    Duet3D announces new tool board at FormNext
    107
    8.8k
      deckingman
      It matters not a jot to me whether you believe me or not because I know for a fact that my bed is both flat and level within +- 0.03mm at any point over the entire surface, and that I can print edge to edge with no firmware compensation of any kind.
      Except that maybe you are calling me a liar to which I object very strongly.
      This video was shot many years ago using the exact same build plate and before mesh compensation had been added to the firmware. Also, I use a single motor and continuous belt driving 3 lead screws so automatic bed leveling is not possible.
      https://youtu.be/U733PMTou7M?si=cgGvQHLgwxZdXike
      How do you explain that if I'm the liar that you are implying that I am?
      Surgikillundefined 1 Reply Last reply Reply Quote -1
        deckingman @fcwilt
        @fcwilt said in Duet3D announces new tool board at FormNext:
        @deckingman said in Duet3D announces new tool board at FormNext:
        Either you haven't used cast machined tooling plate
        The flatness of typically available plate is appx 0.40mm for plate less than 12mm thick. For 12mm or thicker it drops to appx 0.14.
        So what did you use to obtain 0.03?
        My machinist has nothing as flat as that.
        I used this https://www.aluminiumwarehouse.co.uk/collections/plate-cut-to-size/products/12-mm-aluminium-cast-tooling-plate
        The tolerance is usually quoted as the cast plate tolerance prior to machining and covers the entire sheet size (usually 1.2M x 2.4M). So a 400m x 40mm machined section will always be more flat than the quoted tolerance.
        Most "keyboard engineers" think that anything bought to a specified tolerance WILL vary by that tolerance whereas the tolerance is the MAXIMUM variation that the supplier uses to be able to guarantee the product.
        According to my DTI, mine is actually flat better than +_ 0.01mm. The +_ 0.03 variation is due to imperfection in levelling (which I could get better if I spent more time tramming the gantry).
        • o_lampeundefined
          o_lampe @Surgikill
          @Surgikill said in Duet3D announces new tool board at FormNext:
          Toolboards are primarily made for tool changer setups, so multiply your cost difference by the number of toolheads.
          I'm not entirely sure if you'd need a scanning probe on every tool head? If I understood Tony correctly, they are also working on a nozzle coil which would be stationary and after a toolchange you'd level your nozzle there (just like the contact probes on CNC machines)
          • Surgikillundefined
            Surgikill @deckingman
            @deckingman in your video that you linked your dial indicator shows +0.04 and - 0.03 as the maximum and minimum values. It's there pain as day.
            I never said you were lying, but your flatness tolerance is wrong by definition. It's either 0.07mm, according to the video, or 0.06mm according to you. A +/- is not applied to a flatness tolerance. If you only measured those 5 points in the video then it's really a moot point.
            I'm not trying to sound pompous, but I'm a degreed mechanical engineer, not a "keyboard engineer". Using the wrong terminology can be misleading at best and disingenuous at worst. Instead of getting emotional about being incorrect, it would be beneficial to everybody if you used it as a learning opportunity. Nobody is perfect, myself included.
            deckingmanundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
              deckingman @Surgikill
              @Surgikill So what if I made a mistake and it should have been 0.07mm rather than 0.06mm? If you had watched the video to the end, you'd have seen the part where I explained that I thought this would be tram and level enough (as was later proven to be the case) to get perfect first layers over the entire area of the build plate, but that I could spend a bit more time getting even better if necessary.
              The reason for only showing photos of those 5 points is because the video was about tramming the gantry with respect to the bed and not specifically about measuring flatness. The clue was in the title "...............installing the Z stage and getting it level and "tram"..........." I had already established that the plate is as near dammit perfectly flat.
              You can split hairs all you like but the point is that I can print edge to edge with perfect first layers without using mesh compensation. I can't help it if people like you don't believe me.
              • fcwiltundefined
                fcwilt @Surgikill
                @Surgikill
                I went and checked the video.
                With the DI attached to the XY gantry how would you tell the what was responsible for whatever reading was displayed? Could not imperfections in the gantry contribute to the reading?
                deckingmanundefined Surgikillundefined 2 Replies Last reply Reply Quote 0
                • fcwiltundefined
                  fcwilt @deckingman
                  @deckingman
                  I forgot to ask you what sort of surface do you print on? Directly on the metal plate or something added on top of it?
                    deckingman @fcwilt
                    @Surgikill
                    You could direct your questions to me rather than via a third party.
                    But for sure if the gantry sagged it could imply that the bed was bowed or "dish shaped". My calculations showed that any deflection of the gantry due to the weight of the hot end was insignificant and the rails were known to be straight. But the important thing to note is how flat and level is the build platform with respect to the full range of movement of the nozzle. By fitting the DTi to the gantry where the nozzle is mounted, one is checking both the gantry and the build plate. If there was an unacceptable deviation, then one would carry out further measurements on the individual components to determine where the problem was. But it's a lot quicker to check the entire mechanism in its normal working configuration and only break that down into individual components if an unacceptable deviation is observed.
                      deckingman @fcwilt
                      @deckingman
                      Glass. 6mm thick plane float glass. I learned long ago that the process of having the glass toughened leads to unacceptable distortion. And yes before you ask, I checked the flatness. I've tried most other build surfaces but haven't yet found one that beats plane untreated, "hot swappable" float glass (with a little help from 3DLac now and then) and I'm still using the same 3 sheets that I bought about 7 or 8 years ago.
                        Surgikill @fcwilt
                        @fcwilt the gantry can contribute or offset the readings. Aluminum extrusion tolerance is terrible, straightness of 0.0125" per foot. Hence why measuring at 5 points and then assuming that those points will simultaneously be the highest and lowest measured points isn't really the right way to go about it. Even measuring the flatness of the build surface while on the machine isn't really correct, because you don't know if it's your gantry or your plate causing the inconsistencies.
                        If you are printing at 0.2mm layer height, there is a pretty large variation of z height you can get away with. As you try to increase resolution the problems will begin to show themselves. This is why mesh compensation is used.
                          Surgikill @Surgikill
                          @dc42 can you give us the exterior dimensions of the board? I'm trying to see how it will fit in my printer.
                          I threw some pictures up in CAD and scaled them, looks like board width is around 45mm without connectors, and board height is around 50mm without connectors.
                            dc42 administrators @Surgikill
                            @Surgikill I expect we will publish drawings and models next week.
                            Surgikillundefined 1 Reply Last reply Reply Quote 3
                            • o_lampeundefined o_lampe referenced this topic
                            • nikschaundefined
                              nikscha @elmoret
                              @elmoret Nothing stopping you from using a 24V heater at 36V XD
                              You'd get 2.25 times more power out of it!
                              (and a fire hazard lol)
                              Stay in school
                                Surgikill @dc42
                                @dc42 any update on this?
                                  @Surgikill not yet, Tony normally does the drawings and STEP models but he is very busy with Formnext follow-up and SMRRF preparation.
                                  • edspedundefined
                                    edsped @Surgikill
                                    @Herve_Smith
                                    You consider the prices to be an issue?
                                    The money I spend on hardware is dwarfed by the money I spend on filament.
                                    Toolboards are primarily made for tool changer setups, so multiply your cost difference by the number of toolheads. I'm currently building a tool changer, and each toolhead is going to run me close to $400. At some point, cost becomes a favor. When my toolhead alone is over double the cost of an ender 3 you have to take a step back and reevaluate.
                                    I run RRF-36's on my toolchanger and wish I set it up that way sooner.
                                    Surgikillundefined gnydickundefined 2 Replies Last reply Reply Quote 1
                                      Surgikill @edsped
                                      @edsped those actually look like they might work perfectly. A ton cheaper too.
                                      edspedundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                                      • edspedundefined
                                        edsped @Surgikill
                                        No issues on my end so far but I have to admit I'm intrigued by the scanning probe but at more than twice the price for the board not sure if it would be worth it.
                                        Surgikillundefined 1 Reply Last reply Reply Quote 0
                                        • fcwiltundefined
                                          fcwilt @Surgikill
                                          But they are a funny shape. Who wants a printer with parts that have a funny shape. Give me a good old rectangle every time. 🤣
                                            Surgikill @edsped
                                            @edsped Scanning probe would be good. I guess I could have one toolhead with a scanning probe and a euclid probe, and use either depending on the build surface, then do the rest with a fly-rrf-36.
                                            @fcwilt 🤣 Although, I do like that most of the connectors are along the bottom edge, and the stepper is along the top. Connectors along the sides have been a real pain for me designing slim toolheads so I can increase tool capacity.
