    Canned ERCF board v1.0-beta2
    My Duet controlled machine
    9
    24
    2.5k
    • Gixxerfastundefined
      Gixxerfast @R4ffers
      @r4ffers Well, I have some extra boards to sell. The tricky part is to get hold of a Sammy. the ATSAMC21 is a bit unobtanium at the moment (for us regular folks anyway)
      Voron V2.4 (#1317) with Duet 3 Mini5+ Wifi and 1LC v1.1 Toolboard
      Voron V0.1 (#637) with Duet 3 Mini 5+ Wifi and 1LC v1.2 Toolboard
      Ender 3 Pro with BTT SKR-2 + RRF
      Th0mpyundefined 1 Reply Last reply Reply Quote 0
      • Th0mpyundefined
        Th0mpy @Gixxerfast
        @gixxerfast I'd be interested in buying one if you still have one available. Perhaps a trade?
        Usually the team that scores the most points wins the game.
          Gixxerfast
          Apologizes to those who contacted me about the board, I have been (and still am) a wee bit under the weather but I'll respond to you shortly.
          Anyway, I thought that a good test for the board would be to hook it up to drive the A & B motors on the Voron V0.1 running two Nema 14 motors at 1200 mA at 4000 mm/s^2 (5000 travel) and see what happens.
          Said and done. Start:
          https://youtu.be/Jh0_QzTjQ-Q
          End:
          https://youtu.be/QYoGkQ9I5lc
          Finished test print:
          With this I'm pretty sure it will ahev no problems winding some filaments up and down with th ERCF
          Btw, the enraged rabbit feeder is on the way 🙂
          I have another new version in mind that utilizes more Duet hardware but it requires more changes to the firmware changing the slave addressing. Shouldn't be more that a few places. Maybe a couple of ifdefs is enough 🙂
          I just love the Duet hardware and RRF. Swap two drive cables. change two lines in the config.g and restart and you have swapped motor drivers to another board.
            jay_s_uk
            I have 4 of the Canned ERCF boards available.
            They come with all the connectors required. All that's required is for you to purchased a SammyC21 and to provide 2 x 2209 drivers.
            https://www.chip45.com/products/sammy-c21-1.0_atmel_smart_arm_sam_module_samc21_usb_dual_can_duet3d.php
            I have also compiled the firmware for 3.4.2-RC2. It's available here https://github.com/jaysuk/Duet3Expansion/releases
            They are £18 + postage.
            I can also supply 2 x Fly 2209 drivers for a further £10
            dc42undefined R4ffersundefined Morane_3803undefined 3 Replies Last reply Reply Quote 0
              dc42 administrators @jay_s_uk
              Filastruder still has the SammyC21 in stock according to their web site, https://www.filastruder.com/collections/electronics/products/sammy-c21-v1-0-duet3d-module.
              • R4ffersundefined
                R4ffers @jay_s_uk
                @jay_s_uk Hi, do you still have any canned ercf left?
                Mb6hc + 3hc + 1lc on Voron V2.4, Mini 5+ exp 2+ on Vzbot 235 AWD, Duet 2 wifi on Ox CNC and Mini 5+ on Millennium Milo v1.5 mini mill.
                  jay_s_uk @R4ffers
                  @R4ffers I do
                  R4ffersundefined 1 Reply Last reply Reply Quote 1
                  • R4ffersundefined
                    R4ffers @jay_s_uk
                    @jay_s_uk woohoo lol, It seems that I may have a Sammy on the way.
                    Could I buy a board from you please?
                    • Morane_3803undefined
                      Morane_3803 @jay_s_uk
                      @jay_s_uk
                      Hi there, is one of the Canned ERCF boards still available?
                      If yes, how could I pay for it? PayPal?
                      Thanks a lot. Regards Martin
                      • joekoundefined
                        joeko
                        can i order the Canned ERCF board ?
                        • Th0mpyundefined
                          Th0mpy @joeko
                          @joeko Where are you located?
                          joekoundefined 1 Reply Last reply Reply Quote 0
                          • joekoundefined
                            joeko @Th0mpy
                            @Th0mpy germany
                            Th0mpyundefined 2 Replies Last reply Reply Quote 0
                            • Th0mpyundefined
                              Th0mpy @joeko
                              @joeko I have a couple that I had made, but in the US. It would be much less expensive to just order it assembled from PCBWay or similar outfit.
                              • Th0mpyundefined
                                Th0mpy @joeko
                                @joeko That said, let me see if I can publish it on PCBWay and you could just order it assembled from them.
                                • joekoundefined
                                  joeko @Th0mpy
                                  @Th0mpy ok. but is it also possible to use an Expansion board with can conneted ?
                                  • Th0mpyundefined
                                    Th0mpy @joeko
                                    @joeko I don't see why not. The ERCF board is really just a purpose-built toolboard. The benefit to the expansion board is that it's tried and true hardware, less chance of major issues 🙂 The big obvious difference is the form factor.
                                    • joekoundefined
                                      joeko @Th0mpy
                                      @Th0mpy yes and the price 🙂
                                      but until now i am only think about. does this mmu system works without big problems ?
                                      oliofundefined Th0mpyundefined 2 Replies Last reply Reply Quote 0
                                      • oliofundefined
                                        oliof @joeko
                                        @joeko define "big problems" -- I know a bunch of people that use ERCF successfully. Requires some extra considerations, but that's to expected if you add multiple different rolls of filament and additional steppers....
                                        • Th0mpyundefined
                                          Th0mpy @joeko
                                          @joeko It CAN work well, but you need to be ready for some failures and tweaking. There are so many things that are out of the control of the device itself so you need to be prepared for that. It's not for the faint of heart.
                                          • joekoundefined
                                            joeko
                                            i have ordered one and will use it with an expansion board.
                                            i will see 🙂
