    Canned ERCF board v1.0-beta2
    My Duet controlled machine
    9
    24
    2.5k
      jay_s_uk @R4ffers
      @R4ffers I do
      R4ffersundefined 1 Reply Last reply Reply Quote 1
      • R4ffersundefined
        R4ffers @jay_s_uk
        @jay_s_uk woohoo lol, It seems that I may have a Sammy on the way.
        Could I buy a board from you please?
        Mb6hc + 3hc + 1lc on Voron V2.4, Mini 5+ exp 2+ on Vzbot 235 AWD, Duet 2 wifi on Ox CNC and Mini 5+ on Millennium Milo v1.5 mini mill.
        • Morane_3803undefined
          Morane_3803 @jay_s_uk
          @jay_s_uk
          Hi there, is one of the Canned ERCF boards still available?
          If yes, how could I pay for it? PayPal?
          Thanks a lot. Regards Martin
          • joekoundefined
            joeko
            can i order the Canned ERCF board ?
            Th0mpyundefined 1 Reply Last reply Reply Quote 0
            • Th0mpyundefined
              Th0mpy @joeko
              @joeko Where are you located?
              Usually the team that scores the most points wins the game.
              joekoundefined 1 Reply Last reply Reply Quote 0
              • joekoundefined
                joeko @Th0mpy
                @Th0mpy germany
                Th0mpyundefined 2 Replies Last reply Reply Quote 0
                • Th0mpyundefined
                  Th0mpy @joeko
                  @joeko I have a couple that I had made, but in the US. It would be much less expensive to just order it assembled from PCBWay or similar outfit.
                  • Th0mpyundefined
                    Th0mpy @joeko
                    @joeko That said, let me see if I can publish it on PCBWay and you could just order it assembled from them.
                    • joekoundefined
                      joeko @Th0mpy
                      @Th0mpy ok. but is it also possible to use an Expansion board with can conneted ?
                      • Th0mpyundefined
                        Th0mpy @joeko
                        @joeko I don't see why not. The ERCF board is really just a purpose-built toolboard. The benefit to the expansion board is that it's tried and true hardware, less chance of major issues 🙂 The big obvious difference is the form factor.
                        • joekoundefined
                          joeko @Th0mpy
                          @Th0mpy yes and the price 🙂
                          but until now i am only think about. does this mmu system works without big problems ?
                          oliofundefined Th0mpyundefined 2 Replies Last reply Reply Quote 0
                          • oliofundefined
                            oliof @joeko
                            @joeko define "big problems" -- I know a bunch of people that use ERCF successfully. Requires some extra considerations, but that's to expected if you add multiple different rolls of filament and additional steppers....
                            • Th0mpyundefined
                              Th0mpy @joeko
                              @joeko It CAN work well, but you need to be ready for some failures and tweaking. There are so many things that are out of the control of the device itself so you need to be prepared for that. It's not for the faint of heart.
                              • joekoundefined
                                joeko
                                i have ordered one and will use it with an expansion board.
                                i will see 🙂
                                • o_lampeundefined
                                  o_lampe
                                  I've spent some time dreaming of multi-colour FDM printing. But the filament colours available are good for toys, but not much else.
                                  And colour mixing doesn't work as expected.
                                  I discovered resin printers recently. They produce a whole army of spectacular fine detailed figurines in no time and handpainting them comes closer to my expectations.
                                  • Th0mpyundefined
                                    Th0mpy @o_lampe
                                    @o_lampe I tend to agree, however, I do like to add inlayed pieces to my parts. Most of what I do is more functional parts versus toys, so I like to add indicators, logos, etc.
                                    The biggest reason for me is to use soluble supports. Understood that resin printers do supports better, but I really couldn't get over the cleanup and smell. I may try it again when I can move the operation to my new shop.
                                    • sebkritikelundefined sebkritikel referenced this topic
