    Hollow shaft extruder
    345
    44.2k
    • rqthreeundefined
      rqthree @fma
      @fma said in Hollow shaft extruder:
      @rqthree There is a problem with these files: Carrier_Assy.FCStd and Knife_Bearing.FCStd ; I'm unable to open them, neither other people at my hackerspace (they freeze or crash FreeCAD).
      Could you save them as STEP files?
      Thanks,
      The files are fine, but were generated with a very high definition version of FreeCad. They will eventually open, but may take many minutes on a pretty high power workstation. In any case, the two files you reference are not at all important, and just show the over-all arrangement of parts.They don't contain any critical dimensions or data not seen in the other files.
      fmaundefined 1 Reply Last reply Reply Quote 0
      • fmaundefined
        fma @rqthree
        @rqthree Ok, I see!
        Frédéric
        • fmaundefined
          fma
          @rqthree BTW, how do you get the sharp edge on the flanged bearing? With a lathe?
          Frédéric
          rqthreeundefined 1 Reply Last reply Reply Quote 0
          • rqthreeundefined
            rqthree @fma
            @fma , yes, I use a collet chuck in a jewelers lathe, with an abrasive disc on a rotary tool. Others, like Tom Brazier, have come up with clever methods that don't require a lathe.
            • fmaundefined
              fma @rqthree
              @rqthree Thanks, I'll read the entire thread again to see how other guys do...
              Frédéric
              • rqthreeundefined
                rqthree @o_lampe
                @o_lampe said in Hollow shaft extruder:
                @rqthree The left/right rotation is a good idea.
                Otherwise It is a bit similar to my dual motor approach, but I'll put a Bowden tube between the two. No weight panelty and free choice for the remote motor.
                I'm also a bit worried about temperatures and sketched up a thin watercooling plate to fit between your motors. A bit more weight doesn't make much of a difference, you already fouled there anyway 🙂
                The dual motor Push-Me-Pull-You VDE works fine at 0.2 amps driving two paralleled NEMA 11 motors. The motors get slightly warm after several hours of continuous operation, but nothing that affects even PLA.
                • tombrazierundefined
                  tombrazier
                  @rqthree I vote we call this push pull version VDE337.
                  • rqthreeundefined
                    rqthree @tombrazier
                    @tombrazier said in Hollow shaft extruder:
                    Tom, I have to ask...??? I know there is always a method to your madness, but I have wracked my brains on this one.
                    EDIT: Never mind, you Cessna driver. VDE337 it is!
                      tombrazier
                      Some updates from me...
                      I have experimented further with the LDO motor. For everything other than ridiculously fast printing it's great. The primary limitations I have found are that continuous current much above about 600mA will eventually cause it to get too hot for PLA and at any current E jerk needs to remain quite low (e.g. max 7mm/s) for the VDE which has quite a high steps/mm ratio. On the other hand it has great acceleration and speed, I can get 1000mm/s/s even with the high step/mm count of VDE and top speed is about 60mm/s (with no load) and over 10mm/s driving filament into the hot end.
                      One day I might figure out how to get TMC CoolStep to help with the current. And I have dreams of implementing a jerk-less version of Linear Advance in Marlin which would pretty much remove the jerk limit as an issue.
                      In other news, I have uploaded a video about the bearing grinder jig.
                      And, further news, with a PLA printed carrier the 3 back-to-back bearing pairs version of the extruder seems to work pretty well. I have used a bite of 0.07mm for this version. @o_lampe it works a lot better than with your printed carriers which leaves me wondering whether something like material flexibility might be an issue. I am also coming to the conclusion that it's best to grind the bearings first and then measure them and print a carrier to match their edge diameter. That's a lot easier than grinding an edge down to the exact diameter.
                      o_lampeundefined 1 Reply Last reply Reply Quote 2
                      • o_lampeundefined
                        o_lampe @tombrazier
                        Both precedures aren't mass-production friendly. The skrewder wraps the screws around the filament which results in adjustable bite and fast changeable filament ability.
                        If we could change the VDE100 design to be wrappable, it would be best of both worlds.
                        • rqthreeundefined
                          rqthree @o_lampe
                          I must respectfully disagree on both counts. Holding sub-micron tolerances is common practice in manufacturing these days, and the VDE does not need "adjustable bite" and "fast changeable filament ability". It already does these things by design, albeit perhaps serendipitously.
                          I believe that one must be very conscious of the goals of a particular idea, declare victory when achieved and then move on, rather than try to force fit what has worked before into what is needed now.
                          Personally, I believe that increases in FDM printing speeds will only come from smaller diameter filament. All existing extruders (the VDE included) are limited in their extrusion rate by how quickly you can melt a column of plastic 1.75mm in diameter.
                          oliofundefined 1 Reply Last reply Reply Quote 2
                          • oliofundefined
                            oliof @rqthree
                            @rqthree "being done is a decision" that must be made. Kudos!
                            tombrazierundefined 1 Reply Last reply Reply Quote 0
                              tombrazier @oliof
                              @oliof said in Hollow shaft extruder:
                              Yeah, rq3's comments struck a chord with me too.
                              • CNCModellerundefined
                                CNCModeller
                                Hi All,
                                I’ve just finished for the holiday break and wanted to look at the hollow shaft extruder, is there a good consolidated reference material somewhere on the web?
                                I specifically want to order some flanged bearings to go with the carriers I already have but I can’t find the specs… unfortunately I don’t have time to dig into the thread befor Xmas but I want to order parts to grind the flanges and tinker with between Xmas and new year.
                                Any thoughts would be greatly appreciated.
                                Many thanks
                                Barry M
                                Polar Duet3 Mini + 1HCL
                                https://youtube.com/playlist?list=PLWjZVEdMv1BY82izahK45qKh-hp3NFkix
                                Wanhao D4S: Duet2
                                https://forum.duet3d.com/post/296755
                                K40 Laser, Duet2
                                https://forum.duet3d.com/post/312082
                                Wanhao D5S
                                https://www.youtube.com/CNCModellerUK
                                CNCModellerundefined 1 Reply Last reply Reply Quote 0
                                  CNCModeller @CNCModeller
                                  Update - I’ve ordered 8x3x4mm flanged deep groove bearings, hopefully I’ve made the right choice… please let me know if I should order something else… 🙂
                                  Wanhao D4S: Duet2
                                  K40 Laser, Duet2
                                  Wanhao D5S
                                  • oliofundefined
                                    oliof @CNCModeller
                                    @CNCModeller you can find Tom's stuff at https://www.printables.com/model/268255-vde100-rotary-extruder and rqthrees at the reprap forums ( no link at hand it easy to find).
                                    CNCModellerundefined 1 Reply Last reply Reply Quote 1
                                      CNCModeller @oliof
                                      @oliof Thanks for the heads up, I’ve now ordered the correct bearings! Looks like I will be ready to tinker when I get the chance 🙂
                                      Wanhao D4S: Duet2
                                      K40 Laser, Duet2
                                      Wanhao D5S
                                        CNCModeller
                                        General question, so we grind the bearings back to 9.1 mm, how much intersection with the filament does that result in? Or to put it another way, how much do the flanges bite into the surface?
                                        Also how significant is the drag / twist on the filament, does the contra rotating pair of blade sets make a significant difference? I’m assuming there is an amount of backlash like behaviour due to the twisting effect.
                                        Any thoughts would be appreciated
                                        All the best Barry M
                                        Wanhao D4S: Duet2
                                        K40 Laser, Duet2
                                        Wanhao D5S
                                        rqthreeundefined tombrazierundefined 2 Replies Last reply Reply Quote 0
                                        • rqthreeundefined
                                          rqthree @CNCModeller
                                          @CNCModeller, less is better. As Tom said, it may be better to print a carrier that works with the bearing flange diameter that you've made.
                                          Playing with the VDE-337 (which I won't pursue anymore), it became even more apparent that a gentle kiss of the knife edge (0.1 mm or 0.004 inch) is about ideal.
                                          If you are printing the carriers, plain PLA is infinitely better than anything else, at least in the short term. PLA is very stiff, and acts very much like aluminum as regards machining, drilling, tapping, etc. It's just not tolerant of higher temps, and cold flows over time under pressure.
                                          Filaments like PETG are, in my experience, way too "rubbery" to make a bearing carrier of any use in this application.
                                          I have had all of my carrier designs CNC milled from 7075 aluminum to avoid these effects, since we are talking about micron level precision, and just today finished an exercise regarding print surface finish versus extruder knife edge bite depth.
                                          Results: again, the less, the better.
                                          I never intended for this to be a high speed extruder. I intended it to be a very accurate and reproducible extruder.
                                          Regards,
                                          Rip
                                          o_lampeundefined 1 Reply Last reply Reply Quote 1
                                          • o_lampeundefined
                                            o_lampe @rqthree
                                            @rqthree said in Hollow shaft extruder:
                                            ...which is a pity, because it's the lightest DD-extruder ever.
                                            Regarding print-speed on my Delta it can almost compete with a flying extruder setup, but with better ooze control.
                                            I think it deserves to up the speeds a bit. With my BLDC/simpleFOC extruder I can go 120-150mm/s before I see underextrusion.
