    Scanning Z probe support in RRF 3.5
    Beta Firmware
    23
    128
    10.0k
    • flyschaundefined
      flyscha @flyscha
      Hey guys, I hope everyone had a great Christmas.
      Unfortunately, I'm still stuck on the same issue. No progress with the Scanning Z Probe working how it should (calibrating, scanning, etc).
      I'm getting a few hundred i2c bus errors when I run the M122 command (see a few posts above). Most of the forum posts I've found about i2c problems seem to be when connecting Duet with Duex, but in my case I just have the 6HC board along with the Scanning Z Probe.
      Any help would be greatly appreciated.
      gloomyandyundefined 1 Reply Last reply Reply Quote 0
      • gloomyandyundefined
        gloomyandy @flyscha
        @flyscha Over what period do you get "a few hundred i2c bus errors"? Run M122 b69 then wait say 5 minutes then run M122 b69 and see how many errors (if any) that you get.
        flyschaundefined 1 Reply Last reply Reply Quote 0
        • flyschaundefined
          flyscha @gloomyandy
          @gloomyandy Thanks for the reply.
          When I fire up the machine and I'm trying to get the SZP to calibrate, I get between 150-400 I2C bus errors when I run M122 B69. Letting it sit there for 5 minutes without touching anything, I2C bus errors are over thousand:
          m122 b69
          Diagnostics for board 69:
          Duet SZP firmware version 3.5.0-rc.2 (2023-12-14 08:58:41)
          Bootloader ID: SAMC21 bootloader version 2.10 (2023-11-16)
          All averaging filters OK
          Never used RAM 14496, free system stack 124 words
          Tasks: HEAT(2,nWait,0.1%,131) CanAsync(5,nWait,0.0%,55) CanRecv(3,nWait,0.0%,79) CanClock(5,nWait,0.0%,67) ACCEL(3,nWait,0.0%,53) MAIN(1,running,99.7%,432) IDLE(0,ready,0.0%,27) AIN(2,nWait,0.2%,92), total 100.0%
          Last reset 00:44:51 ago, cause: power up
          Last software reset data not available
          Peak sync jitter 1/5, peak Rx sync delay 202, resyncs 0/0, no timer interrupt scheduled
          VIN voltage: min 4.9, current 5.0, max 5.0
          MCU temperature: min 18.8C, current 24.3C, max 24.3C
          Last sensors broadcast 0x00000000 found 0 30 ticks ago, 0 ordering errs, loop time 0
          CAN messages queued 1181, send timeouts 0, received 2612, lost 0, errs 0, boc 0, free buffers 18, min 18, error reg 0
          Accelerometer: LIS2DW, status: 00
          Inductive sensor: raw value 39786813, frequency 3.71MHz, current setting 18, ok
          I2C bus errors 1097, naks 0, contentions 0, other errors 0
          This could be normal for all I know, I'm just grasping for straws currently.
          Thanks!
            dc42 administrators @flyscha
            @flyscha we've traced and fixed the bug that was causing lots of I2C errors on some SZP boards. Please try the SZP firmware build at https://www.dropbox.com/scl/fo/8mwsfwo61tacbyxsu39j9/h?rlkey=zwyd8luhpj7hnanldm4rzm5om&dl=0. It's compatible with main board firmware 3.5.0-rc.2.
            • flyschaundefined
              flyscha @dc42
              @dc42 Thank you for the update! I deleted the Duet3Firmware_SZP.bin file from my SBC's SD card, and put the new file in its place.
              Regarding the other files from your link, (SZP.map, TOOL1RR.bin, and TOOL1RR.map), do I need to upload/replace those somewhere as well?
              Just checking because the SZP Documentation page just mentions the Duet3Firmware_SZP.bin file being needed.
              With only the SZP.bin file replaced, I'm still getting the same errors of:
              -Error: sensor error during calibration
              -Error: Bad reading from scanning probe - try recalibrating the probe
              Here are the diagnostics as well:
              m122 b69
              Never used RAM 14496, free system stack 136 words
              Tasks: HEAT(2,nWait,0.1%,131) CanAsync(5,nWait,0.0%,55) CanRecv(3,nWait,0.0%,79) CanClock(5,nWait,0.0%,67) ACCEL(3,nWait,0.0%,53) MAIN(1,running,99.7%,434) IDLE(0,ready,0.0%,27) AIN(2,nWait,0.2%,92), total 100.0%
              Last reset 00:06:13 ago, cause: software
              Peak sync jitter 1/5, peak Rx sync delay 207, resyncs 0/0, no timer interrupt scheduled
              MCU temperature: min 24.9C, current 25.2C, max 25.3C
              Last sensors broadcast 0x00000000 found 0 76 ticks ago, 0 ordering errs, loop time 0
              CAN messages queued 1972, send timeouts 0, received 3785, lost 0, errs 0, boc 0, free buffers 18, min 18, error reg 0
              Inductive sensor: raw value 42133425, frequency 3.92MHz, current setting 13, ok
              I2C bus errors 1344, naks 3, contentions 0, other errors 0
              Thanks!
                jay_s_uk @flyscha
                @flyscha that shows your board hasn't updated. the build date is still the RC2 release, not the latest one from dc42
                flyschaundefined 1 Reply Last reply Reply Quote 1
                • flyschaundefined
                  flyscha @jay_s_uk
                  @jay_s_uk I'm seeing what you're seeing as well, where it's still showing the older version.
                  Given that, the beginning of my last post seems to be the culprit:
                    jay_s_uk @flyscha
                    @flyscha you don't need those. the board i have here flashed ok
                    • flyschaundefined
                      flyscha @jay_s_uk
                      @jay_s_uk Ok thanks! Are you using an SBC?
                      jay_s_ukundefined 2 Replies Last reply Reply Quote 0
                        jay_s_uk @flyscha
                        @flyscha no, standalone
                          jay_s_uk @flyscha
                          @flyscha if you're using DWC to upload it should ask you to update. if you're pulling the SD card and loading the file you'll need to send M997 B69
                          • flyschaundefined
                            flyscha @jay_s_uk
                            @jay_s_uk Thank you! I for sure ran the M997 B69 after replacing the .bin file on the SD card last night, but maybe something got mixed up when moving bin files around.
                            I'll try it all again tonight. Much appreciated!
                            • flyschaundefined
                              flyscha @flyscha
                              @jay_s_uk I tried over and over and over and somehow FINALLY the firmware updated! I must have tried 5 or 6 times, and it just so happened to stick. I won't speak too loudly or else it may scare it back to the previous version.
                              @dc42 The new firmware was absolutely the fix for me! Now when I run the M122 diagnostics, I get 0 I2C bus errors. Every now and then there are a few naks (always 0 or 3), but that's about it.
                              When sending the G29 command, I now get scanning probe coefficients, and the entire bed scans without any stops, errors, or hiccups.
                              Thanks for everyone's help!
                                @flyscha I'm glad it's working for you.
                                • becky9undefined
                                  becky9
                                  Where can I get the scanning probe in the UK at the moment? Looked on E3D & Ooznest can't see it x
                                  • tkamskerundefined
                                    tkamsker
                                    @dc42 said in Scanning Z probe support in RRF 3.5:
                                    https://www.youtube.com/watch?v=969s3J8EEyM
                                    Hi i might being late to that thread but i have an (several) duet 2 boards and i would love to upgrade my E3D tool changer to that Z-Probe so question how is that possible ? i see all infos refer to Duet 3 board ,. i would love to not totally rework my printers thx thomas
                                    jay_s_ukundefined dc42undefined 2 Replies Last reply Reply Quote 0
                                      jay_s_uk @tkamsker
                                      @tkamsker it doesn't support duet 2 boards as it requires CAN-FD (which the duet 2 doesn't support)
                                        dc42 administrators @tkamsker
                                        @tkamsker also we have run out of flash memory space in Duet 2. After 3.5 I expect to move Duet 2 and Maestro firmware to "bug fixes only" maintenance status because it doesn't have enough flash or RAM space for significant new features.
                                          T3P3Tony administrators @becky9
                                          @becky9 we are working on it, in the meantime if you drop an email to sales@duet3d.com we should be able to help.
