Warning: Driver 1 warning: over temperature warning
536
    infiniteloop @SonnyD1
    @SonnyD1 said in Warning: Driver 1 warning: over temperature warning:
    I'm sure the general consensus will be to put a fan on the motherboard.
    No, you are advised to vent the board from below.
      https://docs.duet3d.com/en/Duet3D_hardware/Duet_2_family/Duet_2_WiFi_Ethernet_Hardware_Overview#cooling
      Important! The higher the motor currents you set, the more important it is to cool the board. Always use a cooling fan if you run a Duet 2 WiFi or Duet 2 Ethernet above 2.0A motor current.
      You're pretty close to that. Good ventilation is important for any electronics that generate heat. Forced air would be recommended in this case. Direct a fan along both sides of the board. Mount the board vertically if possible.
      undefined 2 Replies Last reply 4 Mar 2023, 19:01 Reply Quote 0
        SonnyD1 @Phaedrux
        @Phaedrux Ok so my board is mounted horizontally with 10mm of air on the bottom side. I am going to raise that amount as much as I can and add a 24v blower wired to "Always on" that will blow across the bottom of the board on the drivers. Also, I turned down the current to 65%. I don't plan on speed printing with this printer so I will run some tests to see if that's enough. Based on your advice these items will resolve my issue. It will take some time to complete the hardware adjustments so for now I will consider this issue solved until I can run some additional tests. That is, unless you disagree?
        undefined 1 Reply Last reply 7 Mar 2023, 09:12 Reply Quote 1
          elmoret @SonnyD1
          All of them seem to get pretty hot and are warm even when they are doing nothing.
          Stepper motors are constant power devices - the current running through them is constant, even when they are doing "nothing".
            SonnyD1 @Phaedrux
            @Phaedrux I'm looking at Wathai 75mm x 30mm DC Blower Fan 24V Brushless Cooling Fan https://a.co/d/dJJvd90 . I plan to run one per board with ducts channeling air flow to the bottom of each driver. What do you think? Is that enough, overkill or not enough?
              Should be fine.
              • undefined SonnyD1 has marked this topic as solved 5 Mar 2023, 23:22
                dc42 administrators @SonnyD1
                10mm of space below the board is enough if you have a fan blowing air through it along the line of stepper drivers, or perhaps 2 fans blowing crossways instead.
                undefined 1 Reply Last reply 14 Mar 2023, 23:16 Reply Quote 0
                  SonnyD1 @dc42
                  @dc42 336113310_543608657758529_1691986418586856314_n.jpg 335957639_250863380607540_514005489904937907_n.jpg
                  Like this?
                  undefined 1 Reply Last reply 15 Mar 2023, 06:55 Reply Quote 2
                    @SonnyD1 how will the warm air escape after passing below the drivers?
                    undefined 1 Reply Last reply 17 Mar 2023, 18:51 Reply Quote 0
                      SonnyD1 @dc42
                      @dc42 There is a 2mm space between the printed duct/base and the board. The fins inside the duct channel the air directly to the bottom of each driver chip then dispersed out across the bottom of the board via the 2mm gap. I hope I'm explaining that well enough.
                      undefined 1 Reply Last reply 21 Feb 2024, 14:44 Reply Quote 1
                        FlyingAspect @SonnyD1
                        @SonnyD1 and did the ventilation help??
                        undefined 1 Reply Last reply 26 Feb 2024, 17:24 Reply Quote 0
                          SonnyD1 @FlyingAspect
                          @FlyingAspect Yes. I got a 75mm Blower and designed a duct to channel it straight to the back of the drivers. Eliminated the problem. Printer sounds like a jet taking off, but it's not bad. All electronics are underneath so it muffles it some.
