    Compiling/Building PanelDue Firmware
    PanelDue
    1.6k
      dc42 administrators @R006
      @R006 and how have you set ArmGccPath ?
      R006undefined 1 Reply Last reply Reply Quote 1
      • R006undefined
        R006 @dc42
        @dc42 ArmGccPath is C:\Program Files (x86)\GNU Arm Embedded Toolchain\10 2020-q4-major\bin
          @R006 and is file arm-none-eabi-objcopy.exe in that folder?
          R006undefined 1 Reply Last reply Reply Quote 0
          • R006undefined
            R006 @dc42
            @dc42 yes
            but as per error c:/program files (x86)/gnu arm embedded toolchain/10 2020-q4-major/bin/sh: /arm-none-eabi-objcopy: not found may be it's search in sh folder
            R006undefined oliofundefined 2 Replies Last reply Reply Quote 0
            • R006undefined
              R006 @R006
              This post is deleted!
              • oliofundefined
                oliof @R006
                @R006 remove /sh from the path
                • R006undefined
                  R006 @oliof
                  @dc42 thank you for support .
                  now i am able to build it. and generating PanelDueFirmware.bin file successfully by changing the name of ArmGccPath.
                  but after flashing successfully & restart panel, it was blank.
                  Any Suggestions?@chrishamm
                  • R006undefined
                    R006 @R006
                    @dc42 @chrishamm can any one try my build bin file of panelduefirmware & Check what's wrong in that file & check in your panel if it's working or not.
                    Firmware varsion:3.4.beta3
                    souce code of panel:https://github.com/Duet3D/PanelDueFirmware
                    bin file:68a650ee-e619-4847-8f02-267908ce9181-PanelDueFirmware-v2-7.0.bin
                    dc42undefined 2 Replies Last reply Reply Quote 0
                      @R006 where is your binary file, and which build configuration is it?
                      • R006undefined
                        R006 @dc42
                          @R006 I am away for a few days, but in any case I'm not sure I have a version 2 PanelDue board left. Perhaps @mfs12 can test your binary.
                          • R006undefined
                            R006 @dc42
                            @dc42 thank you for your support now it's working fine.
                            • Phaedruxundefined Phaedrux has marked this topic as solved
