    Duet mini 5 lulzbot won’t drive extruder
    650
    • anthonymundefined
      anthonym @Phaedrux
      @Phaedrux the motor will turn outside but has no torque can stop it by hand.
        droftarts administrators @anthonym
        @anthonym for all of these commands, remove the second E parameter:
        M92 X80.00 Y80.00 Z80.00 E80:80.00 ; set steps per mm
        M566 X900.00 Y900.00 Z60.00 E120.00:60.00 ; set maximum instantaneous speed changes (mm/min)
        M203 X6000.00 Y6000.00 Z200.00 E1200.00:200.00 ; set maximum speeds (mm/min)
        M201 X500.00 Y500.00 Z100.00 E250.00:100.00 ; set accelerations (mm/s^2)
        M906 X1300 Y1300 Z1300 E1350:1300 I30 ; set motor currents (mA) and motor idle factor in per cent
        anthonymundefined 2 Replies Last reply Reply Quote 1
        • anthonymundefined
          anthonym @droftarts
          @droftarts M350 X16 Y16 Z16 E16: I1 ; configure microstepping with interpolation
          M92 X80 Y80 Z80 E420:80 ; set steps per mm
          M566 X900 Y900 Z150 E420:150 ; set maximum instantaneous speed changes (mm/min)
          M203 X6000.00 Y6000.00 Z300.00 E120.00: ; set maximum speeds (mm/min)
          M201 X500.00 Y500.00 Z300.00 E250.00: ; set accelerations (mm/s^2)
          M906 X1300 Y1300 Z1300 E150: I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          • anthonymundefined
            anthonym @droftarts
            @droftarts still does the same thing. I have another stepper I also tried and same thing. if I move over to the x driver it works. Same basically it wont drive e.
              Phaedrux Moderator @anthonym
              @anthonym said in Duet mini 5 lulzbot won’t drive extruder:
              Is this what you changed it to? Try this
              M92 X80.00 Y80.00 Z80.00 E80 ; set steps per mm
              M203 X6000.00 Y6000.00 Z200.00 E1200.00 ; set maximum speeds (mm/min)
              M201 X500.00 Y500.00 Z100.00 E250.00 ; set accelerations (mm/s^2)
              M906 X1300 Y1300 Z1300 E1350 I30 ; set motor currents (mA) and motor idle factor in per cent
              Also send M98 P"config.g" in the gcode console and copy and paste any error messages here.
              anthonymundefined 2 Replies Last reply Reply Quote 0
              • anthonymundefined
                anthonym @Phaedrux
                @Phaedrux Yes
                • anthonymundefined
                  anthonym @Phaedrux
                  @Phaedrux said in Duet mini 5 lulzbot won’t drive extruder:
                  M98 P"config.g"
                  Error: in file macro line 27: M566: array too long, max length = 1
                  anthonymundefined 1 Reply Last reply Reply Quote 0
                  • anthonymundefined
                    anthonym @anthonym
                    @anthonym Error: in file macro line 26: M92: array too long, max length = 1
                      Did you use the block from me above?
                      • anthonymundefined
                        anthonym @Phaedrux
                        @Phaedrux Yes that seems to have fixed it !!
                        • Phaedruxundefined Phaedrux has marked this topic as solved
                          FYI these errors were because you didn’t remove the second E parameter.
                          You also left the colons : in after the first E parameter value, which may not have helped. And the motor had no torque as you had set it to 150mA:
                          • anthonymundefined
                            anthonym @droftarts
                            @droftarts Its seem to be working , I see that now thank you for explaining I really appreciate the help.
                            • anthonymundefined
                              anthonym @droftarts
                              so the issue I am having now it’s extruding way too much if I ask for 10mm I get over 100 my steps per mm are 420 on the aero 2.85 mm with a .5 nozzle.
                                T3P3Tony administrators @anthonym
                                @anthonym send M92 and M350 from the command line and see what they report.
                                anthonymundefined anthony1mundefined 2 Replies Last reply Reply Quote 1
                                • T3P3Tonyundefined T3P3Tony has marked this topic as unsolved
                                • anthonymundefined
                                  anthonym @T3P3Tony
                                  @T3P3Tony I will as soon as I get home and post the report. Thank you
                                  • anthony1mundefined
                                    anthony1m @T3P3Tony
                                    @T3P3Tony
                                    Steps/mm: X: 80.000, Y: 80.000, Z: 80.000, E: 420.000
                                    Microstepping - X:16(on), Y:16(on), Z:16(on), E:16(on)
                                      Is your motor a 0.9 degree or 1.8 degree?
                                        T3P3Tony administrators @anthony1m
                                        @anthony1m and you are definitely getting 10x the requested extrusion? Please measure the actual amount extruded when you send G1 E10
