    Backup of user SD card files
    Documentation
    8
    18
    792
    • appjawsundefined
      appjaws
      The Duet3D Documentation, SD Card section states:-
      "In normal use, you should never need to remove the SD card from its socket. You can transfer files to/from the SD card over the web interface."
      Its no problem to load files from my computer but I just cannot see how to copy to a folder on my computer.
      I can create a zip file of the sys directory but how do I backup filaments, jobs and macros directories?
      appjaws - Core XYUV Duet Ethernet Duex5
      firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
      Ormerod 1-converted to laser engraver, Duet wifi
      OpenSCAD version 2024.03.18
      Simplify3D 5.1.2
      fcwiltundefined deckingmanundefined 2 Replies Last reply Reply Quote 0
      • fcwiltundefined
        fcwilt @appjaws
        @appjaws
        Due to problems like that I took to maintaining all Duet files using an external text editor that supports FTP.
        The Duet firmware can handle an FTP connection.
        Here is what the folder tree looks like inside the editor when connected to the Duet via FTP:
        Any file can be downloaded or uploaded or edited. When the edited file is saved it is automatically uploaded to the Duet.
        The FTP connection can be configured to make a backup on the Duet of any file that is uploaded to the Duet but has changed.
        The FTP connection can also be configured to keep backups of all the files on the Duet on the local computer running the Editor.
        I find it makes maintaining my Duet files much easier.
        Something for you to think about.
        appjawsundefined 2 Replies Last reply Reply Quote 0
          deckingman @appjaws
          @appjaws Hi Paul
          There is this - haven't used it myself. https://forum.duet3d.com/topic/10880/rfm-reprapfirmware-filemanager-duetbackup-successor
          It might do what you want - not sure.
          • jens55undefined
            jens55
            search for "rfm" in the older comments. The link @deckingman posted will also get you there.
            After the developer fixed a bug the other day, I can back up the entire sd card, folder structure and all, in one command.
            • appjawsundefined
              appjaws @fcwilt
              @fcwilt
              Thank you for the information.
              I have installed FileZilla and it appears to be working --- helps if you enter M586 P1 S1 into config
              You say that FTP connection can be configured to make a duet backup and to keep backups , could you share how please?
              Simplify3D 5.1.2
              • fcwiltundefined
                fcwilt @appjaws
                @appjaws said in Backup of user SD card files:
                Glad to hear you got FileZilla working.
                As to your question I was referring to the text editor (EditPad Pro) I am using which allows for that. It is a bit quirky but it has every editing feature you can think of.
                FileZilla is a file transfer program and as far as I know does not provide file editing. It can of course download/upload files from/to the Duet.
                Glad to answer any questions you may have.
                • appjawsundefined
                  appjaws @fcwilt
                  @fcwilt
                  I thought I would take a look at your backup solution.
                  I have the plugins installed on my Notepad++ and have connected to the duet via FTP and can see my files.
                  I get an error when trying to download a file.
                  How do I set up where the file should be copied to?
                  How can I download a complete directory?
                  This may well be easy but I just can't see it, any ideas?
                  Simplify3D 5.1.2
                  fcwiltundefined 2 Replies Last reply Reply Quote 0
                  • fcwiltundefined
                    fcwilt @appjaws
                    @appjaws
                    I will install NotePad++ and check it out.
                    I will get back to you when I have determined how to set it up.
                    • fcwiltundefined
                      fcwilt @appjaws
                      @appjaws
                      Well I installed NotePad++ and the FTP plugin.
                      I created a profile according to the online documentation.
                      It connected OK.
                      It listed the folders and contents OK
                      It changed folders OK
                      It tried to download and ALWAYS failed.
                      I tried every setting I could think of and nothing worked.
                      This is not the first time I have encountered an implementation of FTP that didn't work.
                      As you have observed FileZilla works. My editor, EditPad Pro, works. UltraEdit is flaky as can be and I rarely can open a file on the Duet. DirectoryOpus works but it is not an editor but an amazing replacement for Windows FileExplorer.
                      So when some programs work and some don't, I suspect the problem is the program, not the implementation of FTP on the Duet.
                      Perhaps there is a NotePad++ forum you can ask for help?
                      I will keep trying.
                      • fcwiltundefined
                        fcwilt
                        @KenW
                        That problem with zero byte files was something I was able to get the Duet developer(s) to find and fix.
                        So you suspect the problems with NppFTP are in it's code?
                          Phaedrux Moderator @fcwilt
                          @fcwilt said in Backup of user SD card files:
                          NppFTP
                          Is it making too many requests at once?
                          • fcwiltundefined
                            fcwilt @Phaedrux
                            @Phaedrux said in Backup of user SD card files:
                            NppFTP
                            I have no idea. Today was the first time I ever tried NotePad++.
                              This is what makes me think it's the number of concurrent requests since that will make FileZilla fail in the same way if it's not limited to 1 I seem to recall.
                              • fcwiltundefined
                                fcwilt @Phaedrux
                                Could be. I remember that issue coming up when I first tried to use FTP.
                                  droftarts administrators
                                  @appjaws Is this solved for you now? If you're running in SBC mode rather than standalone, also take a look at this thread: https://forum.duet3d.com/topic/34220/sbc-plugin-to-backup-duet3d-files
                                  appjawsundefined 1 Reply Last reply Reply Quote 0
                                  • appjawsundefined
                                    appjaws @droftarts
                                    @droftarts
                                    No, I wanted to write a script that would run on a schedule to automatically backup the SD card to my windows computer.
                                    At the moment I am mounting the Duet in the windows file system and manually copying all content to a backup location on my PC.
                                    Simplify3D 5.1.2
                                    stuartofmtundefined 1 Reply Last reply Reply Quote 0
                                      To do that you'd need to setup a command line for RFM and run that on a schedule with windows task scheduler.
                                      • stuartofmtundefined
                                        stuartofmt @appjaws
                                        @appjaws
                                        Hi - I'm curious as to your use-case. Is your need to have the backups on your windows computer for occasional use? e.g. restore / write to an SD card. Or do you have some other use-case.
                                        Part of the reason I ask is that I am the author of the duetBackup plugin and curious if I need / should add additional functionality.
