    Control for “Maslow” style cnc
    Using Duet Controllers
    1.5k
    • o_lampeundefined
      o_lampe @CNCModeller
      @CNCModeller Didn't know a CNC router could work that way...
      Imagine, you would use a CO2 laser tube instead. Placing it vertical would only require the mirror in the lens-holder.
      CNCModellerundefined 1 Reply Last reply Reply Quote 0
      • CNCModellerundefined
        CNCModeller @o_lampe
        @o_lampe they seem to be having good success with their approach. I’m sure the accuracy isn’t as good as a traditional xy cartesian table but if the end product doesn’t require it…
        https://www.kickstarter.com/projects/maslow4/maslow4-affordable-compact-large-format-cnc-router
        Definitely something I’m interested in experimenting with especially if I can keep all of my machines in the same ecosystem.
        Polar Duet3 Mini + 1HCL
        https://youtube.com/playlist?list=PLWjZVEdMv1BY82izahK45qKh-hp3NFkix
        Wanhao D4S: Duet2
        https://forum.duet3d.com/post/296755
        K40 Laser, Duet2
        https://forum.duet3d.com/post/312082
        Wanhao D5S
        https://www.youtube.com/CNCModellerUK
        • o_lampeundefined
          @CNCModeller I'd wait for Maslow CNC V5, which might come with brushless motors and no gearbox?
          //edit
          I know we could use BLDC motors as belt tensioners (simpleFOC in angle mode). That way we could get away with only two motors on the effector. I think something similar was done with the 3D hangprinters, too?
          • o_lampeundefined
            o_lampe
            This thread seems to indicate, that the hangprinter kinematic could be used for a 2D modell.
            But I doubt it, because there are only 3 motors for 2D motion and 1 motor for Z.
            The first Maslow CNC used only two motors and gravity. Maybe thats an option, if you can configure the anchor-points of A+B motor accordingly. (C+D as Dummy?)
            IIRC the whole hangprinter story started with 2D kinematic, you just have to roll back to the basics.
            There's an exemplary hangprinter setup, I'm about to read,
            but I'm not exactly sure if the ABCD definitions in this line: M669 K6 A0.0:-2000.0:0.0 B1732.0:1000.0:0.0 C-1732.0:1000.0:0.0 D2000.0 P1000.0
            are the position of the anchor points?
            Anyway, my curiosity is triggered and I will build a small Maslow style test setup.
            A quick sketch, how I think to solve the belt tensioning problem without putting weight on the effector.
            //edit #2 There has to be another roller on the weight. It's missing in the drawing.
              droftarts administrators
              @CNCModeller Polar (or Polargraph) Drawbots have been doing this for some time: https://www.google.com/search?q=polar+drawbot
              As @o_lampe says, the Hangprinter kinematics should be able to do this (yet to be proved). Alternatively, there's a number of Github projects that you could copy the kinematics from, and add it to RRF.
              Let us know how you get on!
              CNCModellerundefined 1 Reply Last reply Reply Quote 1
              • o_lampeundefined
                o_lampe
                I've drawn another sketch which only needs one belt by using a idler on the bottom of the effector.
                That way I can also reduce the amount of belt-length correction by 50%.
                I was wondering if RRF kinematic handles the difference between calculated and real length (caused by varying angles between fix points and center of effector)? Or is this the reason, why some builders report slacking lines or overtight lines?
                  CNCModeller @droftarts
                  @droftarts that’s interesting, I’m really only wanting to make custom shipping crates from sheets of plywoo. I could just use a large plotter to mark out the cuts and then a jigsaw, obviously being able to do the cutting is a bonus but it wouldn’t be something that’s used every day.
                  Wanhao D4S: Duet2
                  K40 Laser, Duet2
                  Wanhao D5S
                  o_lampeundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                    @o_lampe I like the idea definitely something worth thinking about.
                    Wanhao D4S: Duet2
                    K40 Laser, Duet2
                    Wanhao D5S
                    • o_lampeundefined
                      @CNCModeller said in Control for “Maslow” style cnc:
                      That'll be much more accurate I guess, but the pen would need a bit of downforce to write. Maybe a small vacuum hose on the effector? Or an airbrush instead of a pen? That way you can also put your Logo on the crates or a "Fragile" sign...
                      A diode laser would probably work too, but the lines would be very fine.
                        droftarts administrators @CNCModeller
                        Something like the open source Makelangelo would work: https://www.marginallyclever.com/products/makelangelo-5-huge/
                        It runs on Marlin, so I'd think it would be transportable to Duet: https://www.marginallyclever.com/2021/10/friday-facts-4-how-to-marlin-polargraph/
                        A very old blog post about the kinematics https://www.marginallyclever.com/2012/02/drawbot-overview/
                        His software looks pretty fully-featured for making wall art, too.
                        Alternatively https://www.instructables.com/Polargraph-Wall-Draw-Bot-2023/ has a link to GRBL-Polargraph fork.
                        I'm pretty keen to make one of these, too, in case you hadn't realised... Somehow just need to find the time to see if the Hangprinter kinematics will work, or if we need to lift the Polargraph kinematics from Marlin or GRBL.
                        It would be cool to mount a low power diode laser on something like this to cut custom cardboard packaging, too.
                        o_lampeundefined 1 Reply Last reply Reply Quote 2
                        • o_lampeundefined
                          o_lampe @droftarts
                          @droftarts I started building a test-rig, but without steppers. Just to proove my belt-length correction theory. It's still a lot to compensate, I think I might use a torque-mode BLDC instead of the weight. (simpleFOC driven, since it can be completely independent from RRF)
                          PS: The effector was the first thing I found when looking for a triangle shaped thing. I might make a supercheap sandtable instead.
                          droftartsundefined 1 Reply Last reply Reply Quote 1
                            droftarts administrators @o_lampe
                            @o_lampe Nice. Did it work?! I think what you have nearly made is a CoreXY! The nice thing about the Polarbots is that they only need two pivot points, at the motor. Yours needs a full frame, so it may as well be a CoreXY, perhaps more like https://corexy.com/botofthecloth/index.html
                            What I've noticed from most of the polarbots I've looked at is that there is a linkage for each belt around the centre of the effector, so that it's always a straight line between motor and 'pen' (or spindle). The Makelangelo and Maslow does this, in different ways. More complicated physically, but less computation within the kinematics.
                            • o_lampeundefined
                              o_lampe @droftarts
                              @droftarts Opposite to a CoreXY I don't need linear guides or a crossbeam. The motion is similar, but there's no linear correlation between A+B motors.
                              Until the weekend I'll have a stepper driven rig. Then I can post a video.
                                @o_lampe I just realised the Maslow4 is quite different. The Maslow 1 and 2 (no idea what happened to Maslow 3) were polarbots, with a belt/chain from each top corner, but the Maslow 4 is more like a 2D quad-tower delta, and probably much closer to Hangprinter than previous versions. Again, the Hangprinter kinematics might do this, too.
                                • o_lampeundefined
                                  o_lampe @droftarts
                                  @droftarts Maybe the Maslow_3 was a flop and that's why they again had to kickstart their next project? They even pulled the "Ukraine" card to gain more money.
                                  IMHO the Maslow_4 isn't a good design, using brushed DC motors and expensive ODrive controllers.
                                  I think I figured out how to trick RRF to do the correct calculations without rotating belt links. It's similar to Delta-kinematics, where we have to measure rod length and horizontal distance between towers and effector.
                                  I just have to measure the horizontal distance from motorshaft (minus pulley radius) to the fixed link on the effector. Will add it in my next picture for reference.
                                  PS: I like the BotofTheCloth idea with it's strap-on corners. For a plotter or laser it might be good enough: Just buy a 8' x 6' plywood sheet and clamp the motors and idlers directly. No need for a permanent frame which only occupies workspace 99% of the time.
                                    @o_lampe said in Control for “Maslow” style cnc:
                                    PS: I like the BotofTheCloth idea with its strap-on corners. For a plotter or laser it might be good enough: Just buy a 8' x 6' plywood sheet and clamp the motors and idlers directly. No need for a permanent frame which only occupies workspace 99% of the time.
                                    I had exactly the sam thought, personally the idea of having all of the moving parts in the plotter carriage with just a fixed anchor point at the corner of the 8x6 sheet would be ideal. Literally just put a screw in each corner and attach the belts, calibrate, and you’re r away. Ideally everything would retract into the plotter carriage for storage.
                                    I also like the idea of a diode laser to mark out for manual cuts and labelling.
                                    I could even see a larger version being used to layout where you put holes for steelwork or walls etc on a building concrete slab during construction.
                                    All interesting stuff…
                                    Wanhao D4S: Duet2
                                    K40 Laser, Duet2
                                    Wanhao D5S
                                    • o_lampeundefined
                                      o_lampe
                                      I added steppers and a central tightening winch. The idea of the hidden weight is not too good, because it would almost move the same as if it was connected directly to the effector.
                                      This way it won't work with the strap-on corner idea, unless you are willing to drill 3 holes in the 8x6 everytime.
                                      • o_lampeundefined
                                        o_lampe
                                        I tried my luck and modified config for a 2D hangprinter.
                                        It seems RRF3.4.6 already has the latest version of HP-kinematics. It is oddly specific regarding spool diameter and all.
                                        m98 p"config.g"
                                        Error: Wrong number of values after '''D''', expected 3
                                        Q:Buildup fac 0.0070
                                        R:Spool r 75.00, 75.00, 75.00, 75.00
                                        U:Mech Adv 2, 2, 2, 4
                                        O:Lines/spool 1, 1, 1, 1
                                        L:Motor gear teeth 20, 20, 20, 20
                                        H:Spool gear teeth 255, 255, 255, 255
                                        J:Full steps/rev 25, 25, 25, 25
                                        HTTP is enabled on port 80
                                        FTP is disabled
                                        TELNET is disabled
                                          @o_lampe What are the commands you are using to define it? I'd imagine that the C and D motors don't really matter in M669. Are the other values set in firmware? That might rather limit the usefulness of the Hangprinter kinematics.
                                          • o_lampeundefined
                                            o_lampe @droftarts
                                            @droftarts I figured, I could use any two of the ABC motor to define a 2D plane. So I took the BC motors, because they already defined the left and right corner. (A motor is the front/center motor)
                                            Here's the basic config.g, but I don't know how to match XY with ABCD or how to define a tool for a plotter
                                            G90                                                    ; send absolute coordinates...
                                            M83                                                    ; ...but relative extruder moves
                                            M550 P"Hangprinter_2D"                                     ; set printer name
                                            M669 K6 A0.0:220.0:0.0 B-220.0:220.0:0.0 C220.0:220.0:0.0 D2000.0 P100.0 Q0.0 R1
                                            M666 X0 Y0 Z0                                          ; put your endstop adjustments here, or let auto calibration find them
                                            M552 S1                                                ; enable network
                                            M586 P0 S1                                             ; enable HTTP
                                            M586 P1 S0                                             ; disable FTP
                                            M586 P2 S0                                             ; disable Telnet
                                            M569 P0 S0                                             ; physical drive 0 goes forwards
                                            M569 P1 S0                                             ; physical drive 1 goes forwards
                                            M569 P2 S0                                             ; physical drive 2 goes forwards
                                            M569 P3 S0                                             ; physical drive 3 goes forwards
                                            M584 A0 B1 C2 D3                                             ; set drive mapping
                                            M350 A16 B16 C16 D16 I1                                ; configure microstepping with interpolation
                                            M92 A200.00 B200.00 C200.00 D0                       ; set steps per mm
                                            M566 A900.00 B900.00 C900.00 D1200              ; set maximum instantaneous speed changes (mm/min)
                                            M203 A24000.00 B24000.00 C24000.00 D4800            ; set maximum speeds (mm/min)
                                            M201 A4000.00 B4000.00 C4000.00 D1000               ; set accelerations (mm/s^2)
                                            M906 A200 B400 C400 D200 I70                        ; set motor currents (mA) and motor idle factor in per cent
                                            M84 S10                                                ; Set idle timeout
                                            M208 X-100:100 Y-100:100 Z0:10
                                            M563 P0                                           ; define tool 0
                                            G10 P0 X0 Y0 Z0                                       ; set tool 0 axis offsets
                                            M911 S20 R22 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"     ; set voltage thresholds and actions to run on power loss
                                            T0                                                     ; select first tool
                                            //edit OK, I guess I found the reason for one of the errormessages: "D" on has one parameter in my config, but needs three....
                                            YES, that solved most of it, although I still don't know, if I have to map AB drives to XY axes? I guess it should be done automatically by the kinematic model?
