    Canned ERCF board v1.0-beta2
    My Duet controlled machine
    9
    24
    2.5k
    • R4ffersundefined
      R4ffers @jay_s_uk
      @jay_s_uk Hi, do you still have any canned ercf left?
      Mb6hc + 3hc + 1lc on Voron V2.4, Mini 5+ exp 2+ on Vzbot 235 AWD, Duet 2 wifi on Ox CNC and Mini 5+ on Millennium Milo v1.5 mini mill.
        jay_s_uk @R4ffers
        @R4ffers I do
        R4ffersundefined 1 Reply Last reply Reply Quote 1
        • R4ffersundefined
          R4ffers @jay_s_uk
          @jay_s_uk woohoo lol, It seems that I may have a Sammy on the way.
          Could I buy a board from you please?
          • Morane_3803undefined
            Morane_3803 @jay_s_uk
            @jay_s_uk
            Hi there, is one of the Canned ERCF boards still available?
            If yes, how could I pay for it? PayPal?
            Thanks a lot. Regards Martin
            • joekoundefined
              joeko
              can i order the Canned ERCF board ?
              Th0mpyundefined 1 Reply Last reply Reply Quote 0
              • Th0mpyundefined
                Th0mpy @joeko
                @joeko Where are you located?
                Usually the team that scores the most points wins the game.
                joekoundefined 1 Reply Last reply Reply Quote 0
                • joekoundefined
                  joeko @Th0mpy
                  @Th0mpy germany
                  Th0mpyundefined 2 Replies Last reply Reply Quote 0
                  • Th0mpyundefined
                    Th0mpy @joeko
                    @joeko I have a couple that I had made, but in the US. It would be much less expensive to just order it assembled from PCBWay or similar outfit.
                    • Th0mpyundefined
                      Th0mpy @joeko
                      @joeko That said, let me see if I can publish it on PCBWay and you could just order it assembled from them.
                      • joekoundefined
                        joeko @Th0mpy
                        @Th0mpy ok. but is it also possible to use an Expansion board with can conneted ?
                        • Th0mpyundefined
                          Th0mpy @joeko
                          @joeko I don't see why not. The ERCF board is really just a purpose-built toolboard. The benefit to the expansion board is that it's tried and true hardware, less chance of major issues 🙂 The big obvious difference is the form factor.
                          • joekoundefined
                            joeko @Th0mpy
                            @Th0mpy yes and the price 🙂
                            but until now i am only think about. does this mmu system works without big problems ?
                            oliofundefined Th0mpyundefined 2 Replies Last reply Reply Quote 0
                            • oliofundefined
                              oliof @joeko
                              @joeko define "big problems" -- I know a bunch of people that use ERCF successfully. Requires some extra considerations, but that's to expected if you add multiple different rolls of filament and additional steppers....
                              • Th0mpyundefined
                                Th0mpy @joeko
                                @joeko It CAN work well, but you need to be ready for some failures and tweaking. There are so many things that are out of the control of the device itself so you need to be prepared for that. It's not for the faint of heart.
                                • joekoundefined
                                  joeko
                                  i have ordered one and will use it with an expansion board.
                                  i will see 🙂
                                  • o_lampeundefined
                                    o_lampe
                                    I've spent some time dreaming of multi-colour FDM printing. But the filament colours available are good for toys, but not much else.
                                    And colour mixing doesn't work as expected.
                                    I discovered resin printers recently. They produce a whole army of spectacular fine detailed figurines in no time and handpainting them comes closer to my expectations.
                                    • Th0mpyundefined
                                      Th0mpy @o_lampe
                                      @o_lampe I tend to agree, however, I do like to add inlayed pieces to my parts. Most of what I do is more functional parts versus toys, so I like to add indicators, logos, etc.
                                      The biggest reason for me is to use soluble supports. Understood that resin printers do supports better, but I really couldn't get over the cleanup and smell. I may try it again when I can move the operation to my new shop.
                                      • sebkritikelundefined sebkritikel referenced this topic
