Duet mini 5 lulzbot won’t drive extruder
@anthonym said in Duet mini 5 lulzbot won’t drive extruder:
@droftarts M350 X16 Y16 Z16 E16: I1 ; configure microstepping with interpolation
M92 X80 Y80 Z80 E420:80 ; set steps per mm
M566 X900 Y900 Z150 E420:150 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z300.00 E120.00: ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z300.00 E250.00: ; set accelerations (mm/s^2)
M906 X1300 Y1300 Z1300 E150: I30 ; set motor currents (mA) and motor idle factor in per cent
M84 S30 ; Set idle timeoutIs this what you changed it to? Try this
M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z80.00 E80 ; set steps per mm M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z200.00 E1200.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z100.00 E250.00 ; set accelerations (mm/s^2) M906 X1300 Y1300 Z1300 E1350 I30 ; set motor currents (mA) and motor idle factor in per cent
Also send M98 P"config.g" in the gcode console and copy and paste any error messages here.
@Phaedrux Yes
@Phaedrux said in Duet mini 5 lulzbot won’t drive extruder:
M98 P"config.g"
Error: in file macro line 27: M566: array too long, max length = 1
@anthonym Error: in file macro line 26: M92: array too long, max length = 1
Did you use the block from me above?
@Phaedrux Yes that seems to have fixed it !!
undefined Phaedrux marked this topic as a question
undefined Phaedrux has marked this topic as solved
FYI these errors were because you didn’t remove the second E parameter.
M92 X80 Y80 Z80 E420:80 ; set steps per mm M566 X900 Y900 Z150 E420:150 ; set maximum instantaneous speed changes (mm/min)
You also left the colons
in after the first E parameter value, which may not have helped. And the motor had no torque as you had set it to 150mA:M906 X1300 Y1300 Z1300 E150: I30 ; set motor currents (mA) and motor idle factor in per cent
@droftarts Its seem to be working , I see that now thank you for explaining I really appreciate the help.
so the issue I am having now it’s extruding way too much if I ask for 10mm I get over 100 my steps per mm are 420 on the aero 2.85 mm with a .5 nozzle.
@anthonym send M92 and M350 from the command line and see what they report.
undefined T3P3Tony has marked this topic as unsolved
@T3P3Tony I will as soon as I get home and post the report. Thank you
@T3P3Tony
Steps/mm: X: 80.000, Y: 80.000, Z: 80.000, E: 420.000
Microstepping - X:16(on), Y:16(on), Z:16(on), E:16(on) -
Is your motor a 0.9 degree or 1.8 degree?
@anthony1m and you are definitely getting 10x the requested extrusion? Please measure the actual amount extruded when you send G1 E10
