    Duet 2 Ethernet disconnect when printing and paneldue connected
    PanelDue
    2.4k
      I'd be curious to see what happens if you went back to an older version of the PanelDue firmware like 1.24
      https://github.com/Duet3D/PanelDueFirmware/releases/tag/1.24
      edspedundefined Shokiundefined 2 Replies Last reply Reply Quote 0
      • edspedundefined
        edsped @Phaedrux
        @Phaedrux Not so sure it will help. I believe I went through just about every firmware when I was fighting this. The only thing I didn't do was update over USB until I got the 6HC. I'm going to follow this as I putzed with it for almost a year before tossing in the towel.
        • Shokiundefined
          Shoki @Phaedrux
          @Phaedrux I will not be able to try this before mid november as I have vacation and then I will see you at Formnext.
          • edspedundefined
            edsped
            Now I'm racking my brain to think of anything I did differently going from the wifi to the 6HC and the only other thing I can think of and it may be minor is that I switched from a flat 4 wire cable to a twisted left over from a stepper motor. That being said I switched between the 4 wire and the ribbon cable when trying to troubleshoot the WiFi but I did not use new wires for the 4 wire setup. What I'm currently running...
              dc42 administrators @edsped
              All, thanks for reporting this. I suspect that something is causing PanelDue to repeatedly retry a request for the object model, causing the GCode processor to be overloaded with M409 requests. We are looking into it. Meanwhile, if anyone encounters this please report:
              • RRF firmware version on the main board
              • PanelDue firmware version
              • What baud rate you are using for the PanelDue (the default 57600, or something else)
              • What status the PanelDue is showing after it happened (Idle, Connecting, something else, or alternating between two or more values)
              • Anything you did (e.g. command you sent to the machine) that appeared to trigger this happening.
              • dc42undefined dc42 referenced this topic
                dc42 administrators @dc42
                All, please download and install the appropriate build of PanelDueFirmware from https://www.dropbox.com/scl/fo/krqc6189we080r638jrwn/h?rlkey=80p7daqhs67630djtfs2pqwlj&dl=0 and see if it solves the problem.
                edspedundefined Shokiundefined Leonard03undefined 3 Replies Last reply Reply Quote 0
                • edspedundefined
                  edsped @dc42
                  @dc42 said in Duet 2 Ethernet disconnect when printing and paneldue connected:
                  Sorry if I wasn't clear but I've moved from the Duet 2 WiFi to the Duet 3 6HC with SBC and the problem seems to be resolved. That being said no printing information is displayed in the 7i console.
                  Also, I always ran the 7i with standard baud rate. Let me know if you still want me to install the firmware above.
                  • Shokiundefined
                    Shoki @dc42
                    @dc42 I will try it when coming back after Formnext. See you there.
                    • Leonard03undefined
                      Leonard03 @dc42
                      @dc42 for me seems that made a big difference. Not a single drop in DWC into a 7 hours print so far
                      edspedundefined dc42undefined 2 Replies Last reply Reply Quote 0
                      • edspedundefined
                        edsped @Leonard03
                        @Leonard03 Keep me posted as if the firmware fixes your issue then my Duet 2 WiFi should be okay and
                        • Exerqtorundefined Exerqtor referenced this topic
                          dc42 administrators @Leonard03
                          @Leonard03 thanks for that.
                          @Shoki please let me know when you have had a chance to test the new PanelDueFirmware.
                          edspedundefined 1 Reply Last reply Reply Quote 0
                          • Shokiundefined
                            Shoki
                            @dc42 I just tried it.
                            This did not make a difference for me.
                            The firmware was correctly installed and the name displayed on the Paneldue corresponds to the one you provided.
                            • edspedundefined
                              edsped @dc42
                              @dc42 Has there been any more work on this? I switched from a 6HC w/SBC to 6HC standalone and sure enough the disconnects are back. Unlike using the built in WiFi on the Duet 2 that was giving me disconnects I have the 6HC connected to a Trendnet AC1200 Wireless bridge via ethernet. The big difference between SBC and non SBC is that the PanelDue reports all activity in the console in standalone mode and reported nothing in SBC mode.
                              Shokiundefined 1 Reply Last reply Reply Quote 0
                              • Shokiundefined
                                Shoki @edsped
                                @edsped I have added an on/off switch on my PanelDue so I turn it off when I don't use it. Hardware solution to a software problem.
