    BIQU Microprobe
    Third-party add-ons
    8
    25
    3.1k
      jay_s_uk @omni
      @omni i have one of the beta models. apart from a bug that they've now fixed it works fine with RRF and i would recommend it over the bltouch
      I've also covered the setup of a microprobe on the teamgloomy wiki https://teamgloomy.github.io/fly_e3_pro_v3_bltouch.html#overview
      omniundefined 1 Reply Last reply Reply Quote 1
      • omniundefined
        omni @jay_s_uk
        @jay_s_uk
        Thanks for the reply.
        I mostly print on glass, but I've tried pretty much all types of probes in the past (inductive, ir, piezo, microswitch, etc.) except the new scanning type (like the Beacon) and I've always returned to Bltouch because it has been the most reliable/convenient choice - so if there is an improved version of that approach - I would love to try it out. The only situations in which I had repeatability issues with bltouch is when I heat the chamber above 45-50 degrees - but that is rare and even that was solvable with repeated probing until two consecutive ones are withing a very small range.
          jay_s_uk @omni
          @omni as far as i'm aware the microprobe is less affected by heat than the bltouch so it would be fine in a heated chamber
          omniundefined 1 Reply Last reply Reply Quote 0
          • jens55undefined
            jens55
            I noticed that it too has two ground lines, the same as my BLTouch. I am starting to wonder if there is a reason for that. I currently combine the two ground lines in order to run one less wire.
            What is the sense technology of this unit vs the BLTouch - it looks to just be a BLTouch clone but it promises a much better accuracy - is that marketing or is it true? (0.001 - 0.05 vs 0.001-0.003). I have always struggled with the BLTouch accuracy and accuracy alone would be enough of a reason to try this new probe.
            • omniundefined
              omni @jens55
              @jens55 The first versions of BLtouch had problems.... but V3.1 has been working almost flawless-ly for me for years. Check what version you have and also it might be susceptible to inteference, so if you are running unshielded stepper wires in parallel to Bltouch wires, maybe that can cause accuracy problems. I have it installed exactly the same as in the Duet Docs, with 5 wires (veeeery long by the way), but all my stepper cables are shielded and it has been performing like a champ. The only issues I had were chamber temperature related.... since it can have missreadings if the chamber temperature is too high....
              • omniundefined
                omni @jay_s_uk
                @jay_s_uk I've just ordered one.... looking forward to testing it.
                • jens55undefined
                  jens55 @omni
                  @omni, I do in fact run unshielded stepper wires. My issue is that the BLTouch works just fine but the accuracy/repeatability is crap. The accuracy of the BLTouch is between 0.001 and 0.05 and it is not unusual for my setup to take that full 0.05 range .... we are not talking 0.005 but 0.050 so when I see 0.001 to 0.003 I start to drool .....
                  I turn my bed heater off during probing and only the Z motors move (slowly) so I am reluctant to call 'interference' but I suppose I can see how the Z motor cabling is routed and see how that can be changed.
                  • omniundefined
                    omni @jens55
                    @jens55 Well that may well be your main problem - you are probing a cold bed or a hot bed which is cooling during the probing since your bed heater is off. The aluminium plate can warp and fluctuate in height BY A LOT in just a matter of seconds depending on the isolation, much more than the problem of accuracy of the probe. Before you probe the bed you need to make it stabilize in tempreture and keep the printing temperature of the bed (preferably with PWM) at all times during the probing in order to get the most accurate results. Probing it cold or during cooling is pretty much useless if you are looking for very high accuracy during printing. 0.003 repeatability is plenty, those are not values that you are going to notice. But bed height fluctuating +/- 0.3mm because of the cooling you are definitely going to notice...
                    • jens55undefined
                      jens55 @omni
                      @omni I respectfully disagree - the bed and build plate I am referring to has a fairly high thermal mass and is very slow to change temperature. Further, RRF has specific features solely for turning bed heating off while actually probing. Before probing, the bed is thermally stabilized (substantial wait period after starting up the bed heat) and during probing the overall bed temperature is stable.
                      I used to run with bed heating on (PWM) and turning off the heating during actual probing improved the consistency of the readings.
                      • omniundefined
                        omni @jens55
                        @jens55 Well yes, you might be right if it's a small by surface but very thick bed and well insulated it might not make such a big difference. I have a 525x525x6mm bed and it warps like crazy when heating / cooling. It can be +/- 0.5mm difference in corners. That is why I adjust and probe the bed only when fully stable at the printing temperature. But I don't think there is a need to turn off the bed while probing if you are using bltouch. For some other types of probes maybe...
                        • jens55undefined
                          jens55
                          I am having no end of issues with my BLTouch. A bed mesh of my glass plate looks like the Rocky Mountains (Western Canada). This is a Ver 1.0 so it's ancient.
                          After some contemplation, I was too intrigued by the 'Microprobe' promise of a higher accuracy and better repeatability over a BLTouch ver 3.1. I should get the sensor in about 3 weeks. I am quite skeptical about the accuracy claims but the only way to find out is to try it out.
                          I plan on reporting back after I have had a chance to do some testing.
                            dc42 administrators @jens55
                            @jens55 the BLTouch is affected by the magnetic field generated by some bed heaters. Have you tried using parameter B1 in the M558 command to turn heaters off during probing?
                            • jens55undefined
                              jens55 @dc42
                              @dc42, the heater is turned off during the actual probing. I also have a BLTouch Ver 3.0 on another printer and the difference in repeatability is night and day. We are talking about 0.1 mm differences between repeated probings at the same spot!
                              Since I have 3 weeks to stare at a non-operating printer, I might try adjusting the ferrite slug in the BLTouch which some people have said improved their accuracy. Not sure why and how but I got nothing too loose at this point.
                                Phaedrux Moderator @jens55
                                @jens55 said in BIQU Microprobe:
                                There's always manual probing or even stall detection probing in a pinch.
                                • jens55undefined
                                  jens55 @Phaedrux
                                  @Phaedrux Ugh .... manual setup is ok for a rough levelling of the bed but I can't imagine running a printer without a bed mesh compensation map defined.
                                  Just for the heck of it, here are probing results for two runs. The location of the probe point is the same for each run:
                                  -0.036 -0.148 -0.171 -0.165 -0.178 -0.174 -0.175 -0.159 -0.163 -0.153 -0.163 -0.155 -0.175 -0.169 -0.163 -0.175 -0.163 -0.170 -0.165 -0.166 -0.180 -0.176 -0.164 -0.141 -0.165 -0.176, mean -0.161, deviation from mean 0.027
                                  -0.009 -0.007 -0.004 -0.007 -0.015 -0.018 -0.014 -0.011 -0.018 -0.004 -0.011 -0.011 -0.014 -0.010 0.002 -0.005 -0.004 0.007 0.001 0.011 -0.002 0.007 0.012 0.001 0.012 0.005, mean -0.004, deviation from mean 0.009
                                  Most of the measurements in one run are pretty much the same but there are extreme outliers like -0.036 in the first run with all the remaining runs centered around -0.160 or so. Note that the second run looks pretty good at first glance but even it ranges from -0.018 to + 0.011. While I wouldn't be too thrilled about a 0.029 mm in range, it is acceptable (barely) for even a 0.1 mm first layer. Now, when considering all the measurements from both runs which are for the exact same spot on the bed, we are going from +0.011 to -0.180 mm for a total range of 0.191 which is a long way from acceptable for the normal 0.2mm first layer thickness.
                                  Doing a probing run on a printer with a BLTouch Ver 3.0:
                                  -0.041 -0.039 -0.035 -0.037 -0.039 -0.035 -0.032 -0.039 -0.042 -0.044, mean -0.038, deviation from mean 0.003
                                  I also had a chance to try tweaking the ferrite core on the BLTouch which apparently improved things with some people. I saw no discernible improvement.
                                  • dmandnundefined
                                    dmandn
                                    @jens55 I'd be tempted to see if there is any flex in the mount for the bltouch, as that seems to be where my current toolhead design is getting fluctuations from.
                                    One printer is seeing 0.001 fluctuations, while the other with all same except toolhead, 0.02
                                    • jens55undefined
                                      jens55 @dmandn
                                      @dmandn Both printers use the same bits for the carriage and all the parts thereof. The thing about flex that I don't understand - there is practically no load on the probe mount. It holds up the probe and the pin weighs what, a gram or two. The only thing that changes is in one case the mount carries the probe and the pin and in the second case the pin is supported by the build plate. How can there be flex at all? I have read somewhere to make sure the probe mount is solid but I don't understand how this could possibly be a factor. Maybe I am missing something ?
                                      • jens55undefined
                                        jens55
                                        So I have finally installed and tested my BIQU Micro Probe. The overall impression - I am not impressed!
                                        The details:
                                        The pin has a very short movement range - significantly less than a BLTouch. The 'manual' says 4 mm (I measured slightly less but in the range). The BLTouch ver 3.1is 6.6 mm. It is only 2.6 mm difference but it makes a considerable difference. The retracted pin is only about 1.5 mm higher than the nozzle and when probing, the nozzle is only 1.5 mm or so above the trigger point. That doesn't add up to 4 mm of travel but it was as close as I could measure. In any case, these clearances are awfully tight.
                                        Now the real issue - a couple of probing runs over the same spot:
                                        G32 bed probe heights: 0.060 0.054 0.049 0.068 0.054 0.066 0.059 0.054 0.049 0.047 0.045 0.049 0.070 0.062 0.056 0.058 0.051 0.047 0.061 0.058 0.053 0.053 0.047 0.047 0.066 0.055, mean 0.055, deviation from mean 0.007
                                        Total range of measurements: 0.021 mm
                                        G32 bed probe heights: 0.055 0.052 0.066 0.061 0.055 0.052 0.059 0.060 0.058 0.056 0.061 0.068 0.060 0.057 0.061 0.054 0.050 0.056 0.051 0.057 0.052 0.074 0.064 0.066 0.065 0.076, mean 0.060, deviation from mean 0.007
                                        Total range of measurements: 0.025 mm
                                        Total range of both runs for the same testing spot: 0.029
                                        These measurements are for the same spot and they are worse compared to the BLTouch. A lot of reports claim the Micro Probe to have an accuracy about ten times as good as the BLTouch but this is definitely not the case here. Now compared to the presumably defective BLTouch ver 1.0 there is a 10 times improvement but that is not the case against a BLTouch ver 3.0
                                        G32 bed probe heights: -0.009 -0.009 -0.006 -0.003 -0.009 -0.005 -0.007 -0.009 -0.010 -0.009 -0.010 -0.009 -0.011 -0.005 -0.011 -0.010 -0.009 -0.010 -0.011 -0.010 -0.010 -0.010 -0.013 -0.014 -0.010 -0.011, mean -0.009, deviation from mean 0.002
                                        Total range of measurements: 0.011
                                        G32 bed probe heights: -0.006 -0.006 -0.006 -0.009 -0.010 -0.007 -0.009 -0.009 -0.005 -0.009 -0.009 -0.006 -0.007 -0.007 -0.007 -0.007 -0.007 -0.007 -0.007 -0.009 -0.009 -0.010 -0.011 -0.009 -0.011 -0.010, mean -0.008, deviation from mean 0.002
                                        Total range of measurements: 0.006
                                        Total range of both runs for the same testing spot: 0.011
                                        Now these are two different printers .... but I can't see that to make a difference for these tests.
                                        The two supposed points in favour of the Micro Probe are lack of sensitivity to magnetic fields (ie from the heaters switching on/off) and possible larger range of operating temperature range (the BLTouch seems to top out at around 50C or so).
                                        The Micro Probe is totally sealed and has a non-replaceable metal pin, the BLTouch has a replaceable plastic pin. I am not sure which is better.
                                        I did not address size (the MicroProbe is about half the size of a BLTouch) nor speed (irrelevant to me)
                                        I had anticipated replacing the BLTouch ver 3.0 with a Micro Probe for better accuracy but that will obviously not happen. There is some thought of replacing the just installed Micro Probe with a new BLTouch but I am not sure the slight gain in repeatability is worth the cost at the moment.
                                          It could make a large difference to the results, depending on how similar the Z axis construction is between the two machines. I wouldn't like to say that one probe is more reproducible than the other without testing them on the same machine.
                                          • jens55undefined
                                            jens55 @dc42
                                            @dc42, one printer is a CR10 (300-300) and the other is a CR10-S5 (500-500) so the z axis construction is basically identical. I am curious though how error can be introduced even if the z axis is constructed differently. Maybe the resolution (ie motor step angle and z screw pitch)? It's a slow speed process with no x/y action. It's not a question of accuracy but just repeatability with the Z axis going up and down.
                                            What am I missing?
                                            DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
