    Orca slicer and Duet
    14
    3.4k
    • buttonundefined
      button @oliof
      I'm using OrcaSlicer for 3 months and pirint looks briliant. Same settings, copied from SuperSlicer and quality is flawless
      omniundefined 1 Reply Last reply Reply Quote 1
      • omniundefined
        omni @button
        @button Thanks, good to know. I was hesitant to try it out since it looks mainly Klipper oriented, but I'm gonna go ahead and set it up...
        • br7408undefined
          br7408
          Late to the game here, but I am having reasonable success with Orcaslicer. Having experience with Cura & SS, It seems to do very well right out of the box at managing gap fill line widths and flow. Overhangs and especially supports are done extremely well with no tuning required. I still prefer SS for the plethora of features, but I have yet to get SS tuned optimally for all conditions and materials.
          My issues with Orcaslicer:
          • There is a Reprap bug which prevents the individual feature acceleration settings to be applied, so one must stick with the firmware accel settings. I have confirmed this bug in the g-code. This feature would be a huge benefit if they could fix it. This issue has been acknowledged by the developer but no fix yet.
          • The line based calibration PA test will not work on a large bed with bed center 0/0 origin coordinates. It still wants to push the test off the plate as if the 0/0 origin was in the front left. Examining the g-code validated this.
          • ctilley79undefined
            ctilley79 @oliof
            @oliof said in Orca slicer and Duet:
            @omni it doesnt work without Bambulabs' proprietary libraries so I am very wary about this poisoning of an open source project with binary blobs.
            You sure? I'd like to investigate this myself. Are you sure the binary blobs aren't specific to the bambu printers themselves? They mentioned that the tweaked slicer algorithms were open sourced and had to be to satisfy those license requirements
            oliofundefined 1 Reply Last reply Reply Quote 1
            • oliofundefined
              oliof @ctilley79
              @ctilley79 I am sure: You cannot run OrcaSlicer without the bambulabs libraries, and those aren't available in source last I checked.
              • br7408undefined
                br7408
                Per my last post, I can confirm the latest Orcaslicer (1.8 RC) now has individual feature jerk settings working as advertised with Reprap. I did not see an entry in the release notes addressing it.
                I incorrectly called it acceleration on my last post.
                Notepadundefined 1 Reply Last reply Reply Quote 0
                • Notepadundefined
                  Notepad @br7408
                  @br7408 There is a minor bug currently where selecting RepRap as the Gcode flavour will hide the "Motion ability" tab
                  To overcome this. You just need to select a different Gcode flavour (I recommend Marlin 2 as it unlocks all the features). Then save and select a new machine.
                  Selecting the new machine forces the window to refresh the list at the top, and then reselecting the prvious machine keeps the motion ability tab visible.
                  Change all the settings you want, and then reselect RepRapFirmware as the Gcode flavour.
                  The real bamboo printer manufacturer
                  br7408undefined 1 Reply Last reply Reply Quote 0
                  • br7408undefined
                    br7408 @Notepad
                    @Notepad
                    Thanks, I will check that out.
                    • SDJundefined
                      SDJ
                      I switched over to Orca Slicer when it looked like SuperSlicer had be abandoned after no updates since March. But I found a Sept post from the creator that says he is going to work on SS full time starting this month. I hope it's true.
                      From this post: https://github.com/supermerill/SuperSlicer/discussions/3902
                      • omniundefined
                        omni @SDJ
                        @SDJ
                        If that is true, it's really good news. It sure seemed like it had become abandonware.
                        I definitely prefer Superslicer to anything else I've tried.
                        Each slicer has some things that are cool, and others that are kind of annoying or lacking, but SS was definitely the sweetspot, at least for me.
                          jay_s_uk @omni
                          @omni @SDJ
                          you can see work has begun here https://github.com/supermerill/SuperSlicer/commits/nightly_dev
