    One issue after swapping from smoothieboard
    522
    • mdbergholmundefined
      mdbergholm
      The silence is incredible, but I am running into a strange issue that I am a bit perplexed with. I ran PID tuning for both hotend and bed, but still getting a strange defect where the first 25 layers or so are printing slower? or hotter? than the rest? They seem to have more shine and shrink slightly more indicating more heat. I have tried creating a brand new profile using Cura and Prusaslicer and to my surprise got the same result.
      The hardware is basically a Prusa MK2.5 with all extruded aluminum, and Duet 3 Mini 5x
      Duet Web Control 3.4.5
      RRF 3.4.0
      Duet Wifi Server 1.26
      THEPRINT
      OwenDundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
      • OwenDundefined
        OwenD @mdbergholm
        @mdbergholm
        If you lower your bed temperature, does the transition point get lower?
        mdbergholmundefined 2 Replies Last reply Reply Quote 0
          mdbergholm @OwenD
          @OwenD Sorry I meant to also post that I lowered my bed temps to 40c (from 70c) because any lower it wouldnt stick to the bed at all. When doing this i seemed to get quite similar results
            mdbergholm @OwenD
            @OwenD I count about 25 layers on both 70c bed and 40c bed. That was my first thought was the bed was too hot. I updated my initial post with details on printer and software. Seems like a simple issue TBH just strange.
            mdbergholmundefined 1 Reply Last reply Reply Quote 0
              mdbergholm @mdbergholm
              @mdbergholm
              Here is my config.g
              ; ##### General preferences
              G90                                          						; send absolute coordinates...
              M83                                          						; ...but relative extruder moves
              M550 P"Rob"                          								; set printer name
              ; ##### Network
              M552 S1                                      						; enable network
              M586 P0 S1                                   						; enable HTTP
              M586 P1 S0                                  						; disable FTP
              M586 P2 S0                                   						; disable Telnet
              ; ##### 12864 Menu
              M918 P2 E-4
              ; ##### Drives
              M569 P1 S0 D3 V10                                					; X drive @1
              M569 P2 S1 D3 V10                                					; Y drive @2
              M569 P0 S1 D3 V100                               					; Z left drive @0
              M569 P4 S0 D3 V100                               					; Z right drive  @4
              M569 P3 S0 D3 V0                                					; E drive @3 - inversed
              M584 X1 Y2 Z0:4 E3                     								; set drive mapping
              M671 X-37:287 Y0:0 S10                                     			; define dual driven z-axis
              M92 X160.80 Y159.60 Z388.16 E140.00             					; set steps per mm
              M350 X256 Y256 Z256 E256 I1                      					; configure microstepping with interpolation
              M566 X600.00 Y600.00 Z48.00 E300.00        							; set maximum instantaneous speed changes (mm/min)
              M203 X8000.00 Y8000.00 Z720.00 E7200.00      						; set maximum speeds (mm/min)
              M201 X1250.00 Y1250.00 Z1250.00 E2000.00        					; set accelerations (mm/s^2)
              M906 X1000 Y1000 Z1000 E1200 I30                					; set motor currents (mA) and motor idle factor in per cent
              M84 S30                                      						; Set idle timeout
              ; ##### Axis Limits
              M208 X0 Y-4 Z0 S1                             						; set axis minima
              M208 X255 Y212.5 Z215 S0                       						; set axis maxima
              ; ##### Endstops
              M574 X1 S1 P"io0.in"                        						; X endstop
              M574 Y1 S1 P"io1.in"                        						; Y endstop
              ; ##### Z-Probe Settings for PINDA 2
              M558 P5 C"io2.in" I1 H1 F1000 T6000 A3              				; Prusa PindaV2 Endstop
              M574 Z1 S2                                                 			; Set Z axis endstop, controlled by probe
              M557 X0:220 Y0:205 P5                                    			; Define mesh grid for probing
              M376 H5																; Fade height 5mm
              ; ##### Heaters
              ; Bed Heater
              M308 S0 P"temp0" Y"thermistor" B4725 C7.060000e-8 					; configure sensor 0 as thermistor on pin temp1
              M950 H0 C"out0" Q25 T0                           					; create bed heater output on out0 and map it to sensor 0, PWM frequency: 25Hz
              M307 H0 R0.262 C338.0 D10.52 S1.00 V11.8 B0							; Bed tuning values, enable PID
              M140 H0                                                    			; Bed uses Heater 0
              M143 H0 S120                                               			; Set temperature limit for heater 0 to 120C Bed
              ; Hotend heater
              M308 S1 P"temp2" Y"thermistor" T100000 B4092 ; configure sensor 1 as thermistor on pin temp1
              M950 H1 C"out2" T1                           ; create nozzle heater output on out1 and map it to sensor 1
              M307 H1 B0 S1.00                             ; disable bang-bang mode for heater  and set PWM limit
              M143 H1 S275                                 ; set temperature limit for heater 1 to 275C
              ; ##### Fans
              ; Part cooling fan
              M950 F0 C"out3" Q100                         						; create fan 0 on pin out3 and set its frequency
              M106 P0 S0 H-1                               						; set fan 0 value. Thermostatic control is turned off
              ; ##### Tools
              M563 P0 D0 H1 F0                             						; define tool 0
              G10 P0 X0 Y0 Z0                              						; set tool 0 axis offsets
              G10 P0 R0 S0                                 						; set initial tool 0 active and standby temperatures to 0C
              M572 D0 S0.06								 						; Pressure Advance
              ; ##### Startup
              M18 XYE                                                				; release / unlock X, Y, and E axis
              M501                                                   				; use config-override (for Thermistor Parameters and other settings)
              M83                                                   				; ... but relative extruder moves
              OwenDundefined 1 Reply Last reply Reply Quote 0
              • OwenDundefined
                OwenD @mdbergholm
                @mdbergholm
                My next thought would be reflected air off bed from part fan.
                What happens if you lower the fan speed?
                Presumably this didn't happen with same hardware on smoothieware?
                  mdbergholm @OwenD
                  @OwenD Yes - no issue with same hardware/print profiles using smoothieboard. I am currently printing a vase mode print to see if i notice a difference there. After that I will try the other part again using 0 fan. With the prints you saw I am using only 15% fan speed.
                    mdbergholm @OwenD
                    @OwenD So on the left is 15% fan, on the right is 0% fan. The appear the same to me besides the lack of cooling causing some curling on the right side corners...and my bed offset....
                    and as for vase mode... Its hard to say I could have picked a better model to do this... but i think i see it there too.
                      @mdbergholm and for anyone looking at this here is just a point of reference. My machine is basically the "Prusa Bear" upgrade frame with moons motors, and duet 3 electronics. Nothing out of the ordinary here. No crazy cooling or heating. All 12v.
                      gloomyandyundefined 1 Reply Last reply Reply Quote 0
                      • gloomyandyundefined
                        gloomyandy @mdbergholm
                        @mdbergholm Are you using mesh bed levelling? Do you have a fade height set?
                        • mendenmhundefined
                          mendenmh
                          Do you have adaptive layer heights turned on in your slicer? If there is a transition 25 layers up in the design, the printing characteristics may change there, due to speed and layer height changes.
                          • sebkritikelundefined
                            sebkritikel
                            I'd be curious to see a sample GCODE file - I'd be looking for settings dealing with different print speeds for the first 'x' layers, as well as the layer in which the part cooling fan (If used) is fully on (or a permutation - fan speed could slowly lamp up, with full speed being reached at that texture transition, or it might not turn on until that layer).
                            Large(ish?) IDEX - 6HC, 1HCL
                            Stratasys Dimension 1200es to 6HC Conversion
                              Phaedrux Moderator @mdbergholm
                              @mdbergholm said in One issue after swapping from smoothieboard:
                              RRF 3.4.0
                              Probably won't help your issue, but update your firmware. You're a bit all over the place. Upload this zip file to the system tab.
                              https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.5/Duet2and3Firmware-3.4.5.zip
                                mdbergholm @gloomyandy
                                @gloomyandy I am using mesh leveling with the inductive probe. I have not however set a fade height. Didn't know that was a thing. Will read up on it.
                                I do not have adaptive layers turned on. I am printing at 200um the whole time. The issue will happen on any part not just that one I've been printing could be a plain block. I have also printed this part on other machines without the issue showing up.
                                I can post up a sample of the gcode if it would be helpful. And I can def update all my firmware this is just how it arrived. I probably should get it all updated anyways.
                                ;FLAVOR:RepRap
                                ;TIME:10119
                                ;Filament used: 7.59597m
                                ;Layer height: 0.2
                                ;MINX:97.941
                                ;MINY:83.064
                                ;MINZ:0.24
                                ;MAXX:152.06
                                ;MAXY:132.639
                                ;MAXZ:49.64
                                ;Exported with Cura-DuetRRF v1.2.9 plugin by Thomas Kriechbaumer
                                ;Generated with Cura_SteamEngine 5.2.2
                                T0
                                M190 S70
                                M104 S250
                                M109 S250
                                M82 ;absolute extrusion mode
                                G28 ; home all
                                G29 S1 ; load mesh offset map
                                G92 Z0.3 ; z-offset
                                G1 X1 Y1 Z0.45 F10000 ; move to prime position
                                G92 E0 ; zero extruder
                                G1 X125 Y1 E20 F1000 ; prime nozzle
                                M83 ;relative extrusion mode
                                G1 F2400 E-0.55
                                ;LAYER_COUNT:249
                                ;LAYER:0
                                M107
                                G1 F720 Z0.44
                                G0 F9600 X99.382 Y89.896 Z0.44
                                ;TYPE:SKIRT
                                G1 F720 Z0.24
                                G1 F2400 E0.55416
                                G1 F900 X99.857 Y89.436 E0.02633
                                G1 X100.383 Y89.036 E0.02631
                                G1 X100.955 Y88.703 E0.02635
                                G1 X101.562 Y88.441 E0.02632
                                G1 X102.196 Y88.255 E0.0263
                                G1 X102.848 Y88.146 E0.02632
                                G1 X103.74 Y88.107 E0.03555
                                G1 X143.536 Y88.109 E1.58437
                                G1 X144.24 Y88.119 E0.02803
                                G1 X145.157 Y88.19 E0.03662
                                G1 X146.221 Y88.431 E0.04343
                                G1 X146.763 Y88.603 E0.02264
                                G1 X147.38 Y88.841 E0.02633
                                G1 X148.187 Y89.296 E0.03688
                                G1 X148.739 Y89.672 E0.02659
                                G1 X149.381 Y90.169 E0.03232
                                G1 X149.983 Y90.801 E0.03475
                                G1 X150.493 Y91.405 E0.03147
                                G1 X150.991 Y92.202 E0.03742
                                G1 X151.306 Y92.783 E0.02631
                                G1 X151.606 Y93.582 E0.03398
                                G1 X151.788 Y94.213 E0.02615
                                G1 X151.984 Y95.138 E0.03764
                                G1 X152.049 Y95.992 E0.0341
                                G1 X152.06 Y96.725 E0.02919
                                G1 X152.059 Y123.918 E1.08262
                                G1 X152.048 Y124.709 E0.03149
                                G1 X151.998 Y125.49 E0.03116
                                G1 X151.819 Y126.434 E0.03825
                                G1 X151.685 Y126.936 E0.02069
                                G1 X151.476 Y127.563 E0.02631
                                G1 X151.268 Y128.019 E0.01995
                                G1 X150.978 Y128.585 E0.02532
                                G1 X150.642 Y129.154 E0.02631
                                G1 X150.081 Y129.852 E0.03565
                                G1 X149.651 Y130.306 E0.0249
                                G1 X149.079 Y130.843 E0.03124
                                G1 X148.268 Y131.409 E0.03937
                                G1 X147.704 Y131.754 E0.02632
                                G1 X146.846 Y132.121 E0.03715
                                G1 X146.071 Y132.358 E0.03227
                                G1 X145.298 Y132.533 E0.03155
                                G1 X144.371 Y132.619 E0.03706
                                G1 X143.255 Y132.639 E0.04444
                                G1 X104.04 Y132.639 E1.56124
                                G1 X103.342 Y132.629 E0.02779
                                G1 X102.682 Y132.58 E0.02635
                                G1 X102.034 Y132.451 E0.0263
                                G1 X101.405 Y132.245 E0.02635
                                G1 X100.806 Y131.965 E0.02632
                                G1 X100.246 Y131.615 E0.02629
                                G1 X99.731 Y131.199 E0.02636
                                G1 X99.271 Y130.725 E0.0263
                                G1 X98.871 Y130.198 E0.02634
                                G1 X98.538 Y129.627 E0.02632
                                G1 X98.276 Y129.02 E0.02632
                                G1 X98.089 Y128.386 E0.02632
                                G1 X97.98 Y127.733 E0.02636
                                G1 X97.941 Y126.847 E0.03531
                                G1 X97.941 Y116.157 E0.42559
                                G1 X97.958 Y114.913 E0.04953
                                G1 X98.01 Y113.09 E0.07261
                                G1 X98.01 Y110.448 E0.10518
                                G1 X97.992 Y109.928 E0.02071
                                G1 X97.997 Y109.738 E0.00757
                                G1 X97.941 Y106.89 E0.11341
                                G1 X97.941 Y94.189 E0.50566
                                G1 X97.951 Y93.506 E0.02719
                                G1 X98 Y92.847 E0.02631
                                G1 X98.129 Y92.198 E0.02634
                                G1 X98.335 Y91.57 E0.02631
                                G1 X98.616 Y90.971 E0.02634
                                G1 X98.966 Y90.41 E0.02633
                                G1 X99.382 Y89.896 E0.02633
                                G0 F9600 X99.794 Y90.071
                                G1 F900 X100.264 Y89.643 E0.02531
                                G1 X100.784 Y89.278 E0.02529
                                G1 X101.346 Y88.982 E0.02529
                                G1 X101.941 Y88.758 E0.02531
                                G1 X102.559 Y88.61 E0.0253
                                G1 X103.388 Y88.527 E0.03317
                                G1 X143.53 Y88.529 E1.59815
                                G1 X144.234 Y88.539 E0.02803
                                G1 X145.1 Y88.606 E0.03458
                                G1 X146.094 Y88.832 E0.04058
                                G1 X146.636 Y89.004 E0.02264
                                G1 X147.228 Y89.233 E0.02527
                                G1 X147.951 Y89.643 E0.03309
                                G1 X148.503 Y90.019 E0.02659
                                G1 X149.102 Y90.485 E0.03021
                                G1 X149.679 Y91.091 E0.03331
                                G1 X150.155 Y91.657 E0.02944
                                G1 X150.634 Y92.424 E0.036
                                G1 X150.936 Y92.983 E0.0253
                                G1 X151.202 Y93.698 E0.03037
                                G1 X151.384 Y94.329 E0.02615
                                G1 X151.568 Y95.195 E0.03525
                                G1 X151.629 Y95.998 E0.03206
                                G1 X151.64 Y96.725 E0.02895
                                G1 X151.64 Y123.912 E1.08238
                                G1 X151.629 Y124.703 E0.03149
                                G1 X151.581 Y125.446 E0.02964
                                G1 X151.413 Y126.325 E0.03563
                                G1 X151.279 Y126.827 E0.02069
                                G1 X151.037 Y127.548 E0.03028
                                G1 X150.604 Y128.394 E0.03784
                                G1 X150.28 Y128.94 E0.02528
                                G1 X149.776 Y129.564 E0.03193
                                G1 X149.346 Y130.018 E0.0249
                                G1 X148.803 Y130.524 E0.02955
                                G1 X148.028 Y131.065 E0.03763
                                G1 X147.485 Y131.395 E0.0253
                                G1 X146.651 Y131.749 E0.03607
                                G1 X145.955 Y131.954 E0.02889
                                G1 X145.23 Y132.119 E0.0296
                                G1 X144.364 Y132.199 E0.03462
                                G1 X143.255 Y132.219 E0.04416
                                G1 X104.046 Y132.219 E1.561
                                G1 X103.348 Y132.209 E0.02779
                                G1 X102.714 Y132.16 E0.02532
                                G1 X102.092 Y132.032 E0.02528
                                G1 X101.491 Y131.827 E0.02528
                                G1 X100.92 Y131.548 E0.0253
                                G1 X100.389 Y131.199 E0.0253
                                G1 X99.906 Y130.787 E0.02527
                                G1 X99.478 Y130.317 E0.02531
                                G1 X99.113 Y129.797 E0.02529
                                G1 X98.816 Y129.235 E0.02531
                                G1 X98.592 Y128.641 E0.02527
                                G1 X98.444 Y128.023 E0.0253
                                G1 X98.361 Y127.196 E0.03309
                                G1 X98.36 Y116.163 E0.43925
                                G1 X98.378 Y114.925 E0.04929
                                G1 X98.43 Y113.102 E0.07261
                                G1 X98.43 Y110.434 E0.10622
                                G1 X98.412 Y109.914 E0.02071
                                G1 X98.417 Y109.737 E0.00705
                                G1 X98.36 Y106.783 E0.11763
                                G1 X98.361 Y94.195 E0.50116
                                G1 X98.371 Y93.512 E0.02719
                                G1 X98.42 Y92.879 E0.02528
                                G1 X98.548 Y92.256 E0.02532
                                G1 X98.754 Y91.655 E0.02529
                                G1 X99.033 Y91.085 E0.02527
                                G1 X99.382 Y90.554 E0.0253
                                G1 X99.794 Y90.071 E0.02527
                                G0 F9600 X100.206 Y90.253
                                G1 F900 X100.67 Y89.861 E0.02418
                                G1 X101.182 Y89.533 E0.02421
                                G1 X101.733 Y89.274 E0.02424
                                G1 X102.313 Y89.09 E0.02423
                                G1 X102.912 Y88.984 E0.02422
                                G1 X103.74 Y88.947 E0.033
                                G1 X143.524 Y88.948 E1.5839
                                G1 X144.228 Y88.958 E0.02803
                                G1 X145.043 Y89.021 E0.03254
                                G1 X145.966 Y89.232 E0.03769
                                G1 X146.508 Y89.404 E0.02264
                                G1 X147.075 Y89.626 E0.02424
                                G1 X147.715 Y89.99 E0.02931
                                G1 X148.267 Y90.366 E0.02659
                                G1 X148.825 Y90.803 E0.02822
                                G1 X149.375 Y91.38 E0.03174
                                G1 X149.819 Y91.912 E0.02759
                                G1 X150.278 Y92.647 E0.0345
                                G1 X150.565 Y93.183 E0.02421
                                G1 X150.799 Y93.815 E0.02683
                                G1 X150.981 Y94.446 E0.02615
                                G1 X151.152 Y95.255 E0.03292
                                G1 X151.209 Y96.005 E0.02995
                                G1 X151.22 Y96.725 E0.02867
                                G1 X151.22 Y123.906 E1.08214
                                G1 X151.209 Y124.697 E0.03149
                                G1 X151.133 Y125.554 E0.03425
                                G1 X151.007 Y126.217 E0.02687
                                G1 X150.873 Y126.719 E0.02069
                                G1 X150.643 Y127.397 E0.0285
                                G1 X150.231 Y128.202 E0.036
                                G1 X149.918 Y128.724 E0.02423
                                G1 X149.472 Y129.275 E0.02822
                                G1 X149.042 Y129.729 E0.0249
                                G1 X148.53 Y130.202 E0.02775
                                G1 X147.787 Y130.721 E0.03608
                                G1 X147.267 Y131.035 E0.02418
                                G1 X146.584 Y131.323 E0.02951
                                G1 X145.838 Y131.551 E0.03106
                                G1 X145.161 Y131.705 E0.02764
                                G1 X144.356 Y131.779 E0.03218
                                G1 X143.255 Y131.799 E0.04384
                                G1 X104.052 Y131.8 E1.56076
                                G1 X103.354 Y131.79 E0.02779
                                G1 X102.747 Y131.741 E0.02424
                                G1 X102.153 Y131.613 E0.02419
                                G1 X101.58 Y131.409 E0.02422
                                G1 X101.039 Y131.131 E0.02422
                                G1 X100.539 Y130.784 E0.02423
                                G1 X100.088 Y130.375 E0.02424
                                G1 X99.696 Y129.911 E0.02418
                                G1 X99.367 Y129.399 E0.02423
                                G1 X99.109 Y128.848 E0.02422
                                G1 X98.925 Y128.268 E0.02423
                                G1 X98.818 Y127.67 E0.02419
                                G1 X98.781 Y126.846 E0.03284
                                G1 X98.78 Y116.168 E0.42512
                                G1 X98.796 Y115.005 E0.04631
                                G1 X98.85 Y113.114 E0.07532
                                G1 X98.85 Y110.419 E0.10729
                                G1 X98.832 Y109.899 E0.02071
                                G1 X98.837 Y109.735 E0.00653
                                G1 X98.78 Y106.783 E0.11755
                                G1 X98.78 Y94.201 E0.50092
                                G1 X98.79 Y93.518 E0.02719
                                G1 X98.839 Y92.912 E0.02421
                                G1 X98.967 Y92.317 E0.02423
                                G1 X99.172 Y91.744 E0.02423
                                G1 X99.45 Y91.203 E0.02422
                                G1 X99.797 Y90.704 E0.0242
                                G1 X100.206 Y90.253 E0.02424
                                G0 F9600 X100.616 Y90.446
                                G1 F900 X101.074 Y90.09 E0.02309
                                G1 X101.577 Y89.801 E0.0231
                                G1 X102.115 Y89.583 E0.02311
                                G1 X102.677 Y89.442 E0.02307
                                G1 X103.41 Y89.367 E0.02933
                                G1 X143.518 Y89.368 E1.5968
                                G1 X144.222 Y89.378 E0.02803
                                G1 X144.983 Y89.437 E0.03039
                                G1 X145.839 Y89.632 E0.03495
                                G1 X146.381 Y89.804 E0.02264
                                G1 X146.921 Y90.017 E0.02311
                                G1 X147.478 Y90.338 E0.02559
                                G1 X148.03 Y90.714 E0.02659
                                G1 X148.547 Y91.12 E0.02617
                                G1 X149.071 Y91.67 E0.03024
                                G1 X149.595 Y92.345 E0.03402
                                G1 X149.922 Y92.869 E0.02459
                                G1 X150.194 Y93.381 E0.02308
                                G1 X150.395 Y93.931 E0.02331
                                G1 X150.577 Y94.562 E0.02615
                                G1 X150.735 Y95.308 E0.03036
                                G1 X150.79 Y96.011 E0.02807
                                G1 X150.8 Y96.66 E0.02584
                                G1 X150.8 Y123.901 E1.08453
                                G1 X150.789 Y124.692 E0.03149
                                G1 X150.716 Y125.506 E0.03254
                                G1 X150.602 Y126.109 E0.02443
                                G1 X150.468 Y126.611 E0.02069
                                G1 X150.254 Y127.237 E0.02634
                                G1 X149.857 Y128.011 E0.03463
                                G1 X149.557 Y128.507 E0.02308
                                G1 X149.167 Y128.986 E0.02459
                                G1 X148.737 Y129.44 E0.0249
                                G1 X148.091 Y129.996 E0.03393
                                G1 X147.547 Y130.376 E0.02642
                                G1 X147.05 Y130.675 E0.02309
                                G1 X146.452 Y130.924 E0.02579
                                G1 X145.722 Y131.147 E0.03039
                                G1 X144.963 Y131.302 E0.03084
                                G1 X144.348 Y131.359 E0.02459
                                G1 X143.255 Y131.379 E0.04352
                                G1 X104.058 Y131.38 E1.56053
                                G1 X103.36 Y131.37 E0.02779
                                G1 X102.782 Y131.321 E0.02309
                                G1 X102.216 Y131.194 E0.02309
                                G1 X101.673 Y130.99 E0.02309
                                G1 X101.163 Y130.714 E0.02309
                                G1 X100.696 Y130.37 E0.02309
                                G1 X100.281 Y129.965 E0.02309
                                G1 X99.925 Y129.507 E0.02309
                                G1 X99.635 Y129.004 E0.02312
                                G1 X99.418 Y128.467 E0.02306
                                G1 X99.276 Y127.904 E0.02312
                                G1 X99.201 Y127.174 E0.02922
                                G1 X99.2 Y116.174 E0.43794
                                G1 X99.216 Y115.011 E0.04631
                                G1 X99.27 Y113.126 E0.07508
                                G1 X99.27 Y110.405 E0.10833
                                G1 X99.252 Y109.885 E0.02071
                                G1 X99.257 Y109.728 E0.00625
                                G1 X99.2 Y106.783 E0.11727
                                G1 X99.2 Y94.207 E0.50068
                                G1 X99.21 Y93.524 E0.02719
                                G1 X99.259 Y92.946 E0.02309
                                G1 X99.386 Y92.381 E0.02306
                                G1 X99.59 Y91.838 E0.02309
                                G1 X99.867 Y91.328 E0.02311
                                G1 X100.211 Y90.861 E0.02309
                                G1 X100.616 Y90.446 E0.02309
                                G1 F2400 E-0.55
                                G1 F720 Z0.44
                                ;MESH:bucket_sign.stl
                                G0 F9600 X120.491 Y99.045 Z0.44
                                ;TYPE:WALL-INNER
                                G1 F720 Z0.24
                                G1 F2400 E0.55416
                                G1 F900 X120.317 Y98.844 E0.01058
                                G1 X120.208 Y98.635 E0.00938
                                G1 X120.15 Y98.407 E0.00937
                                G1 X120.137 Y97.68 E0.02895
                                G1 X120.263 Y97.341 E0.0144
                                G1 X120.466 Y97.075 E0.01332
                                G1 X120.786 Y96.866 E0.01522
                                G1 X121.059 Y96.786 E0.01133
                                G1 X145.54 Y96.785 E0.97465
                                G1 X145.54 Y96.149 E0.02532
                                G1 X145.4 Y95.543 E0.02476
                                G1 X145.192 Y95.21 E0.01563
                                G1 X144.986 Y94.992 E0.01194
                                G1 X144.666 Y94.766 E0.0156
                                G1 X144.088 Y94.629 E0.02365
                                G1 X104.461 Y94.628 E1.57765
                                G1 X104.461 Y106.759 E0.48296
                                G1 X137.872 Y107.845 E1.33087
                                G1 X138.487 Y107.979 E0.02506
                                G1 X139.026 Y108.256 E0.02413
                                G1 X139.439 Y108.648 E0.02267
                                G1 X139.728 Y109.062 E0.0201
                                G1 X139.848 Y109.338 E0.01198
                                G1 X140.02 Y109.983 E0.02658
                                G1 X140.02 Y116.25 E0.2495
                                G1 X139.884 Y116.965 E0.02898
                                G1 X139.599 Y117.493 E0.02389
                                G1 X139.189 Y117.96 E0.02474
                                G1 X138.619 Y118.334 E0.02714
                                G1 X137.889 Y118.509 E0.02989
                                G1 X131.796 Y118.509 E0.24258
                                G1 X131.104 Y118.379 E0.02803
                                G1 X130.562 Y118.018 E0.02593
                                G1 X130.402 Y117.841 E0.0095
                                G1 X130.149 Y117.441 E0.01884
                                G1 X104.46 Y116.609 E1.02328
                                G1 X104.46 Y126.12 E0.37866
                                G1 X144.123 Y126.118 E1.57908
                                G1 X144.679 Y125.976 E0.02285
                                G1 X144.988 Y125.761 E0.01499
                                G1 X145.247 Y125.492 E0.01487
                                G1 X145.423 Y125.149 E0.01535
                                G1 X145.502 Y124.87 E0.01154
                                G1 X145.54 Y124.505 E0.01461
                                G1 X145.54 Y103.969 E0.81759
                                G1 X145.54 Y99.311 E0.18545
                                G1 X121.155 Y99.31 E0.97082
                                G1 X120.735 Y99.207 E0.01722
                                G1 X120.491 Y99.045 E0.01166
                                G0 F9600 X120.839 Y98.784
                                G1 F900 X120.629 Y98.548 E0.01258
                                G1 X120.566 Y98.348 E0.00835
                                G1 X120.559 Y97.74 E0.02421
                                G1 X120.634 Y97.539 E0.00854
                                G1 X120.755 Y97.379 E0.00799
                                G1 X120.947 Y97.254 E0.00912
                                G1 X121.112 Y97.206 E0.00684
                                G1 X145.96 Y97.205 E0.98926
                                G1 X145.96 Y95.995 E0.04817
                                G1 X145.788 Y95.372 E0.02573
                                G1 X145.526 Y94.952 E0.01971
                                G1 X145.262 Y94.672 E0.01532
                                G1 X144.852 Y94.384 E0.01995
                                G1 X144.411 Y94.25 E0.01835
                                G1 X144.118 Y94.209 E0.01178
                                G1 X104.041 Y94.208 E1.59556
                                G1 X104.041 Y107.166 E0.51589
                                G1 X137.858 Y108.265 E1.34705
                                G1 X138.337 Y108.372 E0.01954
                                G1 X138.81 Y108.626 E0.02137
                                G1 X139.143 Y108.946 E0.01839
                                G1 X139.415 Y109.349 E0.01936
                                G1 X139.6 Y110.035 E0.02829
                                G1 X139.6 Y116.209 E0.2458
                                G1 X139.48 Y116.837 E0.02545
                                G1 X139.235 Y117.285 E0.02033
                                G1 X138.922 Y117.635 E0.01869
                                G1 X138.445 Y117.935 E0.02243
                                G1 X137.866 Y118.085 E0.02381
                                G1 X131.796 Y118.089 E0.24166
                                G1 X131.331 Y118.008 E0.01879
                                G1 X130.84 Y117.703 E0.02301
                                G1 X130.604 Y117.401 E0.01526
                                G1 X130.449 Y117.093 E0.01373
                                G1 X130.346 Y117.026 E0.00489
                                G1 X104.04 Y116.175 E1.04785
                                G1 X104.04 Y126.54 E0.41266
                                G1 X144.155 Y126.538 E1.59707
                                G1 X144.864 Y126.359 E0.02911
                                G1 X145.262 Y126.083 E0.01928
                                G1 X145.592 Y125.738 E0.01901
                                G1 X145.816 Y125.304 E0.01944
                                G1 X145.917 Y124.948 E0.01473
                                G1 X145.96 Y124.526 E0.01689
                                G1 X145.96 Y103.969 E0.81842
                                G1 X145.96 Y98.891 E0.20217
                                G1 X121.169 Y98.89 E0.98699
                                G1 X120.839 Y98.784 E0.0138
                                G0 F9600 X121.045 Y97.683
                                ;TYPE:WALL-OUTER
                                G1 F900 X121.153 Y97.629 E0.00481
                                G1 X146.38 Y97.625 E1.00435
                                G1 X146.38 Y96.09 E0.06111
                                G1 X146.335 Y95.775 E0.01267
                                G1 X146.177 Y95.202 E0.02366
                                G1 X145.86 Y94.694 E0.02384
                                G1 X145.538 Y94.353 E0.01867
                                G1 X145.039 Y94.002 E0.02429
                                G1 X144.502 Y93.838 E0.02235
                                G1 X144.147 Y93.789 E0.01427
                                G1 X103.621 Y93.788 E1.61344
                                G1 X103.621 Y107.572 E0.54877
                                G1 X137.887 Y108.69 E1.36494
                                G1 X138.162 Y108.756 E0.01126
                                G1 X138.537 Y108.949 E0.01679
                                G1 X138.847 Y109.244 E0.01704
                                G1 X139.036 Y109.557 E0.01456
                                G1 X139.18 Y110.092 E0.02206
                                G1 X139.177 Y116.187 E0.24266
                                G1 X139.083 Y116.681 E0.02002
                                G1 X138.87 Y117.077 E0.0179
                                G1 X138.656 Y117.311 E0.01262
                                I had to keep cutting this shorter to get it to fit within a post... hopefully its enough to be useful. Note this is gcode with zero fan that still showed the issue. But even when running a fan I had it set to turn on at layer 2 to 15% and I watched it physically start on layer 2 as expected.
                                I am about to be travelling for two weeks so I appreciate all your suggestions and I will work on them when I return.
                                  mdbergholm
                                  Just as an update in case anyone else comes across a similar issue - I haven't gotten it totally fixed but it seems to be related to my thermistor settings for my hotend. I was using a config that I found from CNC Kitchen (he swapped a Prusa to Duet) and I am using the same heater/thermistor so I assumed it would work fine. Once I found the datasheet for the thermistor and entered the values from there it seems to be a lot better. I am going through tweaking and PID tuning now but I am relatively confident that with some tuning I can make this defect disappear. Something to look for if you run into the same problem.
                                  mdbergholmundefined 1 Reply Last reply Reply Quote 2
                                    @mdbergholm and just to correct myself - the issue was NOT temperature related. My layer lines are super clean now that I have my hotend dialed in, but that was not what was causing my defect. I had M376 H5 set in the probe section of my config. I copied my config from CNC kitchen since I was using all the same hardware I was trying to make it easier for myself. In the end I went through line by line and culled anything I didn't deem necessary and verified on the duet wiki any line I didn't understand. Setting M376 H0 keeps mesh compensation on for the whole print and no more issue right at 5mm height...
                                    Again...just in case anyone else runs into it. Check fade height. Thanks @gloomyandy for suggesting it.
