    M671 like function for Delta printer
    Gcode meta commands
    1.3k
    • tecnoundefined
      tecno
      How can I get following to show measured points in Console or saved to CSV file?
      G30 P0 X0 Y0
      G30 P1 X-154 Y-164
      G30 P2 X-63 Y214
      G30 P3 X217 Y-52
      tecnoundefined 1 Reply Last reply Reply Quote 0
      • tecnoundefined
        tecno @tecno
        This gives measurements in console, so far so good.
        How to make calc so points 2/3/4 are compared to point 1 and answer in turns with 0.5 pitch.
        M562                    ; clear any bed transform from mesh leveling
        G90                     ; absolute positioning
        G1 Z50 F4000
        G1 X0 Y0				; 1 point
        G30 S-1
        G1 Z50 F4000
        G1 X-154 Y-164 F4000    ; 2 point
        G30 S-1
        G1 Z50 F4000
        G1 X-63 Y214 F4000      ; 3 point
        G30 S-1
        G1 Z50 F4000
        G1 X217 Y-52 F4000      ; 4 point
        G30 S-1
        G1 Z50 F4000
        G28
        • tecnoundefined
          tecno @tecno
          Manual says:
          The console output can be cleared, or downloaded as a plain text or CSV file, from the drop down menu on the right.
          Where do these files be saved?
          • o_lampeundefined
            o_lampe
            I think, the delta calibration routine already has such bed tramming. But it adjusts the endstops instead.
            Look in your config-override.g and find the endstop adjustment values. just have to recalculate these values for a 0.5mm pitch.
            I hope, I'm right and I understood your intentions correctly.
              dc42 administrators @tecno
              @tecno after G30 S-1 object model variable sensors.probes[0].lastStopHeight will be set. You could save those values in local variables, then write them to file use an echo command with redirection.
              • tecnoundefined
                tecno @dc42
                @dc42 said in M671 like function for Delta printer:
                It is here it goes over my head, where are the files saved Download as
                  droftarts administrators @tecno
                  @tecno They are saved to whatever place your browser sets for downloads. I usually have my browser set to ask me where to download stuff (you can change this in your browser's preferences/settings). You can also usually look in the Downloads history to see where it has saved it, if it downloads automatically without asking. Probably your 'Downloads' folder.
                  • tecnoundefined
                    tecno @droftarts
                    @droftarts
                    Hi Ian,
                    I thougt so too but nothing is downloaded to my Downloads 😞
                    droftartsundefined tecnoundefined 2 Replies Last reply Reply Quote 0
                      @tecno Strange. I downloaded to my desktop, appeared fine:
                      • tecnoundefined
                        tecno @tecno
                        Just tested to see if my Ubuntu woks with this = Nothing
                        Tested with another W10 = Nothing
                        • tecnoundefined
                          tecno @droftarts
                          @droftarts
                          2023-02-03 12:50:21 Echo "Hi Ian"
                          Error: Bad command: Echo "Hi Ian"
                            @tecno lower case 'e' in "echo". However, that doesn't explain why your browser isn't saving the console.txt. What version DWC and RRF?
                            • tecnoundefined
                              tecno @droftarts
                              @droftarts
                              🙂 did notice that with echo
                              Duet Web Control 3.4.5
                              Board: Duet 3 Mini 5+ (Mini5plus)
                              Firmware: RepRapFirmware for Duet 3 Mini 5+ 3.4.5 (2022-11-30)
                              • tecnoundefined
                                tecno @tecno
                                Tested with 3 browser = nothing
                                  T3P3Tony administrators @tecno
                                  @tecno your browsers may be set to block downloads? not sure why but i just tested this as well and it works with Chrome on windows.
                                  • tecnoundefined
                                    tecno @T3P3Tony
                                    @T3P3Tony
                                    No problems here with dowload, just tested to dowload stl file from thingiverse.
                                    Can this be a languae problem, my OS is in Swedish.
                                    • tecnoundefined
                                      tecno @tecno
                                      Any ideas what is causing this problem??
                                      OwenDundefined 1 Reply Last reply Reply Quote 0
                                      • OwenDundefined
                                        OwenD @tecno
                                        @tecno
                                        Exactly what steps are you taking?
                                        If you're trying to use echo then you have to use the correct syntax to write to a file.
                                        https://docs.duet3d.com/User_manual/Reference/Gcode_meta_commands
                                        If you're trying to save the console then click on the icon with the horizontal lines and select download as text or csv
                                        The file will be saved wherever your browser normally saves files.
                                        If it doesn't then there is something blocking it. Either browser settings or anti virus perhaps.
                                        • tecnoundefined
                                          tecno @OwenD
                                          @OwenD said in M671 like function for Delta printer:
                                          I have no problems dowloading files.
                                          I can run backups with ```
                                          c:/backup/rfm backup -domain bigdelta -password ******** c:/backup/bigdelta 0:/
                                          • tecnoundefined
                                            tecno @tecno
                                            Tested M122 on 3 of my printers now and it works OK, a window with where to save pops up so it isOK.
                                            But this I get nowhere
                                            Want to have the output from macro to a CSV. So what is my problem with this?
