    Backup of user SD card files
    Documentation
    8
    18
    792
      deckingman @appjaws
      @appjaws Hi Paul
      There is this - haven't used it myself. https://forum.duet3d.com/topic/10880/rfm-reprapfirmware-filemanager-duetbackup-successor
      It might do what you want - not sure.
      • jens55undefined
        jens55
        search for "rfm" in the older comments. The link @deckingman posted will also get you there.
        After the developer fixed a bug the other day, I can back up the entire sd card, folder structure and all, in one command.
        • appjawsundefined
          appjaws @fcwilt
          @fcwilt
          Thank you for the information.
          I have installed FileZilla and it appears to be working --- helps if you enter M586 P1 S1 into config
          You say that FTP connection can be configured to make a duet backup and to keep backups , could you share how please?
          appjaws - Core XYUV Duet Ethernet Duex5
          firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
          Ormerod 1-converted to laser engraver, Duet wifi
          OpenSCAD version 2024.03.18
          Simplify3D 5.1.2
          • fcwiltundefined
            fcwilt @appjaws
            @appjaws said in Backup of user SD card files:
            Glad to hear you got FileZilla working.
            As to your question I was referring to the text editor (EditPad Pro) I am using which allows for that. It is a bit quirky but it has every editing feature you can think of.
            FileZilla is a file transfer program and as far as I know does not provide file editing. It can of course download/upload files from/to the Duet.
            Glad to answer any questions you may have.
            • appjawsundefined
              appjaws @fcwilt
              @fcwilt
              I thought I would take a look at your backup solution.
              I have the plugins installed on my Notepad++ and have connected to the duet via FTP and can see my files.
              I get an error when trying to download a file.
              How do I set up where the file should be copied to?
              How can I download a complete directory?
              This may well be easy but I just can't see it, any ideas?
              Simplify3D 5.1.2
              fcwiltundefined 2 Replies Last reply Reply Quote 0
              • fcwiltundefined
                fcwilt @appjaws
                @appjaws
                I will install NotePad++ and check it out.
                I will get back to you when I have determined how to set it up.
                • fcwiltundefined
                  fcwilt @appjaws
                  @appjaws
                  Well I installed NotePad++ and the FTP plugin.
                  I created a profile according to the online documentation.
                  It connected OK.
                  It listed the folders and contents OK
                  It changed folders OK
                  It tried to download and ALWAYS failed.
                  I tried every setting I could think of and nothing worked.
                  This is not the first time I have encountered an implementation of FTP that didn't work.
                  As you have observed FileZilla works. My editor, EditPad Pro, works. UltraEdit is flaky as can be and I rarely can open a file on the Duet. DirectoryOpus works but it is not an editor but an amazing replacement for Windows FileExplorer.
                  So when some programs work and some don't, I suspect the problem is the program, not the implementation of FTP on the Duet.
                  Perhaps there is a NotePad++ forum you can ask for help?
                  I will keep trying.
                  • fcwiltundefined
                    fcwilt
                    @KenW
                    That problem with zero byte files was something I was able to get the Duet developer(s) to find and fix.
                    So you suspect the problems with NppFTP are in it's code?
                      Phaedrux Moderator @fcwilt
                      @fcwilt said in Backup of user SD card files:
                      NppFTP
                      Is it making too many requests at once?
                      • fcwiltundefined
                        fcwilt @Phaedrux
                        @Phaedrux said in Backup of user SD card files:
                        NppFTP
                        I have no idea. Today was the first time I ever tried NotePad++.
                          This is what makes me think it's the number of concurrent requests since that will make FileZilla fail in the same way if it's not limited to 1 I seem to recall.
                          • fcwiltundefined
                            fcwilt @Phaedrux
                            Could be. I remember that issue coming up when I first tried to use FTP.
                              droftarts administrators
                              @appjaws Is this solved for you now? If you're running in SBC mode rather than standalone, also take a look at this thread: https://forum.duet3d.com/topic/34220/sbc-plugin-to-backup-duet3d-files
                              appjawsundefined 1 Reply Last reply Reply Quote 0
                              • appjawsundefined
                                appjaws @droftarts
                                @droftarts
                                No, I wanted to write a script that would run on a schedule to automatically backup the SD card to my windows computer.
                                At the moment I am mounting the Duet in the windows file system and manually copying all content to a backup location on my PC.
                                Simplify3D 5.1.2
                                stuartofmtundefined 1 Reply Last reply Reply Quote 0
                                  To do that you'd need to setup a command line for RFM and run that on a schedule with windows task scheduler.
                                  • stuartofmtundefined
                                    stuartofmt @appjaws
                                    @appjaws
                                    Hi - I'm curious as to your use-case. Is your need to have the backups on your windows computer for occasional use? e.g. restore / write to an SD card. Or do you have some other use-case.
                                    Part of the reason I ask is that I am the author of the duetBackup plugin and curious if I need / should add additional functionality.
