    3.5 B3 Toolboard stepper intermittently running backwards
    Beta Firmware
    12
    83
    4.5k
    • tasundefined
      tas
      Hi dc42,
      I just need firmware for Duet2wifi and I can test immediately.
      I do have pressure advance enabled in my config.
        dc42 administrators @tas
        @tas please try the file at https://www.dropbox.com/sh/in0t2j68ic66oa8/AADv_6WzRy07H6MhBOrkDt23a?dl=0. Caution: this is untested because I no longer have a Duet 2 machine to test it on.
        @Exerqtor I will test the new tool board firmware on my machine before I make it available.
        dc42undefined tasundefined 2 Replies Last reply Reply Quote 0
          dc42 administrators @dc42
          @Exerqtor my test print was OK so I have put the new binaries for tool board and 6HC at https://www.dropbox.com/sh/in0t2j68ic66oa8/AADv_6WzRy07H6MhBOrkDt23a?dl=0. The tool board binary should be all you need to fix this issue.
          • ctilley79undefined
            ctilley79 @dc42
            @dc42 I’m using an SBC Duet 3 6HC and Toolboard. Is there a process to update without the package manager?
              dc42 administrators @ctilley79
              @ctilley79 if you are already running 3.5.0-beta.3 then it should be OK to just upload the new files via DWC.
              • tasundefined
                tas @dc42
                @dc42 Yes that has fixed the problem.
                I tried extrude and retract from the paneldue three times rebooting the printer each time. All ok.
                I then tried a print and the prime did push out filament. I see no issues with the print so far.
                So you have fixed the issue and my Duet2Wifi machine did not blow up.
                Many thanks.
                • Argoundefined
                  Argo @dc42
                  I can confirm the issues are gone with Duet 3 Mini 5 + Toolboard 1LC šŸ™‚
                    dc42 administrators @Argo
                    @Argo @tas thanks for the feedback! This gives us more confidence to release 3.5.0-beta.4.
                    ctilley79undefined 1 Reply Last reply Reply Quote 0
                      ctilley79 @dc42
                      @dc42 Worked for me too. Thank you.
                        @ctilley79 thanks.
                        Exerqtorundefined 1 Reply Last reply Reply Quote 0
                        • Exerqtorundefined
                          Exerqtor @dc42
                          Seems to be working here too!
                          It's off-topic but happened after moving too b3+ so i'll drop it here and open another thread if it's more than a one line reply to fix it. Now I'm having some issues with the new neopixel assignement, it won't accept M950 E0 C"DO" T2 and returns:
                          M950 E0 C"DO" T2
                          Error: M950: Unknown pin name 'do'
                          This is on the Duet 3 Mini.
                            dc42 administrators @Exerqtor
                            @Exerqtor the configuration of LED strips has changed for 3.5 beta4. See the new E parameter of the M950 command and the updated M150 description in the GCode dictionary.
                            • Exerqtorundefined
                              Exerqtor @dc42
                              Yeah I allready have the GCode dictionary for M150 & M950 up trying to figgure out what i'm doing wrong.
                              The reason i "had" to look into it now is that it threw Error: LED strip #0 has not been configured . And when i try to configure it it won't let me lol. (Or do i have to wait for b4 for it to work again?).
                                ctilley79 @Exerqtor
                                @Exerqtor said in 3.5 B3 Toolboard stepper intermittently running backwards:
                                If I'm reading the M950 G-code section correctly, some of those parameters aren't available until 3.5.0-beta.4. I'm just living with the error at the moment.
                                Exerqtorundefined dc42undefined 2 Replies Last reply Reply Quote 1
                                • Exerqtorundefined
                                  Exerqtor @ctilley79
                                  @ctilley79 said in 3.5 B3 Toolboard stepper intermittently running backwards:
                                  Yeah that's how i'm interpreting it to, Same here even though it's flooding DWC & PD at the start / end of a print lmao.
                                    @ctilley79 the new commands for configuring and controlling LED strips are implemented in the 3.5.0-beta.3+ binaries that I posted. They have been tested on Duet 3 Mini and 6HC.
                                    @Exerqtor please post the M950 and M150 commands you used.
                                    Exerqtorundefined 1 Reply Last reply Reply Quote 1
                                    • wieman01undefined
                                      wieman01
                                      Hello, @ctilley79,
                                      I generally have these issues when there is a problem with the wiring or the connectors. Manual extruding via DWC works fine, but then the motor needs higher currents, it move backwards because the wires only let through so much current.
                                      I would check every wiring the in particular the soldering joints and connectors. This solves this particular problem for me every time.
                                      wieman01
                                      • Exerqtorundefined
                                        Exerqtor @dc42
                                        @dc42 said in 3.5 B3 Toolboard stepper intermittently running backwards:
                                        That's weird, since i'm quiiiite sure i'm using the right command set (for a Duet3 Mini).
                                        I TRY to send M950 E0 C"DO" T2, but i get the error mentioned above.
                                        The M150's have been changed to this (for example):
                                        M150 E0 R150 U150 B150 W150 S1 F1
                                        M150 E0 R150 U150 B150 W150 S2 F0
                                        gloomyandyundefined oliofundefined 2 Replies Last reply Reply Quote 0
                                        • gloomyandyundefined
                                          gloomyandy @Exerqtor
                                          @Exerqtor Is "DO" a valid pin name on the mini? I had a quick look and couldn't find any pins with that name. Is this for the neopixels in a display attached via the exp headers?
                                          • oliofundefined
                                            oliof @Exerqtor
                                            @Exerqtor Are you sure DO is right and not D0?
