TPU Shore 60A
3D Printing General Chat
844
    jens55
    I am trying to print a part from a sprinkler. I have tried a shore 85A but just can not get a watertight seal between the sprinkler body and the part I am attempting to print. I have tried everything I can think of including inserting an O ring between the sprinkler body and the 3D printed part. With the O ring, the O ring to sprinkler body joint sealed properly but the O ring to printed part joint leaks.
    One of the possible thoughts I had was that maybe the 85A TPU is not soft enough to deform enough to seal any surface irregularities on the TPU printed part with water using the surface irregularities to escape.
    I have found a Shore 60A TPU (although no stock currently). The vendor recommends a Flexion extruder. I have a Dragon hot end with a Bondtech clone extruder. I am wondering if anyone had experience printing really really soft TPU and the likelihood of TPU 60A filament printing successfully with my hot end/extruder combo.
    undefined undefined undefined 3 Replies Last reply 7 Aug 2023, 05:11 Reply Quote 0
    • undefined Phaedrux moved this topic from Tuning and tweaking 7 Aug 2023, 04:55
      o_lampe @jens55
      @jens55
      Print a mold with PLA filament (or resin for less postprocessing) and fill it with suitable silicone of desired shore.
      If it's a complex shape, you can use the lost PLA method by heating up the mold until it melts away.
        deckingman @jens55
        @jens55 Buying a roll of filament seems to be an expensive way to seal a joint. There may be other ways. Can you describe the part in a bit more detail, or better still, post a picture or two?
        undefined 1 Reply Last reply 7 Aug 2023, 06:43 Reply Quote 0
          jens55 @deckingman
          Before I go into details, a little bit of background is necessary. So these sprinkler heads are about 30 years old and I am assuming that the rubber seal is getting stiff or in some other way is degrading. These sprinkler heads are no longer made and the replacement (of course) is slightly different in size. Option #1 was to dig out all the sprinkler heads in my yard. The current model has a bigger main body so I can't just remove the old sprinkler and install the new sprinkler in the same hole. Option #2 was to design a new gasket. Now as it turned out, with all the time invested so far, I could have pulled and replaced all my sprinklers several times over. So at this stage it is no longer a matter of fixing the sprinklers but rather a "I shall not be defeated by an inanimate object". In other words, I realize that what I am doing is stupid, takes more time and costs more money than just replacing the damn sprinkler heads.
          The sprinkler is a pop-up type sprinkler that sits in the ground. It consists of a main body that is 1.8" in diameter and connects to the pipe system in the ground. It is maybe 6" tall. Inside that tube is a spring loaded pipe with the sprinkler head on top. As water pressure builds up, the tube gets pushed up through a hole in the top of the assembly and the sprinkler does it's thing. The main body/tube has a cap on it with a hole in it for the pop-up tube. The seal in question sits between the main body/tube and the top cap. There are two sealing surfaces - one around the pop up tube so water doesn't leak out around the sides of the tube (it has a bit of clearance so that it can freely pop up) and the second seal is between the main body/tube and the cap around the edge.
          Initially I figured that the seal around the pop up tube would be a big problem but as it turned out, that was easy to accomplish. The sealing surface that I thought would be easy, turned out to be impossible (so far).
          The seal is a single piece of rubber (no idea how soft it was initially) that is pretty hard by now. Since the pop-up seal is not the issue, I will no longer address that part of things.
          To simplify my problem, I have removed the pop-up mechanism from the equation and I have printed a flat disk out of TPU. There is a locating ridge on one side of the disk that fits into the main body/tube. The cap simply screws down onto that new TPU disk and squishes the TPU disk onto the main body.
          The outside wall of the main tube is about 1 mm thick so all the sealing action is happening in a fairly narrow ring at the outside of the tube. Applied water pressure is around 100 PSI. As a matter of interest, the new version of the sprinkler head does not leak at that pressure level. Further, these sprinkler heads are rated up to about 60 PSI (even the new heads). I am going under the assumption that the old sprinkler head was able to handle 100 PSI when it came from the factory but the new sprinkler seal is completely different around the perimeter of the main tube.
          With just the TPU disk installed, I get a ton of leakage from the joint between the TPU disk and the main body/tube. With the addition of an O ring between the TPU disk and the main body, it would appear that all the leakage is on the joint between the TPU disk and the O ring. It would appear that there is no leakage between the main body and the O ring. The surface area of the rim of the main body is nice and smooth, the TPU disk seal surface is anything but smooth. I was hoping that the TPU would deform to the point of sealing all surface abnormalities in the TPU disk.
          I should point out that my description here is based on my current understanding which is obviously false so I am more than likely overlooking some very critical fact.
          Pictures will be posted tomorrow (not including the pop-up mechanism to reduce complexity)
          There are still a number of things I need to try. I am going to try to obtain some inner tube rubber, cut out a disk the same size as my current TPU disk and attempt to place this rubber disk between a TPU disk and the main body. In that sort of arrangement the water would never get to the underside of the TPU disk and the roughness of the sealing TPU surface would not be an issue. It won't help for the complete seal but might confirm my theory about the TPU surface being too rough.
          A currently ongoing experiment - I have put a bead of RTV between the TPU disk and an O ring. I will give this arrangement a few days to fully cure. The hope is that the RTV will seal all TPU seal surface abnormalities.
          Lastly, I still need to try and print thinner TPU seals in the hopes that maybe two layers (0.2 mm each) of TPU would be more flexible than the current 1 mm (or is it 2 mm) thick (solid) TPU.
          At this point I am just trying to figure out exactly what the mechanism is that allows the water to leak past the two joining surfaces. For all I know, maybe the sprinkler was re-designed because the seal arrangement caused many issues even when new. I can see the O ring (1.5 mm thick) to get pushed out of position by the water pressure. A full disk would be immune to that.
          The full seal together with the pop up sealing area is actually quite complex and I do not believe that I could either cast it or use any kind of lost PLA process to replicate it.
            jens55
            The bottom is the original sprinkler. The seal I am replacing is sitting on top of the spring. The area that is leaking is where the seal meets the rim of the tube of the main body. To simplify the whole thing, I made just a lid as seen at the top. This replacement is shown with an O ring but I started out without the O ring since the original seal did not have this. The cap has a surface right next to the thread that forces the edge of the seal against the rim of the tube.
            The part that is really frustrating - the quick coupler you see on the top sprinkler has an O ring that slides into it's female counterpart and has zero leakage 😞
            undefined 1 Reply Last reply 7 Aug 2023, 18:09 Reply Quote 0
              deckingman @jens55
              @jens55 Thanks for the pics - I think I now understand how it works. It's not uncommon for compression fittings (which is what this is essentially) to leak slightly for as number of reasons. Have you tried the normal plumbers solution of wrapping ptfe tape around the threaded part? That's the first thing I'd try. In case you don't know what I'm talking about, here is a little video I found on how too apply it https://www.youtube.com/watch?v=efTqIIAfPhI
              undefined 1 Reply Last reply 7 Aug 2023, 18:19 Reply Quote 0
                jens55 @deckingman
                @deckingman, thanks for your thoughts. In this case, the threads have no sealing function whatsoever. Water is never supposed to get past the joint between the seal and the main body.
                Having said that, I have confirmed that the surface on the printed seal is too rough to work. I have devised a few more tests to try a bunch of different things. One of these tests will be with a seal printed with ironing on in order to make the seal surface smoother. I will also use 0.1 mm layers instead of 0.2 mm layers which should reduce surface roughness. I should have tried ironing right at the beginning but just never thought of it.
                I might have introduced another error during my testing and a whole bunch of experiments need to be repeated.
                undefined 1 Reply Last reply 7 Aug 2023, 18:32 Reply Quote 0
                  deckingman @jens55
                  @jens55 Yes, I understand what you are saying about the thread leakage - but talk to any plumber. In theory compression olives used in copper water systems should always seal but in practice they often leak. That's why plumbers almost always use PTFE tape on threaded connectors, even though the thread itself is not supposed to be part of the seal. It might not be the solution in this case but it will only cost a few cents to find out...........
                  Edit. When I used to use Diamond hot ends, many users complained of leakage where the heat sinks screwed into the brass part. In theory, the face of the heat sink should seal against the face of the brass part so it shouldn't happen. I always used to assemble mine with PTFE tape on the thread and never once had any leakage problems.
                  undefined 1 Reply Last reply 7 Aug 2023, 19:16 Reply Quote 0
                    jens55 @deckingman
                    @deckingman, a lot of people have hot end leakage because they do not hot-tighten the tip which invariably will result in leakage at operating temperatures. If you hot tighten and still have leakage, that says "Chinese tip' to me 🙂
                    I know what you mean re plumbing but a lot of times we are talking a drip every few seconds compared to a geyser in my case. Independent of that, if I seal the thread, the same amount of water will escape out the central hole of the cap where the sprinkler pops up.
                    I am not concerned with a drip every second but when I have a string of sprinklers that are maxing out the water flow that the system is capable of supplying, when you loose a geyser's worth of water at every sprinkler head, you have no pressure left and the sprinklers reach will drop substantially resulting in green patches wherever there is a sprinkler head and brown patches where the sprinkler no longer reaches.
                    Well, I have a number of tests to run and hopefully I will find a smoking gun (or leaking joint) 🙂
                    undefined 1 Reply Last reply 7 Aug 2023, 19:58 Reply Quote 0
                      jens55
                      Further comment:
                      It REALLY doesn't help when you have a tiny particle lodged between the glass build plate and the aluminum base plate. That took way longer to find than it should have 😞 I think this particular issue has been present for some time and would have caused a lot of hair pulling if I had any hair left.
                      Tests with the sprinkler are ongoing and results will be reported for everyone's amusement <sigh>
                        omni @jens55
                        @jens55
                        If you can, get one of these products:
                        Just print a mold, use some mold release, and you will make a perfect gasket.
                        I did not read the entire thread, but also make sure the 3d printed part itself is waterproof. Print it solid or dip it in resin after printing to make sure it's 100% waterproof. I made some critical parts and gaskets for a waterpump and it took me some trial and error before I made it 100% reliable.
                        undefined 1 Reply Last reply 7 Aug 2023, 20:27 Reply Quote 1
                          deckingman @jens55
                          @jens55 said in TPU Shore 60A:
                          For reasons that are beyond the scope of this thread, you can't hot tighten a Diamond hot end.
                          Depends on the pressure - and you did say you have about 100 psi.
                          Although this is digressing somewhat, someone once told me the definition of an expert................ an "ex" is a has been, and a "spurt" is a drip under pressure. I always think of that when someone on TV is introduced as being "an ex spurt". 😄
                          undefined 1 Reply Last reply 7 Aug 2023, 20:14 Reply Quote 0
                            jens55 @deckingman
                            @deckingman ... LOL, got to remember that1
                              jens55 @omni
                              @omni said in TPU Shore 60A:
                              Before ordering O rings for this project, I attempted to make a simple flat ring in a mold but had no end of problems. The RTV doesn't flow so I was unable to 'flow' the material into the mold. Forcing the material in will invariably result in some trapped air pockets. I did not get around to degassing the RTV in a vacuum chamber. I gave up on that before I went too far down that particular rabbit hole.
                              I think I would need to get some castable silicone material that flows properly and that stuff is quite expensive and has a limited shelf life (I think one year).
                              How did you manage to overcome these issues?
                              undefined 1 Reply Last reply 7 Aug 2023, 20:41 Reply Quote 0
                                omni @jens55
                                @jens55 Well, with the rtv I just kind of overpoured it into the mold and made a mold in such a way that it squeezes out the excess... Then when it cured I just did a little bit of postprocessing with a scalpel / rotary tool. Don't know if there were any significant air pockets but it sure worked well enough, and going strong for more than a year now. The second one is pretty much liquid, you can pour it easily. I still haven't used it but it was recommended to me by a person who uses it regularly so I bought it as a backup option. Didn't yet need it since this rtv worked great.
                                  omni
                                  @jens55
                                  Can't find the original file for the gasket mold, but I skecthed something fast along those lines.....
                                  Fill the light gray part with rtv, push the dark gray part inside, the excess goes out from the holes.... when it cures, you just cut it out with a scalpel.
                                  But you need to do it fast while it's still viscous, since it cures quite quickly.... Also my gasket was rather large, so I guess it would be a bit difficult to squeeze it out if the holes were very small....
                                  undefined 1 Reply Last reply 7 Aug 2023, 22:43 Reply Quote 0
                                    jens55 @omni
                                    @omni, thanks. Interesting how you used a 'pusher' with holes. I will have to give that a try. I will also look for that other, more liquid material.
                                    What did you use as a mold release? I didn't have anything specifically called 'mold release' so I used light oil. It might as well have been crazy glue 🙂
                                    undefined 1 Reply Last reply 7 Aug 2023, 22:55 Reply Quote 0
                                      omni @jens55
                                      @jens55
                                      The idea was to put more material than needed (tighly packed into the mold straight from the tube) and then just compress it and let the extra material and and some air flow out of the holes.... It turned out great actually, just needed a bit of sanding where I cut the excess, but it's a 3 minute work.
                                      For the mold release I used a puropse mold release wax (usually used for resin pouring) but since this RTV is silicone based, you can probably get away with a few drops of fairy dishwashing detergent spread all over, since silicone does not stick to it at all....
                                      And one important thing, my mold was printed on a resin printer, so the tolerances were very tight and precise and the surface finish was excellent.
                                      undefined 1 Reply Last reply 7 Aug 2023, 23:28 Reply Quote 0
                                        omni @omni
                                        @omni Yea, another great thing about this method is that my gasket was actually quite complex - it had multiple points of contact on the lower side, so it was not a simple O-ring (more like a 3D o-ring) and I could not find a replacement anywhere. So you can make even complex gaskets.
                                        I tried TPU printing, but anything below 70A is actually quite tricky to pull off nicely. especially if it's a bit complex, and there is always the seam issue with FDM, layers, tolerances, etc. For gaskets - printing a resin mold and using a purpose gasket compound is the way to go.... it also tolerates temperatures up to 200c, does not deform from water exposure and high pressure, etc.
                                          jens55
                                          Thanks for all the input! I have now figured out that ironing TPU causes a mess although maybe that could be lessened with adjusting the settings of the ironing process. I have also come up with a seal that actually works although that seal used PLA and an O ring for the seal and that will not work in the full functioning seal. I might try to build a composite seal that uses PLA and an O ring along the outside of the main body and TPU for the section that seals against the popup part. At this point I do not know how feasible/durable it is to combine PLA and TPU in a single seal when there isn't enough room to combine the materials with some sort of physical connection rather than depending on just adhesion.
                                          Anyway, more trial prints are in order but progress is being made!
                                          After I have this all sorted, I will try my luck again at casting a seal based on what I learned here. I do have a resin printer that has been gathering dust and this might be a great excuse to give that printer another go.
                                          I have given up on the thought of printing 60A shore TPU although I might still give a 70A material a try if I trip over a roll of it someplace up here in Canada. Most TPU in Canada is around shore 90A with only one vendor (that I have found) offering shore 60A TPU. I have not found anything in between those two grades.
                                          7 out of 20
