    duet 2 wifi wifi connector fell off * warrenty request e3d *
    591
    • owling2005undefined
      owling2005
      as e3d have sent me here for you to try and help me the connector fell off while mounting the board into the case
      • Reply for jay as I cant find the reply button * this is the best photo I can produce its off my phone I have no other way to take a photo
        jay_s_uk @owling2005
        @owling2005 your photo is tiny. could you post a higher resolution one?
          owling2005
          @owling2005 said in duet 2 wifi wifi connector fell off * warrenty request e3d *:
            @owling2005 i think you're uploading a thumbnail rather than actual image as its very difficult to see anything
            up to @Phaedrux
            owling2005undefined 1 Reply Last reply Reply Quote 0
              owling2005 @jay_s_uk
              @jay_s_uk ![alt text](image url16868291500763124873634634459842.jpg )
                @owling2005 wow, i think connector fell off is a bit of an understatement. what happened to that?
                  @jay_s_uk ur answers as good as mine
                  elmoretundefined 1 Reply Last reply Reply Quote 0
                  • elmoretundefined
                    elmoret @owling2005
                    It was clearly physically damaged.... warranty is not going to cover smashing the product!
                      owling2005 @elmoret
                      @elmoret it wasnt physicalie damaged it looked like the connector was just glued on
                        It was like that out of the box?
                          owling2005 @Phaedrux
                          @Phaedrux no i mounted it into my ender 5+ middle section connected all the wires turned it over and it was gone 😞 I was fuming its such a bad design these no support or anything for it
                            @owling2005 sounds like you trapped the wifi antenna and ripped it off during turning the machine off.
                              @jay_s_uk i made sure it was free it was just the weight of the cable cause I couldn't disconnect it because of its poor placement
                              • elmoretundefined
                                elmoret @owling2005
                                The "weight of the cable" would not have caused all these scratches and smash marks on the ESP shield/housing:
                                infiniteloopundefined 1 Reply Last reply Reply Quote 1
                                • infiniteloopundefined
                                  infiniteloop @elmoret
                                  @elmoret
                                  These WiFi cables can weight quite a lot - especially if the router is more than a scratch (or two) away 😎
                                    A Former User
                                    This post is deleted!
                                      owling2005
                                      the scrathces happened after the fact as I was thinning cables for the pins for the connector and a blob of solder fell on there I do have a possible friend able to possible desolder the board but if we do that I'll go ethernet as the wifi was patchy at best board would restart but wifi would fail to connect
                                        droftarts administrators @owling2005
                                        @owling2005 Unfortunately, damage like this is not covered by the warranty. See https://www.duet3d.com/page/warranty-policy
                                        I initially thought that there's a hole through the board, but I think it is actually just the pad has been ripped off. Unfortunately, the missing pad is the contact for the pin. See page 19 of https://www.espressif.com/sites/default/files/documentation/esp-wroom-02u_esp-wroom-02d_datasheet_en.pdf
                                        Probably the easiest repair is to replace the ESP module. They are £2.59 on Digikey: https://www.digikey.co.uk/en/products/detail/espressif-systems/ESP-WROOM-02U-N2/9381715
                                        Edit: The Duet Mini 5+ WiFi PCB is different from the Ethernet version; you can't replace the WiFi module with an Ethernet module.
                                          owling2005 @droftarts
                                          @droftarts i have a standard duet 2 wifi i ordered the ethernet module and get a replacement wifi aswell
                                          Thanks for your kind words i wish more members were as considerate
                                            Ah, sorry, I was looking at my Mini 5+ and forgot you had a Duet 2! It's the same ESP module on both, though. And you're right, you can change a Duet 2 WiFi to a Duet 2 Ethernet.
