    Wifi 2.1beta6 from 3.5.0-rc.2/3 still disconnecting
    Beta Firmware
    10
    82
    4.3k
    • moth4017undefined
      moth4017 @oliof
      @oliof ran printer for a couple of hours today with USB connected , no issue , will add tape to USB lead and try again
      that was a bit tricky to do 🙂
      • moth4017undefined
        moth4017
        ok DWC lost connection
        M122 === Diagnostics ===
        RepRapFirmware for STM32F4 based Boards (biqoctopuspro_1.0) version 3.5.0-rc.2+101 (2023-12-19 16:32:23) running on STM32F4 (standalone mode)
        Board ID: 32063-002JU-NJ38P-6T18S-HFUN7-70000
        Used output buffers: 1 of 40 (40 max)
        Static ram: 19696
        Dynamic ram: 90300 of which 20 recycled
        Never used RAM 20028, free system stack 91 words
        CCMRam static ram: 24276 dynamic ram: 34724 free ram 6532
        Tasks: NETWORK(1,ready,16.8%,168) HEAT(3,nWait,0s 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
        Bed heaters 0 -1 -1 -1, chamber heaters 3 -1 -1 -1, ordering errs 0
        Heater 0 is on, I-accum = 0.3
        Heater 1 is on, I-accum = 0.6
        HTTP is idle in state(s) 0
        File is idle in state(s) 0
        USB is ready with "M122" in state(s) 0
        Aux is idle in state(s) 0
        Trigger is idle in state(s) 0
        Queue is idle in state(s) 0
        LCD is idle in state(s) 0
        Daemon is idle in state(s) 0
        File2 is idle in state(s) 0
        Queue2 is idle in state(s) 0
        Q0 segments left 0, axes/extruders owned 0x0004007
        Code queue 0 is empty
        Code queue 1 is empty
        === Filament sensors ===
        check 13820565 clear 32718022
        Extruder 0 sensor: ok
        === CAN ===
        Disabled
        Longest wait 0ms for reply type 0, peak Tx sync delay 0 free buffers 0 (min 0), ts 0/0/0
        Tx timeouts 0,0,0,0,0,0
        === Network ===
        Slowest loop: 668.81ms; fastest: 0.07ms
        Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0)
        HTTP sessions: 2 of 8
        Uploads/Errors: 4/0
        === WiFi ===
        Interface state: active
        Module is connected to access point
        Failed messages: pending 0, notrdy 0, noresp 0
        Bad header: 0/0
        Firmware version 1.27-04S-D
        MAC address 00:23:cd:20:84:e6
        Module reset reason: Turned on by main processor, Vcc 3.39, flash size 4194304, free heap 37176
        WiFi IP address 192.168.0.13
        Signal strength -60dBm, channel 5, mode 802.11n, reconnections 0
        Clock register 00004002
        ok
        Damon running
        Debugging On
        Fan & Heater Off
        9564
        Damon running
        Debugging On
        Fan & Heater Off
        9574
        gloomyandyundefined 2 Replies Last reply Reply Quote 0
        • gloomyandyundefined
          gloomyandy @moth4017
          @moth4017 I don't see any M111 output from the WiFi module...
          moth4017undefined 1 Reply Last reply Reply Quote 0
          • moth4017undefined
            moth4017 @gloomyandy
            @gloomyandy hopefully o SD card but im printing at the moment so cant stop, funny how it lost connection shortly after doing the tape on the USB lead
            gloomyandyundefined 1 Reply Last reply Reply Quote 0
              @moth4017 Also what exactly do you mean by "lost connection"? Does the connection get re-established? Are you connecting to the IP address or to the <board>.local dns name? If the connection does not get re-established can you ping the board when it is in this state, can you connect to it from a different device?
                @moth4017 The M111 output only goes to the USB terminal and you will only see it if you have the UART connection to the WiFi board in place.
                Chrissundefined moth4017undefined 2 Replies Last reply Reply Quote 0
                • Chrissundefined
                  Chriss @gloomyandy
                  I learned yesterday that I had a loop in my includes. So the FW opened the same 3 files over and over again, till a counter was reached. It seems to me that this made the WiFi module too disconnect and reconnect without being reachable in the LAN. But it is a guess only. I need observe the behaviour a bit more.
                  Chrissundefined 1 Reply Last reply Reply Quote 1
                  • moth4017undefined
                    @gloomyandy DWC stopped responding no data being updated in the DWC window ,
                    connection "octo.local"
                    to get reconnected i use the reload button in chrome
                    • moth4017undefined
                      @gloomyandy please explain " UART connection to the WiFi board in place."
                      im connected via USB to hercules , sent the M111 P14 S1 $0D and M111 P1 S1 $0D
                        @moth4017 I'm not sure which WiFi module you are using, but on the skrpro there will be a separate set of wires that connects the module UART interface (used for flashing new versions of the WiFi firmware and for debug output) to the main board. That is the connection you need in place to see debug output from the board. If it is working and you run M552 s-1 followed by M522 S1 you should see a lot of debug output from the board.
                        If a refresh of the web page allows it to work again, I'd say that probably means it it not a problem with the WiFi module, check the Web browser developer console for errors, it may be that DWC has crashed for some reason.
                        • moth4017undefined
                          @gloomyandy
                          M111
                          The oldest data was removed. Continue...
                           conn on socket 0 for local port 80
                          Found responder
                          Received 350 bytes
                          New conn on socket 0 for local port 80
                          Found responder
                          Received 349 bytes
                          Found responder
                          Received 350 bytes
                          Found responder
                          Received 349 bytes
                          Found responder
                          Received 350 bytes
                          Found responder
                          Received 349 bytes
                          Damon running
                          Debugging On
                          Fan & Heater Off
                          12896
                          Found responder
                          Received 350 bytes
                          Found responder
                          Received 360 bytes
                          Found responder
                          Received 361 bytes
                          Found responder
                          Received 337 bytes
                          Found responder
                          Received 349 bytes
                          Found responder
                          Received 359 bytes
                          Found responder
                          Received 360 bytes
                          Found responder
                          Received 336 bytes
                          Found responder
                          Received 350 bytes
                          Found responder
                          Received 349 bytes
                          Found responder
                          Received 350 bytes
                          Serial port COM3 closed
                          Serial port COM3 opened
                          M552 s1 ok
                          Found responder
                          Received 349 bytes
                          Found responder
                          Received 350 bytes
                          Found responder
                          Received 349 bytes
                          Found responder
                          Received 350 bytes
                          Found responder
                          Received 349 bytes
                          M552 s1 ok
                          Found responder
                          Received 350 bytes
                          Found responder
                          Received 349 bytes
                          Found responder
                          Received 350 bytes
                          Found responder
                          Received 349 bytes
                          Found responder
                          Received 350 bytes
                          Found responder
                          Received 349 bytes
                          Found responder
                          Received 350 bytes
                          Found responder
                          Received 349 bytes
                          Found responder
                          Received 350 bytes
                          Found responder
                          Received 349 bytes
                          Damon running
                          Debugging On
                          Fan & Heater Off
                          12917
                          Found responder
                          Received 350 bytes
                          Found responder
                          Received 360 bytes
                          Found responder
                          Received 361 bytes
                          Found responder
                          Received 337 bytes
                          Found responder
                          Received 349 bytes
                          M552 s-1 WiFi module stopped
                          ok
                          M552 s1 WiFi:
                          WiFi:  ets Jan  8 2013,rst cause:2, boot mode:(3,6)
                          WiFi:
                          WiFi: load 0x4010f000, len 1392, room 16
                          WiFi: tail 0
                          WiFi: chksum 0xd0
                          WiFi: csum 0xd0
                          WiFi: v00000000
                          WiFi: ~ld
                          ok
                          WiFi: phy buf[107] is ff adc mode is ff
                          WiFi: boot not set
                          WiFi: ota1 not set
                          WiFi: ota2 not set
                          WiFi: V2
                          WiFi: Mo
                          WiFi: irf cal sector: 1019
                          WiFi: freq trace enable 0
                          WiFi: rf[112]
                          WiFi: SDK:3.0.2(824dc80)/Core:unspecified=0/lwIP:STABLE-2_1_2_RELEASE/glue:1.2-17-g354887a/BearSSL:89454af
                          WiFi: SocketServer.cpp(1576): Init completed
                          WiFi: SocketServer.cpp(1577):
                          WiFi:
                          WiFi: DuetWiFiSocketServer version 1.27-04S-D ready
                          WiFi:
                          WiFi module started
                          ESP reported status change
                          WiFi: SocketServer.cpp(1222): Set hostname to octo
                          WiFi: mode : sta(e8:68:e7:d9:f9:a3)
                          WiFi: add if0
                          Damon running
                          Debugging On
                          Fan & Heater Off
                          12927
                            @moth4017 I would have expected to see details of the WiFi server connecting to your access point in that output, did you remove that from what you posted?
                            But anyway I don't see any signs of a problem with the WiFi module in that output.
                            • T3P3Tonyundefined T3P3Tony moved this topic from Beta Firmware
                            • Chrissundefined
                              Chriss @Chriss
                              my loop in the config files was not the root unfortunately. The board is again not reachable. It lost the connection approximately 15 minutes after I started a print at a fresh booted printer. I will get an USB extension cable and connect via USB as soon as I have the cable.
                              I understood that you guys want M122, something else? M11? M552 s-1 followed by M522 S1?
                              Cheers, Chriss
                                gloomyandy @Chriss
                                @Chriss I think ideally what we need is...
                                1. Reboot the board
                                2. Connect over USB
                                3. Run M111 P14 S1
                                4. Run m122
                                5. Leave the USB connection open and wait for the WiFi disconnect
                                6. Run M122
                                7. run M552
                                8. run M552 s-1
                                9. run M552 s1
                                10. capture all of the output from the above and post it here.
                                @droftarts may have other suggestions.
                                • Chrissundefined
                                  Chriss @gloomyandy
                                  @gloomyandy
                                  Got it, so the current status does not help at all than. But I think that I can reproduce that now.
                                  My local hardware dealer was unable to provide a long enough USB cable. Amazon will bring me one tomorrow noon. Is there anything I need to know for the serial interface? (115200 8n1?)
                                  The only M575 I found is commented out:
                                  M575 P1 B115200 S1
                                  Cheers, Chriss
                                    gloomyandy @Chriss
                                    @Chriss If you haven't restarted the board since you lost the connection and it is still disconnected then running M122 might provide some information.
                                      gloomyandy @gloomyandy
                                      @gloomyandy If you are connecting over USB it is not really a "serial" connection in the normal way of things (so things like the baud rate, stop bits etc. don't really apply).
                                      Chrissundefined 1 Reply Last reply Reply Quote 0
                                      • Chrissundefined
                                        Chriss @gloomyandy
                                        @gloomyandy
                                        Well, at least the baud rate is needed. I will give it a try with 115200 or the half of it, let's see what I will get out of it.
                                        The docu "https://docs.duet3d.com/en/How_to_guides/Getting_connected/Getting_connected_to_your_Duet" mentions "screen /dev/ttyACM0 115200", so it should be 115200 than.
                                        The printer is still printing and I do not want to disturb it now. I will give the M122 a try as soon as the print is finished and I found a laptop to provide the output from that till my long cable arrives out of the Amazon. 😉
                                        Cheers, Chriss
                                          gloomyandy @Chriss
                                          @Chriss The baud rate means nothing when connecting via USB to RRF.
                                          • rechrtbundefined
                                            rechrtb
                                            @Chriss Hello, I'm also looking into this issue. I have a few questions:
                                            1. You mentioned that before 3.5.0rc2 + 2.1beta6, you also observed disconnects but reconnection always succeeded. Do you remember the RRF version and WiFi firmware version you were running then?
                                            2. You mentioned that all Duet boards you have on RRF 3.5rc + WiFi firmware 2.1beta6 have this issue, but the 'others' are fine. Can you tell me what versions these other boards are on?
                                            3. Can you downgrade maybe one of the problematic boards to RRF 3.5.0rc2 + WiFi firmware v1.27?
                                              @moth4017 reports that this issue still occurs for the v1.27 firmware, just want to confirm if that also occurs for you.
                                            4. I assume the RRF firmware you flashed on the boards are exactly the release binaries in the GitHub repo. Is this correct?
