    Stutter on long curves - bitrate?
    Firmware installation
    1.1k
      T3P3Tony administrators @IndeX4D
      @IndeX4D free space 7.78GB? sounds alright. lets see the M122 for the mainboard when the stuttering is occuring and also the M122 for boards 30, 20 and 21
      IndeX4Dundefined 2 Replies Last reply Reply Quote 0
      • IndeX4Dundefined
        IndeX4D @T3P3Tony
        @T3P3Tony let ne just test print with new Jerks. Changing back to default bitrate took a while....
        • IndeX4Dundefined
          IndeX4D @T3P3Tony
          @T3P3Tony
          It“s not the jerk - still stutter.
          M122 is coming...
          • IndeX4Dundefined
            IndeX4D
            m122 b0
            RepRapFirmware for Duet 3 MB6HC version 3.5beta2 (2023-02-08 17:43:01) running on Duet 3 MB6HC v1.01 (standalone mode)
            Board ID: 08DJM-956L2-G43S8-6J9D0-3S46R-9U2AD
            Used output buffers: 1 of 40 (40 max)
            Error in macro line 15 while starting up: No WiFi interface available
            Static ram: 154344
            Dynamic ram: 119384 of which 0 recycled
            Never used RAM 68072, free system stack 128 words
            Tasks: NETWORK(ready,29.4%,194) ETHERNET(notifyWait,0.2%,559) HEAT(notifyWait,0.0%,321) Move(notifyWait,10.8%,214) CanReceiv(notifyWait,0.1%,771) CanSender(notifyWait,0.5%,325) CanClock(delaying,0.0%,340) TMC(notifyWait,8.1%,56) MAIN(running,50.9%,446) IDLE(ready,0.0%,30), total 100.0%
            Owned mutexes: HTTP(MAIN)
            Last reset 00:33:06 ago, cause: software
            Last software reset at 2023-03-24 18:35, reason: User, Gcodes spinning, available RAM 69384, slot 0
            Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
            Error status: 0x00
            Step timer max interval 269
            MCU temperature: min 41.5, current 41.9, max 41.9
            Supply voltage: min 23.8, current 24.0, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
            12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0
            Heap OK, handles allocated/used 99/4, heap memory allocated/used/recyclable 2048/80/16, gc cycles 0
            Events: 0 queued, 0 completed
            Driver 0: standstill, SG min 0, mspos 488, reads 45589, writes 0 timeouts 0
            Driver 1: standstill, SG min 0, mspos 488, reads 45588, writes 0 timeouts 0
            Driver 2: standstill, SG min 0, mspos 488, reads 45588, writes 0 timeouts 0
            Driver 3: standstill, SG min 0, mspos 488, reads 45588, writes 0 timeouts 0
            Driver 4: standstill, SG min n/a, mspos 8, reads 45588, writes 0 timeouts 0
            Driver 5: standstill, SG min n/a, mspos 440, reads 45588, writes 0 timeouts 0
            Date/time: 2023-03-24 19:08:50
            Slowest loop: 8.30ms; fastest: 0.06ms
            === Storage ===
            Free file entries: 18
            SD card longest read time 3.6ms, write time 0.0ms, max retries 0
            DMs created 125, segments created 34, maxWait 627ms, bed compensation in use: none, comp offset 0.000
            next step interrupt due in 2156 ticks, disabled
            === DDARing 0 ===
            Scheduled moves 65387, completed 65327, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
            === DDARing 1 ===
            Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
            Heater 0 is on, I-accum = 0.1
            Heater 2 is on, I-accum = 0.0
            HTTP is ready with "m122 b0" in state(s) 0
            Telnet is idle in state(s) 0
            File is idle in state(s) 3
            USB is idle in state(s) 0
            Aux is idle in state(s) 0
            Trigger is idle in state(s) 0
            Queue is idle in state(s) 0
            LCD is idle in state(s) 0
            SBC is idle in state(s) 0
            Daemon is idle in state(s) 0
            Aux2 is idle in state(s) 0
            File2 is idle in state(s) 0, sync state 1
            Queue2 is idle in state(s) 0
            Q0 segments left 26, axes/extruders owned 0x40000007
            Code queue 0 is empty
            Code queue 1 is empty
            === CAN ===
            Messages queued 31229, received 3638, lost 0, boc 0
            Longest wait 2ms for reply type 6029, peak Tx sync delay 461, free buffers 50 (min 16), ts 239/239/0
            Tx timeouts 0,0,0,0,0,0
            === Network ===
            Slowest loop: 13.45ms; fastest: 0.03ms
            Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
            HTTP sessions: 2 of 8
            = Ethernet =
            State: active
            Error counts: 0 0 0 0 0 0
            === Multicast handler ===
            Responder is inactive, messages received 0, responses 0
            IndeX4Dundefined 1 Reply Last reply Reply Quote 0
            • IndeX4Dundefined
              IndeX4D @IndeX4D
              m122 b30
              Diagnostics for board 30:
              Duet EXP1HCL firmware version 3.5beta2 (2023-02-08 15:50:31)
              Bootloader ID: SAME5x bootloader version 2.4 (2021-12-10)
              All averaging filters OK
              Never used RAM 51496, free system stack 173 words
              Tasks: Move(notifyWait,0.3%,110) HEAT(notifyWait,0.0%,78) CanAsync(notifyWait,0.0%,53) CanRecv(notifyWait,0.2%,42) CanClock(notifyWait,0.0%,69) TMC(notifyWait,48.0%,346) CLSend(notifyWait,0.0%,152) MAIN(running,49.6%,407) IDLE(ready,0.0%,30) AIN(notifyWait,1.9%,265), total 100.0%
              Last reset 00:33:44 ago, cause: software
              Last software reset data not available
              Closed loop enabled: yes, pre-error threshold: 12.00, error threshold: 8.00, encoder type rotaryQuadrature, position 41370
              Encoder reverse polarity: yes, raw count 24167
              Tuning mode: 0, tuning error: 0, collecting data: no
              Control loop runtime (us): min=12, max=41, frequency (Hz): min=9868, max=15306
              Driver 0: pos 132268, 160.0 steps/mm,ok, SG min n/a, mspos 948, reads 0, writes 49516 timeouts 0, steps req 3485420 done 0
              Moves scheduled 70382, completed 70361, in progress 1, hiccups 0, step errors 0, maxPrep 128, maxOverdue 3, maxInc 1, mcErrs 0, gcmErrs 0
              Peak sync jitter -5/17, peak Rx sync delay 208, resyncs 0/0, next step interrupt due in 3 ticks, enabled
              VIN voltage: min 24.2, current 24.3, max 24.3
              V12 voltage: min 12.2, current 12.3, max 12.3
              MCU temperature: min 32.4C, current 38.7C, max 38.7C
              Last sensors broadcast 0x00000000 found 0 128 ticks ago, 0 ordering errs, loop time 0
              CAN messages queued 5664, send timeouts 0, received 53704, lost 0, free buffers 37, min 36, error reg 20000
              dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 333, adv 34395/82094
              • IndeX4Dundefined
                IndeX4D
                m122 b21
                Diagnostics for board 21:
                Never used RAM 51320, free system stack 173 words
                Tasks: Move(notifyWait,0.2%,110) HEAT(notifyWait,0.0%,78) CanAsync(notifyWait,0.0%,53) CanRecv(notifyWait,0.2%,42) CanClock(notifyWait,0.0%,69) TMC(notifyWait,48.5%,346) CLSend(notifyWait,0.0%,152) MAIN(running,49.1%,407) IDLE(ready,0.0%,30) AIN(notifyWait,1.9%,265), total 100.0%
                Last reset 00:33:42 ago, cause: software
                Closed loop enabled: yes, pre-error threshold: 12.00, error threshold: 8.00, encoder type rotaryQuadrature, position 43300
                Encoder reverse polarity: yes, raw count 22235
                Control loop runtime (us): min=12, max=40, frequency (Hz): min=10000, max=15306
                Driver 0: pos 132383, 160.0 steps/mm,ok, SG min n/a, mspos 444, reads 0, writes 31928 timeouts 0, steps req 3538630 done 0
                Moves scheduled 70151, completed 70130, in progress 1, hiccups 0, step errors 0, maxPrep 117, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
                Peak sync jitter -2/16, peak Rx sync delay 205, resyncs 0/0, next step interrupt due in 21 ticks, enabled
                VIN voltage: min 24.6, current 24.7, max 24.8
                V12 voltage: min 12.2, current 12.2, max 12.2
                MCU temperature: min 31.0C, current 34.6C, max 35.0C
                Last sensors broadcast 0x00000000 found 0 110 ticks ago, 0 ordering errs, loop time 0
                CAN messages queued 8788, send timeouts 0, received 54034, lost 0, free buffers 37, min 36, error reg 10000
                dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 333, adv 35010/82643
                • IndeX4Dundefined
                  IndeX4D
                  m122 b20
                  Diagnostics for board 20:
                  Never used RAM 51496, free system stack 172 words
                  Tasks: Move(notifyWait,0.2%,110) HEAT(notifyWait,0.0%,78) CanAsync(notifyWait,0.0%,53) CanRecv(notifyWait,0.1%,42) CanClock(notifyWait,0.0%,69) TMC(notifyWait,47.8%,346) CLSend(notifyWait,0.0%,152) MAIN(running,49.8%,407) IDLE(ready,0.0%,30) AIN(notifyWait,2.0%,265), total 100.0%
                  Last reset 00:33:41 ago, cause: software
                  Closed loop enabled: yes, pre-error threshold: 12.00, error threshold: 8.00, encoder type rotaryQuadrature, position -35748
                  Encoder reverse polarity: yes, raw count 35748
                  Control loop runtime (us): min=12, max=42, frequency (Hz): min=10000, max=15306
                  Driver 0: pos 144227, 160.0 steps/mm,ok, SG min n/a, mspos 764, reads 0, writes 48368 timeouts 0, steps req 4052086 done 0
                  Moves scheduled 69892, completed 69871, in progress 1, hiccups 0, step errors 0, maxPrep 117, maxOverdue 1, maxInc 1, mcErrs 0, gcmErrs 0
                  Peak sync jitter -3/16, peak Rx sync delay 210, resyncs 0/0, next step interrupt due in 17 ticks, enabled
                  VIN voltage: min 24.6, current 24.6, max 24.7
                  V12 voltage: min 12.1, current 12.1, max 12.1
                  MCU temperature: min 31.9C, current 36.1C, max 36.3C
                  Last sensors broadcast 0x00000000 found 0 187 ticks ago, 0 ordering errs, loop time 0
                  CAN messages queued 6662, send timeouts 0, received 55645, lost 0, free buffers 37, min 36, error reg 10000
                  dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 333, adv 34737/82358
                    Did this start happening after updating to 3.5 Beta 2? Or same thing on 3.4.5?
                    • IndeX4Dundefined
                      IndeX4D @Phaedrux
                      @Phaedrux
                      It has been starting in the last time somehow. I've not printing curvy things in last time. So I can't say it 100%. But it could be.
                      Strange - other printer is printing with 3.5beta2 also and has no problems. Just smaller nozzles at work and there are no stutter in (smaller) curves.
                      https://forum.duet3d.com/topic/22746/cura-uses-concentric-circles-to-fill-will-be-a-layer-of-lag
                      May I thought about this.... I have a new extruder with 100mm3 maximum flow so the flow rate has been increased from 20mm3 to almost 80mm3.
                        @IndeX4D ok, now start a print running (you can remove the filament to avoid wasting it) and when you have had that stuttering happening for a while, then send the M122s as above.
                        I am looking to see if there are any issues reported on the CAN communications, or driver hiccups or buffer underruns etc.
                        if you let it stutter for a while then it will rule out a single hiccup etc.
                        • IndeX4Dundefined
                          IndeX4D @T3P3Tony
                          @T3P3Tony
                          The diagnostics above are made by a print when some stutter happened.... or do I need to print for a longer time?
                            @IndeX4D it does not look like you were printing a file. I suggest pritning one that stutters a lot and have it stuttering for at least (say) 100 stutters then send the M122 9while its still printing).
                            If that doe snot show up anything in the CAN communication, hiccups or buffers then the next thing to try is temporarily switch the axes into open loop mode
                            • IndeX4Dundefined
                              IndeX4D @T3P3Tony
                              @T3P3Tony
                              I added a M413 S0 to stop power loss like somebody said. was not working. may that“s the reason it looked like it was not printing.
                              I“ll start a print, now.
                              • IndeX4Dundefined
                                IndeX4D @T3P3Tony
                                @T3P3Tony
                                Used output buffers: 3 of 40 (40 max)
                                Static ram: 154344
                                Tasks: NETWORK(ready,31.1%,194) ETHERNET(notifyWait,0.2%,559) HEAT(notifyWait,0.0%,321) Move(notifyWait,1.8%,214) CanReceiv(notifyWait,0.1%,771) CanSender(notifyWait,0.1%,325) CanClock(delaying,0.0%,340) TMC(notifyWait,8.4%,56) MAIN(running,58.2%,446) IDLE(ready,0.0%,30), total 100.0%
                                Owned mutexes:
                                Last reset 01:33:42 ago, cause: software
                                Error status: 0x00
                                Step timer max interval 271
                                MCU temperature: min 39.8, current 41.1, max 42.0
                                Supply voltage: min 23.7, current 23.9, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
                                12V rail voltage: min 12.1, current 12.2, max 12.2, under voltage events: 0
                                Heap OK, handles allocated/used 99/4, heap memory allocated/used/recyclable 2048/104/40, gc cycles 0
                                Driver 0: standstill, SG min 0, mspos 488, reads 4467, writes 4 timeouts 0
                                Driver 1: standstill, SG min 0, mspos 488, reads 4467, writes 4 timeouts 0
                                Driver 2: standstill, SG min 0, mspos 488, reads 4467, writes 4 timeouts 0
                                Driver 3: standstill, SG min 0, mspos 488, reads 4467, writes 4 timeouts 0
                                Driver 4: standstill, SG min n/a, mspos 8, reads 4471, writes 0 timeouts 0
                                Driver 5: standstill, SG min n/a, mspos 440, reads 4468, writes 2 timeouts 0
                                Date/time: 2023-03-24 20:09:25
                                Slowest loop: 54.15ms; fastest: 0.05ms
                                === Storage ===
                                SD card longest read time 4.3ms, write time 146.2ms, max retries 0
                                DMs created 125, segments created 34, maxWait 3037708ms, bed compensation in use: none, comp offset 0.000
                                next step interrupt due in 1472 ticks, disabled
                                === DDARing 0 ===
                                Scheduled moves 50125, completed 50065, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
                                === DDARing 1 ===
                                Heater 0 is on, I-accum = 0.2
                                HTTP is idle in state(s) 0
                                Q0 segments left 3, axes/extruders owned 0x40000007
                                === CAN ===
                                Messages queued 417508, received 276475, lost 0, boc 0
                                Longest wait 5ms for reply type 6024, peak Tx sync delay 655, free buffers 50 (min 16), ts 18180/18180/0
                                === Network ===
                                Slowest loop: 147.44ms; fastest: 0.03ms
                                = Ethernet =
                                State: active
                                • IndeX4Dundefined
                                  IndeX4D
                                  Static ram: 154344
                                  Tasks: NETWORK(ready,28.8%,194) ETHERNET(notifyWait,0.3%,559) HEAT(notifyWait,0.0%,321) Move(notifyWait,12.6%,214) CanReceiv(notifyWait,0.1%,771) CanSender(notifyWait,0.5%,325) CanClock(delaying,0.0%,340) TMC(notifyWait,8.0%,56) MAIN(running,49.6%,446) IDLE(ready,0.0%,30), total 100.0%
                                  Owned mutexes:
                                  Last reset 01:50:56 ago, cause: software
                                  Error status: 0x04
                                  Step timer max interval 252
                                  MCU temperature: min 41.5, current 41.7, max 41.8
                                  Supply voltage: min 23.7, current 24.0, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
                                  Driver 0: standstill, SG min 0, mspos 488, reads 10678, writes 0 timeouts 0
                                  Driver 1: standstill, SG min 0, mspos 488, reads 10676, writes 0 timeouts 0
                                  Driver 2: standstill, SG min 0, mspos 488, reads 10676, writes 0 timeouts 0
                                  Driver 3: standstill, SG min 0, mspos 488, reads 10677, writes 0 timeouts 0
                                  Driver 4: standstill, SG min n/a, mspos 8, reads 10677, writes 0 timeouts 0
                                  Driver 5: standstill, SG min n/a, mspos 440, reads 10677, writes 0 timeouts 0
                                  Date/time: 2023-03-24 20:26:39
                                  Slowest loop: 9.70ms; fastest: 0.09ms
                                  === Storage ===
                                  SD card longest read time 3.5ms, write time 0.0ms, max retries 0
                                  DMs created 125, segments created 34, maxWait 165ms, bed compensation in use: none, comp offset 0.000
                                  next step interrupt due in 2125 ticks, disabled
                                  === DDARing 0 ===
                                  Scheduled moves 225820, completed 225760, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
                                  === DDARing 1 ===
                                  Q0 segments left 58, axes/extruders owned 0x40000007
                                  === CAN ===
                                  Messages queued 11311, received 1164, lost 0, boc 0
                                  Longest wait 0ms for reply type 0, peak Tx sync delay 292, free buffers 50 (min 18), ts 77/77/0
                                  === Network ===
                                  Slowest loop: 12.66ms; fastest: 0.03ms
                                  = Ethernet =
                                  State: active
                                  Slowest loop 12.66ms?
                                  Is this right?
                                  When having 12 in M569.1
                                  • IndeX4Dundefined
                                    IndeX4D
                                    m122 b20
                                    Tasks: Move(notifyWait,0.7%,110) HEAT(notifyWait,0.0%,78) CanAsync(notifyWait,0.0%,53) CanRecv(notifyWait,0.4%,42) CanClock(notifyWait,0.0%,69) TMC(notifyWait,47.7%,346) CLSend(notifyWait,0.0%,152) MAIN(running,49.2%,399) IDLE(ready,0.0%,30) AIN(notifyWait,1.9%,265), total 100.0%
                                    Last reset 01:55:04 ago, cause: software
                                    Closed loop enabled: yes, pre-error threshold: 12.00, error threshold: 8.00, encoder type rotaryQuadrature, position -65535
                                    Encoder reverse polarity: yes, raw count 65535
                                    Driver 0: pos 97480, 160.0 steps/mm,ok, SG min n/a, mspos 764, reads 0, writes 36246 timeouts 0, steps req 3911300 done 0
                                    Moves scheduled 367793, completed 367793, in progress 0, hiccups 0, step errors 0, maxPrep 119, maxOverdue 2, maxInc 2, mcErrs 0, gcmErrs 0
                                    Peak sync jitter -2/14, peak Rx sync delay 207, resyncs 0/0, next step interrupt due in 12 ticks, enabled
                                    VIN voltage: min 24.6, current 24.7, max 24.7
                                    MCU temperature: min 31.9C, current 35.7C, max 36.5C
                                    Last sensors broadcast 0x00000000 found 0 165 ticks ago, 0 ordering errs, loop time 0
                                    CAN messages queued 7290, send timeouts 0, received 160029, lost 0, free buffers 37, min 37, error reg 40000
                                    dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 335, adv 34405/74350
                                    m122 b21
                                    Never used RAM 51320, free system stack 172 words
                                    Tasks: Move(notifyWait,0.3%,110) HEAT(notifyWait,0.0%,78) CanAsync(notifyWait,0.0%,53) CanRecv(notifyWait,0.2%,42) CanClock(notifyWait,0.0%,69) TMC(notifyWait,47.5%,346) CLSend(notifyWait,0.0%,152) MAIN(running,50.1%,399) IDLE(ready,0.0%,30) AIN(notifyWait,1.9%,265), total 100.0%
                                    Last reset 01:55:51 ago, cause: software
                                    Closed loop enabled: yes, pre-error threshold: 12.00, error threshold: 8.00, encoder type rotaryQuadrature, position 65490
                                    Encoder reverse polarity: yes, raw count 46
                                    Driver 0: pos 97480, 160.0 steps/mm,ok, SG min n/a, mspos 444, reads 0, writes 64430 timeouts 0, steps req 8692927 done 0
                                    Moves scheduled 367793, completed 367793, in progress 0, hiccups 0, step errors 0, maxPrep 118, maxOverdue 2, maxInc 1, mcErrs 0, gcmErrs 0
                                    Peak sync jitter -2/17, peak Rx sync delay 209, resyncs 0/0, next step interrupt due in 4 ticks, enabled
                                    VIN voltage: min 24.6, current 24.7, max 24.9
                                    MCU temperature: min 31.0C, current 35.0C, max 35.2C
                                    Last sensors broadcast 0x00000000 found 0 212 ticks ago, 0 ordering errs, loop time 0
                                    CAN messages queued 59178, send timeouts 0, received 381438, lost 0, free buffers 37, min 37, error reg 80000
                                    dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 335, adv 34423/81293
                                    m122 b30
                                    Tasks: Move(notifyWait,0.3%,110) HEAT(notifyWait,0.0%,78) CanAsync(notifyWait,0.0%,53) CanRecv(notifyWait,0.2%,42) CanClock(notifyWait,0.0%,69) TMC(notifyWait,47.1%,346) CLSend(notifyWait,0.0%,152) MAIN(running,50.5%,399) IDLE(ready,0.0%,30) AIN(notifyWait,2.0%,265), total 100.0%
                                    Last reset 01:55:54 ago, cause: software
                                    Closed loop enabled: yes, pre-error threshold: 12.00, error threshold: 8.00, encoder type rotaryQuadrature, position 65541
                                    Encoder reverse polarity: yes, raw count 65531
                                    Control loop runtime (us): min=12, max=42, frequency (Hz): min=9868, max=15625
                                    Driver 0: pos 92616, 160.0 steps/mm,ok, SG min n/a, mspos 948, reads 0, writes 38835 timeouts 0, steps req 9192394 done 0
                                    Moves scheduled 367344, completed 367344, in progress 0, hiccups 0, step errors 0, maxPrep 118, maxOverdue 4, maxInc 1, mcErrs 0, gcmErrs 0
                                    Peak sync jitter -5/19, peak Rx sync delay 214, resyncs 0/0, next step interrupt due in 5 ticks, enabled
                                    MCU temperature: min 32.4C, current 38.9C, max 39.1C
                                    Last sensors broadcast 0x00000000 found 0 27 ticks ago, 0 ordering errs, loop time 0
                                    CAN messages queued 39474, send timeouts 0, received 380779, lost 0, free buffers 37, min 37, error reg a0000
                                    dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 336, adv 33841/80725
                                    • o_lampeundefined
                                      o_lampe
                                      While you are hunting down a FW issue, I'd suggest to use "arcwelder.exe" as postprocessor in your slicer.
                                      It's very helpful compressing gcode and reduce SD-card traffic while printing.
                                      I don't remember where I found it, but I think it was on github. Maybe others who use it can chime in?
                                        @IndeX4D can't see any hiccups, can you try running the same print in open loop mode.
                                        • IndeX4Dundefined
                                          IndeX4D
                                          New situation:
                                          I used cura 5.0 insteaf of 5.3 --> almost no stutter
                                          Then I increased the stl output stl (0.001mm) resolution.
                                          Then I sliced and the g code had around 10mb instead of 2.7mb. So more steps are not a hugh problem - I think the new cura version make to many strange corners. I“ll test it more and more the next hours and will tell you the exact Issue.
                                          I was a bit lazy and I haven“t told you, that I usally print with up to 250mm/s and I had no stutter- now I was printing with maximum 100mm/s, so I could not imagine that the board is to slow. Only different was a very natural curvy shape and a much bigger hotend/ layer width/ with much more filament output.
                                          Now, I after was printing 2.5 hours without stutter, I had 1 little layer shift but some underruns. I don“t know where this comes from. I very often ask, If 10 meter cable is to long or need higher bitrate?`
                                          Layer shifts has never be a problem, so I just keep an Eye on it.
                                          m122 b0
                                          Used output buffers: 8 of 40 (37 max)
                                          Static ram: 154344
                                          Dynamic ram: 119352 of which 0 recycled
                                          Never used RAM 67432, free system stack 140 words
                                          Tasks: NETWORK(ready,1852.5%,194) ETHERNET(notifyWait,13.8%,445) HEAT(notifyWait,2.2%,321) Move(notifyWait,222.0%,214) CanReceiv(notifyWait,11.8%,771) CanSender(notifyWait,6.8%,325) CanClock(delaying,0.7%,340) TMC(notifyWait,1030.5%,56) MAIN(running,995.7%,446) IDLE(ready,4.5%,30), total 4140.4%
                                          Last reset 09:37:23 ago, cause: software
                                          Last software reset at 2023-03-26 13:09, reason: User, Gcodes spinning, available RAM 68600, slot 0
                                          Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
                                          Error status: 0x00
                                          Step timer max interval 339
                                          MCU temperature: min 38.7, current 39.7, max 41.9
                                          Heap OK, handles allocated/used 99/2, heap memory allocated/used/recyclable 2048/72/32, gc cycles 0
                                          Driver 0: standstill, SG min 0, mspos 808, reads 48960, writes 23 timeouts 0
                                          Driver 1: standstill, SG min 0, mspos 808, reads 48960, writes 23 timeouts 0
                                          Driver 2: standstill, SG min 0, mspos 808, reads 48960, writes 23 timeouts 0
                                          Driver 3: standstill, SG min 0, mspos 808, reads 48960, writes 23 timeouts 0
                                          Driver 4: standstill, SG min n/a, mspos 8, reads 48972, writes 11 timeouts 0
                                          Driver 5: standstill, SG min 0, mspos 440, reads 48961, writes 23 timeouts 0
                                          Date/time: 2023-03-26 22:47:17
                                          Slowest loop: 51.47ms; fastest: 0.04ms
                                          === Storage ===
                                          Free file entries: 20
                                          SD card longest read time 4.6ms, write time 41.5ms, max retries 0
                                          DMs created 125, segments created 62, maxWait 6017841ms, bed compensation in use: none, comp offset 0.000
                                          no step interrupt scheduled
                                          === DDARing 0 ===
                                          Scheduled moves 318648, completed 318648, hiccups 0, stepErrors 0, LaErrors 0, Underruns [120, 7, 7], CDDA state -1
                                          === DDARing 1 ===
                                          File is idle in state(s) 0
                                          Q0 segments left 0, axes/extruders owned 0x40000003
                                          === CAN ===
                                          Messages queued 3010480, received 2632681, lost 0, boc 0
                                          Longest wait 13ms for reply type 6018, peak Tx sync delay 669, free buffers 50 (min 16), ts 173217/173215/0
                                          === Network ===
                                          Slowest loop: 56.31ms; fastest: 0.03ms
                                          HTTP sessions: 1 of 8
                                          = Ethernet =
                                          State: active
                                          Error counts: 0 0 0 1 0 0
                                          Socket states: 5 5 2 2 2 0 0 0
                                            @IndeX4D lots of very very short segments can cause stuttering but AFAIK modern slicers have a setting to set the shortest allowed segment length to something reasonable.
                                            for example on cura:
