    Cura uses concentric circles to fill will be a layer of lag
    25
    1.6k
    • FLYundefined
      FLY
      When cura turns on this filling mode, there will be a layer of printing and filling, there will be a stutter4ac04cc3-9404-48b6-98e8-6623c74a03e3-image.png
      I set the number of outer wall and inner wall to 1 layer, but there will be a stutter when printing on the second layer
      187f74dc-1150-4a69-8560-b428f9306536-image.png This is the gcode that I separated one layer of the second circle from the other 3 circlesSecond lap.gcode
      other.gcode
      Test stl
      零件1.STL
      Does anyone know where this is the reason?
      dc42undefined jay_s_ukundefined 2 Replies Last reply Reply Quote 0
        Is it maybe trying to do a gap fill in between?
        alankilianundefined 1 Reply Last reply Reply Quote 0
        • alankilianundefined
          alankilian @Phaedrux
          I don't understand the question.
          FLYundefined 1 Reply Last reply Reply Quote 0
          • FLYundefined
            FLY @alankilian
            @alankilian The second circle prints vibration, other circles will not vibrate
            • FLYundefined
              FLY
              35ddfd2e-9266-4972-90fb-2aeb6ce4974d-image.png ad4257a8-7be9-4817-9f80-3d71ad36b507-image.png
              After removing the E parameter in the second gcode, there will be no freezes. It is preliminarily believed that the extrusion command parameter will conflict with other movement parameters. Even if the extrusion speed, acceleration, speed change is increased to a large extent, it will also be stuck
              • FLYundefined
                FLY
                Motion video with E parameters in the second circle
                EAA7EBE743E9CB9A0F54CB66640C68B2.mp4
                Motion video without E parameter in the second lap9F1DD4E87A58FBD740D55F4C5D791780.mp4
                • FLYundefined
                  FLY
                  E parameters of 2 files are taken out separately for comparison
                  • FLYundefined
                    FLY
                    I conducted a test, and if the extruder grows close to 0 and there are many cuts nearby, there will be vibration.
                    mrehorstdmdundefined 1 Reply Last reply Reply Quote 0
                    • mrehorstdmdundefined
                      mrehorstdmd @FLY
                      @fly Try tweaking the line width and reslice.
                      giostarkundefined 1 Reply Last reply Reply Quote 1
                        dc42 administrators @FLY
                        @fly, do you have pressure advance enabled? If yes, try setting it to zero. If that stops the stuttering, then the reason may be that Cura is not generating moves with a uniform extrusion rate. We have a GCode analyser that can look at this in more detail.
                        FLYundefined 2 Replies Last reply Reply Quote 0
                        • FLYundefined
                          FLY
                          After testing, the DUET2 motherboard will not vibrate when the heating is not turned on. When the heating is turned on, it will vibrate even if the set temperature is 0. What I get roughly means that as long as the E extruder is involved, it will vibrate.
                          Test version 3.3 b1/3.3 b2
                          • FLYundefined
                            FLY @dc42
                            @dc42 There is no advance squeeze setting found in my config,So duet officially needs to be tested
                            • FLYundefined
                              FLY @dc42
                              @dc42 When the E command is close to 0, the gcode parser should ignore the value of E and only keep the XY parameter, which should solve this problem
                              engikeneerundefined 1 Reply Last reply Reply Quote 0
                              • engikeneerundefined
                                engikeneer @FLY
                                @fly post your config.g file (copy the text and use the code snippet tool). That way we can see any issues in there, and have a go at recreating the problem.
                                i3 clone with a bunch of mods
                                • FLYundefined
                                  FLY @engikeneer
                                  @engikeneer It has nothing to do with the configuration file, gcode parsing problem. You can test the gcode I sent, or modify the filling mode of cura.
                                  • FLYundefined
                                    FLY
                                    This is the configuration tested on my duet2 motherboard on ender3
                                    ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sat Apr 17 2021 11:41:47 GMT+0800 (中国标准时间)
                                    M550 P"My Printer" ; set printer name
                                    M552 S1 ; enable network
                                    M586 P0 S1 ; enable HTTP
                                    M586 P1 S0 ; disable FTP
                                    M586 P2 S0 ; disable Telnet
                                    M569 P0 S0 ; physical drive 0 goes forwards
                                    M569 P1 S0 ; physical drive 1 goes forwards
                                    M569 P2 S0 ; physical drive 2 goes forwards
                                    M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
                                    M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
                                    M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
                                    M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
                                    M84 S30
                                    M208 X230 Y210 Z200 S0 ; set axis maxima
                                    M574 Z1 S2 ; configure Z-probe endstop for low end on Z
                                    M558 P1 C"zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
                                    G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
                                    M557 X15:215 Y15:195 S20 ; define mesh grid
                                    • FLYundefined
                                      FLY
                                      This is the configuration I used on a large machine, using the stm32 motherboard, and using an external driver
                                      ; Configuration file for Fly-E3 (firmware version 3)
                                      ; generated by RepRapFirmware Configuration Tool v3.2.1-LPC on Mon Jan 18 2021 15:03:24 GMT+0800 (中国标准时间)
                                      M569 P0 S1 T5.0:2.0:5:0.4 R1 ; physical drive 0 goes forwards using default driver timings
                                      M569 P1 S0 T5.0:2.0:5:0.4 R1 ; physical drive 1 goes backwards using default driver timings
                                      M569 P2 S1 T1.0:1.0:0.2:0.2 ; physical drive 2 goes forwards using A4988 driver timings
                                      M569 P3 S0 T1.0:1.0:0.2:0.2 ; physical drive 3 goes forwards using A4988 driver timings
                                      M569 P4 S0 T1.0:1.0:0.2:0.2
                                      M584 X0 Y1 Z2 E3:4 ; set drive mapping
                                      M350 X16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation
                                      M92 X266.67 Y266.67 Z1600.00 E92.65:92.65 ; 脉冲
                                      M566 X500.00 Y500.00 Z10.00 E80.00:80.00 ; 最大速度变化mm/秒
                                      M203 X30000.00 Y30000.00 Z600.00 E4800.00:4800.00 ;最大速度 (mm/min)
                                      M201 X700.00 Y700.00 Z100.00 E700.00:700.00 ; 加速度 (mm/s^2)
                                      M906 X800 Y800 Z800 E800:800 I30 ; set motor currents (mA) and motor idle factor in per cent
                                      M84 S30 ; Set idle timeout
                                      M208 X600 Y600 Z63 S0 ; set axis maxima
                                      M574 X2 S1 P"!xstopmax" ; configure active-high endstop for high end on X via pin !xstop
                                      M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin !ystop
                                      M574 Z1 S1 P"!zstop" ; configure active-high endstop for low end on Z via pin !zstop
                                      M558 P9 H4.5 F360 T8000 C"^probe" ; disable Z probe but set dive height, probe speed and travel speed
                                      M557 X15:565 Y15:565 S28 ;
                                      G31 P1000 X-30. 5 Y-3 Z2.891 ;
                                      M950 S0 C"servo0" ;
                                      M950 H0 C"bed" T0 ; create bed heater output on bed and map it to sensor 0
                                      M307 H0 R0.162 C136.2 D3.10 S1.00 V0.0 ; disable bang-bang mode for the bed heater and set PWM limit
                                      M307 H1 R2.457 C230.3 D4.65 S1.00 V0.0 ; disable bang-bang mode for heater and set PWM limit
                                      M563 P1 D1 H1 F0 ; define tool 1
                                      G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets
                                      G10 P1 R0 S0
                                      M575 P1 S0 B57600
                                      T0 ; select first tool
                                      M280 P0 S160
                                        engikeneer @FLY
                                        @fly I just ran your gcode files on my machine. CoreXY with Duet Wifi on RRF3.2.2.
                                        other.gcode seems to have printed fine - smooth & no jerking motion at all.
                                        second-lap.gcode does produce a vibrating motion like you describe. If however, I slow it down a lot (e.g. to 20%), the motion it smooth, but I can see the circle it prints isn't quite perfect (you can see the facets from the stl file and the line width varies a little)
                                        I think that the issue you are seeing is related to some non-uniform extrusion rate as DC42 suggested. You can see in the snippet of the gcode you posted that the extrusion rate is varying. It jumps from ~0.01438mm to 0.00005mm in one line (line 16 to 17), so it goes from extruding to stopping, then back to extruding again in three lines of gcode (in about 10ms of time at a motion speed of 4800mm/min). I calculate that as a speed change of about 160mm/min inboth directions for your extruder (-160mm/min then +160mm/min) which is higher than your jerk setting of 120mm/min (and 80mm/min on the other printer). There are some even higher jumps in the problem file looking at your graphs. The extruder has to be able to keep up with the motion requested and will slow/stop the xyz motion if it can't. Again, as DC42 said, if you have any pressure advance set (I do), this may make things worse as the pressure advance will be applied on top of the extisting fluctuations. All this is the Duet behaving as expected I think.
                                        So your options are:
                                        • Increase your extruder jerk (M566) significantly so that it doesn't impact/limit the motion planning
                                        • Change your slicer settings so the gcode they output is more consistent (e.g. alter your line widths so the additional line is a more consitent size like @mrehorstdmd suggested)
                                        • Change your stl file. It might be that the facets on the inner/outer surfaces are making the rim thickness of your part vary, hence the problem line has all these non-uniform extrusion rates.
                                          Seems like expected behaviour from Cura actually. How it handles single width fill lines is pretty abysmal.
                                          You can try this version of Cura that has some fixes for that behaviour. https://github.com/smartavionics/Cura/releases
                                          Or try Prusa Slicer which has really good gap fill behaviour by comparison.
                                          • FLYundefined
                                            FLY @engikeneer
                                            @engikeneer The M83 command is used in the gcode of RRF, which is not 0.01438mm to 0.00005mm. After extruding 0.01438mm, it will extrude 0.00005mm relative to 0.01438mm.
                                            Modifying the speed and acceleration of the extruder is invalid. I have tried it many times.
                                            Running this kind of gcode in marlin firmware will not have this use case, so I think the firmware program may also have bugs.
