    Compiling/Building PanelDue Firmware
    PanelDue
    1.4k
    • R006undefined
      R006 @dc42
      @dc42 hi, sorry for late reply.
      i am build panel FM as per you mentioned but when i am flashing it's paneldue screen was blank.
      and getting this error:Generating binary
      "/arm-none-eabi-objcopy" -O binary "C:\Users\rishita.butala\eclipse-workspace\Firmware\PanelDueFirmware\Release-7.0/PanelDueFirmware-v2-7.0.elf" "C:\Users\rishita.butala\eclipse-workspace\Firmware\PanelDueFirmware\Release-7.0/PanelDueFirmware-v2-7.0.bin" && cat "C:/Users/rishita.butala/eclipse-workspace/Firmware/PanelDueFirmware/Release-7.0/PanelDueFirmware-v2-7.0.bin" "C:/Users/rishita.butala/eclipse-workspace/Firmware/PanelDueFirmware/SplashScreens/SplashScreen-Duet3D-800x480.bin" >"C:/Users/rishita.butala/eclipse-workspace/Firmware/PanelDueFirmware/Release-7.0/PanelDueFirmware-v2-7.0-logo.bin"
      c:/program files (x86)/gnu arm embedded toolchain/10 2020-q4-major/bin/sh: /arm-none-eabi-objcopy: not found
      makefile:101: recipe for target 'post-build' failed
      make[1]: [post-build] Error 127 (ignored)
      but i am go through this topic:https://forum.duet3d.com/topic/22876/solved-paneldue-firmware-compile-error/10
      and try to generating .bin file so .bin file was generated. but it's blank.
      i am waiting for your reply @dc42
      Any Suggestions? @jay_s_uk
      R006undefined 1 Reply Last reply Reply Quote 0
      • R006undefined
        R006 @R006
        @dc42 i am waiting for your reply
          dc42 administrators @R006
          @R006 looks like you haven't defined variable ArmGccPath in Window->Preferences->C/C++->Build->Build Variables. It need to be defined as the path to the folder where the C++ compiler and related tools (including arm-none-eabi-objcopy) live. This is what mine is set to, although a more recent version of the compiler than that should also work.
          • R006undefined
            R006 @dc42
            @dc42 it's already defined.
              If you look at the Command box in the above image, you can see that it tries to invoke "${ArmGccPath}/arm-none-eabi-objcopy". As it's trying to invoke"/arm-none-eabi-objcopy" according to the error message you posted, there must be something wrong with your definition of that build variable, or else the post build step command line in your system doesn't match mine.
              • R006undefined
                R006 @dc42
                Post-build steps in my eclipse.
                "${ArmGccPath}/arm-none-eabi-objcopy" -O binary "${workspace_loc:/${ProjName}/${ConfigName}}/${BuildArtifactFileBaseName}.elf" "${workspace_loc:/${ProjName}/${ConfigName}}/${BuildArtifactFileBaseName}.bin" && cat "${ProjDirPath}/${ConfigName}/${BuildArtifactFileBaseName}.bin" "${ProjDirPath}/SplashScreens/SplashScreen-Duet3D-800x480.bin" >"${ProjDirPath}/${ConfigName}/${BuildArtifactFileBaseName}-logo.bin"
                  @R006 and how have you set ArmGccPath ?
                  R006undefined 1 Reply Last reply Reply Quote 1
                  • R006undefined
                    R006 @dc42
                    @dc42 ArmGccPath is C:\Program Files (x86)\GNU Arm Embedded Toolchain\10 2020-q4-major\bin
                      @R006 and is file arm-none-eabi-objcopy.exe in that folder?
                      • R006undefined
                        R006 @dc42
                        @dc42 yes
                        but as per error c:/program files (x86)/gnu arm embedded toolchain/10 2020-q4-major/bin/sh: /arm-none-eabi-objcopy: not found may be it's search in sh folder
                        R006undefined oliofundefined 2 Replies Last reply Reply Quote 0
                        • R006undefined
                          R006 @R006
                          This post is deleted!
                          • oliofundefined
                            oliof @R006
                            @R006 remove /sh from the path
                            • R006undefined
                              R006 @oliof
                              @dc42 thank you for support .
                              now i am able to build it. and generating PanelDueFirmware.bin file successfully by changing the name of ArmGccPath.
                              but after flashing successfully & restart panel, it was blank.
                              Any Suggestions?@chrishamm
                              • R006undefined
                                R006 @R006
                                @dc42 @chrishamm can any one try my build bin file of panelduefirmware & Check what's wrong in that file & check in your panel if it's working or not.
                                Firmware varsion:3.4.beta3
                                souce code of panel:https://github.com/Duet3D/PanelDueFirmware
                                bin file:68a650ee-e619-4847-8f02-267908ce9181-PanelDueFirmware-v2-7.0.bin
                                dc42undefined 2 Replies Last reply Reply Quote 0
                                  @R006 where is your binary file, and which build configuration is it?
                                  • R006undefined
                                    R006 @dc42
                                      @R006 I am away for a few days, but in any case I'm not sure I have a version 2 PanelDue board left. Perhaps @mfs12 can test your binary.
                                      • R006undefined
                                        R006 @dc42
                                        @dc42 thank you for your support now it's working fine.
                                        • Phaedruxundefined Phaedrux has marked this topic as solved
