Input Shaping plugin "Machine is not homed!"
468
    jjude
    I'm trying to run "Record Motion Profile" but I get a message "Machine is not homed!".
    All axes is homed.
    Input Shaping plugin 3.4.1-b1, DWC 3.4.3, Duet2 Wifi firmware 3.4.3.
    Sparkfun accelerometer
    https://www.sparkfun.com/products/13963
    Wiring and config https://docs.duet3d.com/User_manual/Connecting_hardware/Sensors_Accelerometer
      Please update to 3.4.5 and update the plugin as well.
      Upload this zip file to the system tab in DWC.
      https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.5/Duet2and3Firmware-3.4.5.zip
      https://plugins.duet3d.com/plugins/InputShapingPlugin.html
      undefined 1 Reply Last reply 18 Feb 2023, 09:16 Reply Quote 0
        jjude @Phaedrux
        @Phaedrux said in Input Shaping plugin "Machine is not homed!":
        3.4.5
        Duet Web Control 3.4.5
        Duet 2 WiFi/Ethernet 3.4.5
        Input Shaping 3.4.1-b1
        will still come
        undefined 1 Reply Last reply 18 Feb 2023, 09:34 Reply Quote 0
          Rushmere3D @jjude
          @jjude What happens if you click the Home All button?
          Follow my adventures in 3D Printing, laser cutting and electronics. https://linktr.ee/Rushmere3D
          undefined 1 Reply Last reply 18 Feb 2023, 09:41 Reply Quote 0
            jjude @Rushmere3D
            @Rushmere3D
            The printer drives the axes home, nothing else happens.
            The notification remains, NEXT is gray
              Please post your full config.g and homing files.
              undefined 1 Reply Last reply 18 Feb 2023, 17:31 Reply Quote 0
                jjude @Phaedrux
                @Phaedrux
                Please try to find out..
                homez.g homey.g homex.g homeall.g config.g
                undefined 1 Reply Last reply 19 Feb 2023, 17:55 Reply Quote 0
                  jjude @jjude
                  @jjude
                  I removed config.g the filament changer motors and axes, now working fine!
                  undefined 1 Reply Last reply 20 Feb 2023, 13:54 Reply Quote 0
                  • undefined Phaedrux marked this topic as a question 19 Feb 2023, 20:58
                  • undefined Phaedrux has marked this topic as solved 19 Feb 2023, 20:58
                    T3P3Tony administrators @jjude
                    @jjude how are you configuring the filament changer motors? if you are configuring them as axes rather than extruders then those will be the unhomed axes that are causing the issues.
                    If you need to keep them as axes rather than extruders then either home them, or send G92 A0 B0 C0
                    or whatever the axes are to se them to a known position (does not need to be 0).
                    9 out of 9
