Post-build steps in my eclipse.
"${ArmGccPath}/arm-none-eabi-objcopy" -O binary "${workspace_loc:/${ProjName}/${ConfigName}}/${BuildArtifactFileBaseName}.elf" "${workspace_loc:/${ProjName}/${ConfigName}}/${BuildArtifactFileBaseName}.bin" && cat "${ProjDirPath}/${ConfigName}/${BuildArtifactFileBaseName}.bin" "${ProjDirPath}/SplashScreens/SplashScreen-Duet3D-800x480.bin" >"${ProjDirPath}/${ConfigName}/${BuildArtifactFileBaseName}-logo.bin" -
@R006 and how have you set ArmGccPath ?
@dc42 ArmGccPath is C:\Program Files (x86)\GNU Arm Embedded Toolchain\10 2020-q4-major\bin
@R006 and is file arm-none-eabi-objcopy.exe in that folder?
@dc42 yes
but as per error c:/program files (x86)/gnu arm embedded toolchain/10 2020-q4-major/bin/sh: /arm-none-eabi-objcopy: not found may be it's search in sh folder -
This post is deleted! -
@R006 remove
/sh
from the path -
@dc42 thank you for support .
now i am able to build it. and generating PanelDueFirmware.bin file successfully by changing the name of ArmGccPath.but after flashing successfully & restart panel, it was blank.
Any Suggestions?@chrishamm
@dc42 @chrishamm can any one try my build bin file of panelduefirmware & Check what's wrong in that file & check in your panel if it's working or not.
Firmware varsion:3.4.beta3
souce code of panel:https://github.com/Duet3D/PanelDueFirmware
bin file:68a650ee-e619-4847-8f02-267908ce9181-PanelDueFirmware-v2-7.0.bin -
@R006 where is your binary file, and which build configuration is it?
@dc42 thank you for your support now it's working fine.
