Duet Wifi - Accel
@dc42 I upload the RRF 3.4.5 and I had to update all the parameter that are changed, but I try to install the input shaping plug in without success. I follow this:
But return the DWC return me this message:
So I try to upload in System -> Upload System Files and do somethings but I can't se the plugin in the GUI.Some help?
Thanks!
Are you uploading a single zip file or has the zip file been extracted first?
It must be a single zip file.
@Phaedrux I'm not sure plugins can be uploaded using the upload and start button in DWC so I think the wiki is incorrect
@jay_s_uk Yes, installing plugins via "Upload&Start" is supported so the documentation is correct.
@samu_87 Please make sure you are actually using DWC 3.4.5, the error notification looks like it is from an older DWC build. If you are sure that you installed it, try to force-refresh DWC via Ctrl+Shift+R or clear your browser cache.
@chrishamm I install this:
Where I can control if the DWC is correct?
I have a lot of problem to migrate to RRF2 to RRF3 maybe is better that I delete all and make a clean and fresh installation? If yes how?
Thanks!
@Phaedrux I upload the exact file that I download...
@samu_87 Yes, that's the firmware but not the web interface. Just upload Duet2and3Firmware-3.4.5.zip without unpacking it first, then the web interface is updated as well.
@chrishamm Many thanks!!! now I see the plugins!
Can some one help me to adapt my config.g because cannot make the home correctly and if some one can help me to update the parameter. Thanks
homedelta.g
Here the big difference, the homing sometimes don't work well and return me the message "Position can't be reach"...
I have traditional optical end stop and I have the piezo probe.
@samu_87 your M574 endstop settings should be X2, Y2 and Z2, for max end endstops. I assume this machine is a delta?
@droftarts Thank you so much!!! The problem was there, now I'm going to setup fans and heaters OMG
This post is deleted! -
Hi, I think I configure Bed and Hotend well but the printer can't extrude:
Some help? Thanks!
Your tool definition is missing an extruder drive assignment.
You must add
D0
like this to your tool definition.M563 P1 S"tool1" H1 F0 D0
This assigns the first extruder drive to the tool.
It would be easiest if you copy and pasted the text of your config.g here so we can see the whole thing at once.
You can also send M98 P"config.g" in the gcode console and you may catch some error messages.
@Phaedrux Thanks! I Add M98:
I don't understand why drive 0 is not ok.
If I add D0 at M563 the tool 1 disappear... -
Please copy and paste the text of your config.g here so we can see it all?
@Phaedrux Yes!
; Configuration file for Duet WiFi (firmware version 1.21) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v2 on Mon Mar 25 2019 12:03:15 GMT+0100 (CET) M98 ; General preferences G90 ; Send absolute coordinates... M83 ; ...but relative extruder moves M665 R280.8 L515 B200 H572.95 X0.0 Y0.0 Z0.0 ; Set delta radius, diagonal rod length, printable radius and homed height M666 X0.0 Y0.0 Z0.0 A0 B0 ; Put your endstop adjustments here, or let auto calibration find them ; Network M550 P"Delta" ; Set machine name M551 P"KKKKKK" ; Set password M552 S1 ; Enable network M587 S"YYYYYYY" P"XXXXXX" I192.168.1.230 J192.168.1.1 K255.255.255.0 ; Configure access point and IP addresses. You can delete this line once connected M586 P0 S1 ; Enable HTTP M586 P1 S0 ; Disable FTP M586 P2 S0 ; Disable Telnet ; Drives M569 P0 S1 ; Drive 0 goes forwards M569 P1 S1 ; Drive 1 goes forwards M569 P2 S1 ; Drive 2 goes forwards M569 P3 S1 ; Drive 3 goes forwards M350 X16 Y16 Z16 E16 I1 ; Configure microstepping without interpolation M92 X200.00 Y200.00 Z200.00 E432 ; Set steps per mm M566 X600 Y600 Z2800 E6000.00 P1 ; Set maximum instantaneous speed changes (mm/min) M203 X18000.00 Y18000.00 Z18000.00 E900.00 ; Set maximum speeds (mm/min) M201 X3000.00 Y3000.00 Z3000.00 E5000.00 ; Set accelerations (mm/s^2) M906 X1600.00 Y1600.00 Z1600.00 E1000.00 I30 ; Set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 Z0 S1 ; Set minimum Z ; Endstops M574 X2 P"xstop" S1 M574 Y2 P"ystop" S1 M574 Z2 P"zstop" S1 ; Z-Probe M558 P1 C"!zprobe.in" R0.4 F240 H10 T3600 G31 X0 Y0 Z-0.1 P540 M557 R190 S20 ; Define mesh grid ; Heaters M308 S0 P"e1temp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin e1temp M950 H0 C"e1heat" T0 ; create bed heater output on e1heat and map it to sensor 0 M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"spi.cs1" Y"rtd-max31865" ; configure sensor 1 as PT100 on pin spi.cs1 M950 H1 C"bedheat" T1 ; create nozzle heater output on bedheat and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S280 ; set temperature limit for heater 1 to 280C ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off ;CPU Fan - NOT WORKING M912 P0 S3 ;Calibration CPU Temperature M950 F2 C"fan2" Q500 M106 P2 T25:65 H100:101:102 L130 ;Cooling board ; Tools ;M563 P1 S"tool1" H1 F0 ; define tool 1 M563 P1 S"tool1" H1 F0 D0 G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C M204 P1800 M579 X1.004 Y1.01 ;M591 D0 P1 C"e1stop" S1 ;Sensore di Fine_Filo M572 D0 S0.05 ;M955 P0 C"spi.cs4+spi.cs3" ;Accelerometer M501 ; Automatic saving after power loss is not enabled ; Custom settings are not configured
@samu_87 said in Duet Wifi - Accel:
M98
You have a random M98 at the start on your config. That's one of the errors so remove that.
M587 S"" P"" I192.168.1.230 J192.168.1.1 K255.255.255.0
Remove this from config.g it only needs to be sent once.
You're missing an M584 command to bind the drives to axis.
AddM584 X0 Y1 Z2 E3
after the M569 commands, but you must verify that that mapping is correct as I do not know which driver you have your motors plugged into.; Drives M569 P0 S1 ; Drive 0 goes forwards M569 P1 S1 ; Drive 1 goes forwards M569 P2 S1 ; Drive 2 goes forwards M569 P3 S1 ; Drive 3 goes forwards M350 X16 Y16 Z16 E16 I1 ; Configure microstepping without interpolation M92 X200.00 Y200.00 Z200.00 E432 ; Set steps per mm M566 X600 Y600 Z2800 E6000.00 P1 ; Set maximum instantaneous speed changes (mm/min) M203 X18000.00 Y18000.00 Z18000.00 E900.00 ; Set maximum speeds (mm/min) M201 X3000.00 Y3000.00 Z3000.00 E5000.00 ; Set accelerations (mm/s^2) M906 X1600.00 Y1600.00 Z1600.00 E1000.00 I30 ; Set motor currents (mA) and motor idle factor in per cent M84 S30
There's a problem with your cpu fan command as well.
H100:101:102
is no longer valid. You can see how it's done now in RRF3 here: https://docs.duet3d.com/en/User_manual/Connecting_hardware/Temperature_configuring_mcu_tempThat's a good start. Make those corrections and send M98 P"config.g" again and then share the results of that and your updated config.g.
@Phaedrux Many Thanks!
Now the Fan works but the extrude button is not enabled:; Configuration file for Duet WiFi (firmware version 1.21) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v2 on Mon Mar 25 2019 12:03:15 GMT+0100 (CET) ; General preferences G90 ; Send absolute coordinates... M83 ; ...but relative extruder moves M665 R280.8 L515 B200 H572.95 X0.0 Y0.0 Z0.0 ; Set delta radius, diagonal rod length, printable radius and homed height M666 X0.0 Y0.0 Z0.0 A0 B0 ; Put your endstop adjustments here, or let auto calibration find them ; Network M550 P"Delta" ; Set machine name M551 P"samufree" ; Set password M552 S1 ; Enable network M586 P0 S1 ; Enable HTTP M586 P1 S0 ; Disable FTP M586 P2 S0 ; Disable Telnet ; Drives M569 P0 S1 ; Drive 0 goes forwards M569 P1 S1 ; Drive 1 goes forwards M569 P2 S1 ; Drive 2 goes forwards M569 P3 S1 ; Drive 3 goes forwards M584 X0 Y1 Z2 E3 M350 X16 Y16 Z16 E16 I1 ; Configure microstepping without interpolation M92 X200.00 Y200.00 Z200.00 E432 ; Set steps per mm M566 X600 Y600 Z2800 E6000.00 P1 ; Set maximum instantaneous speed changes (mm/min) M203 X18000.00 Y18000.00 Z18000.00 E900.00 ; Set maximum speeds (mm/min) M201 X3000.00 Y3000.00 Z3000.00 E5000.00 ; Set accelerations (mm/s^2) M906 X1600.00 Y1600.00 Z1600.00 E1000.00 I30 ; Set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 Z0 S1 ; Set minimum Z ; Endstops M574 X2 P"xstop" S1 M574 Y2 P"ystop" S1 M574 Z2 P"zstop" S1 ; Z-Probe M558 P1 C"!zprobe.in" R0.4 F240 H10 T3600 G31 X0 Y0 Z-0.1 P540 M557 R190 S20 ; Define mesh grid ; Heaters M308 S0 P"e1temp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin e1temp M950 H0 C"e1heat" T0 ; create bed heater output on e1heat and map it to sensor 0 M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"spi.cs1" Y"rtd-max31865" ; configure sensor 1 as PT100 on pin spi.cs1 M950 H1 C"bedheat" T1 ; create nozzle heater output on bedheat and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S280 ; set temperature limit for heater 1 to 280C ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off ;CPU Fan - NOT WORKING M308 S3 Y"mcu-temp" A"MCU" ; configure sensor 3 as on-chip MCU temperature sensor M950 F2 C"fan2" Q100 ; create fan 2 on pin fan2 and set its frequency M106 P2 H3 T20:70 ; set fan 2 value ; Tools ;M563 P1 S"tool1" H1 F0 ; define tool 1 M563 P1 S"tool1" H1 F0 D0 G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C M204 P1800 M579 X1.004 Y1.01 ;M591 D0 P1 C"e1stop" S1 ;Sensore di Fine_Filo M572 D0 S0.05 ;M955 P0 C"spi.cs4+spi.cs3" ;Accelerometer M501 ; Automatic saving after power loss is not enabled ; Custom settings are not configured
The driver motor are connected like here:
https://docs.duet3d.com/Duet3D_hardware/Duet_2_family/Duet_2_WiFi_Ethernet_Hardware_Overview#pin-namesExtruder stepper in E0 Stepper, but still not work...
Can you send M98 P"config.g" again and share the results please?
You also need to have a tool selected before you can extrude with it, please add
T0
to the end of your config.g so that your tool is selected at startup.The extruder will also not work unless the hotend is at temperature by default unless you have cold extrusion enabled for testing.
