  • Active leveling before the print + mesh bed compensation active -> Broken
                                  • Only mesh bed compensation -> Broken
                                  • Only active leveling -> No issue
                                  So it appears that mesh bed compensation is indeed related in some way.
                                  dc42undefined 2 Replies Last reply Reply Quote 1
                                    @Diamondback thanks, that's very useful.
                                      @Diamondback
                                      • Do you have any layer change script in those models, or anything else happening during the print (after initial heating etc.) other than G1 commands?
                                      • Do you have daemon.g running?
                                      Diamondbackundefined 1 Reply Last reply Reply Quote 1
                                        Diamondback @dc42
                                        @dc42 Not exactly sure what you mean with the first point, I can share the gcode though.
                                        AccuracyDebug.gcode
                                        As for daemon, yes, at that point it was a regular daemon.g with NO loop in it that has this content:
                                        if state.status == "idle" && global.deactivateToolAfterFilamentChange == true
                                        	echo "Unloading tool after filament change"
                                        	T-1
                                        set global.deactivateToolAfterFilamentChange = false
                                        if state.status == "processing" && state.gpOut[1].pwm > 0 && job.layer == 3
                                        	M98 P"/macros/Misc/Lights/Off"
                                          @Diamondback I tried to reproduce this on my tool changer, which uses a 6HC, but the print using the current RRF 3.5 build was the same height as the one using RRF 3.4.5 and doesn't show the layer artefacts. I had mesh bed compensation enabled.
                                          Have you time to run some more tests? If so:
                                          • Please try the latest RRF build for the 6HC at https://www.dropbox.com/sh/5vxz29a7400gwcy/AAAPexxpGsP0LMo0jEFOOCqVa?dl=0
                                          • If it shows the same issue, try stopping the daemon task (rename daemon.g to something else)
                                          • If it still shows the same issue, try disabling bed compensation and instead enable segmentation using M669 S100 T10 (preferably, replace the 10 by the mesh spacing you use). This will tell me whether it is the bed compensation that provokes the issue, or the segmentation that occurs when bed compensation is enabled.
                                            Diamondback @dc42
                                            @dc42 Currently printing some actual parts, will do these tests afterwards. 👍
