    PID Tuning Procedure
    2.8k
    • CarlBossonundefined
      CarlBosson
      Dose anyone have a procedure for auto tuning he extruder? I am using a Pt-100 Expansion board and Pt-100 for control. I would also like to tune the bed. Thanks in advance.
      Carl
      Firmware Version: 2.05.1 (2020-02-09b1)
      WiFi Server Version: 1.21
      Web Interface Version: 1.22.6
      Web Interface by Christian Hammacher
      Licensed under the terms of the GPL v3
      droftartsundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
        droftarts administrators @CarlBosson
        @CarlBosson See https://docs.duet3d.com/en/How_to_guides/Commissioning
        Specifically this section, but the whole guide is useful: https://docs.duet3d.com/en/How_to_guides/Commissioning#h-7-tune-heaters
        CarlBossonundefined 2 Replies Last reply Reply Quote 0
        • stuartofmtundefined
          stuartofmt
          Not sure if this is useful for your situation, but here are two (related) macros that I put together. Basically, together, they create additional macro files that look something like this:
          M307 H1 R2.673 K0.258:0.127 D9.248 E1.350 S0.80 B0 V24.16
          M143 H1 S250
          I then invoke the applicable macro depending on which tool I select as well as a separate macro for the bed,
          ; Macro to select PID target and parameters
          ;Invoke a PID tuning
          ;parameters A, B and C are mandatory
          ; A = "hot" if autotune hotend, A = "bed" if autotune Bed
          ; B = heater number (typically 0 for Bed)
          ; C = Target Tune Temp
          ; D = Tool number > 0
          ; Optional Parameters
          ; E = Pwm - default is 0.8
          ; F = Bed temp during hotend tuning - default is 20 deg C
          M291 R"Auto Pid Tuning" P"What to tune?" K{"Hotend","Bed","Cancel"} S4
          if input = 0
              var tool = state.currentTool
              if var.tool < 0   ; no tool selected
                  M291 R"Auto Pid Tuning" P"What hotend?" K{"Direct(T0)","Bowden(T1)","Cancel"} S4
                  if input = 0
                      T0
                  elif input = 1
                      T1
                  else
                      var msg = "Cannot run if no tool is selected"
                      M117 {var.msg}
                      abort {var.msg}
              if state.currentTool = 0
                  ; Tune Tool 0 to 250 deg using heater 1 with bed temp = 50 deg
                  M98 P"0:/macros/PID_Tuning/PID_Tune.g" A"hot" B1 C240 D0 F50
              elif state.currentTool = 1
                  ; Tune Tool 1 to 250 deg using heater 1 with bed temp = 50 deg
                  M98 P"0:/macros/PID_Tuning/PID_Tune.g" A"hot" B1 C240 D1 F50
              else
                  abort "Invalid tool selected. Tool number "^state.currentTool
          elif input = 1
              ; Tune Bed to 85 deg using heater 0
              M98 P"0:/macros/PID_Tuning/PID_Tune.g" A"bed" B0 C85 D1 E1
          else
              abort "Selection cancelled"
          ;Macro to perform the actual tuning and save results to another macro file
          ;Autotune heater and save the M307 settings to a macro file
          ;parameters A, B , C  and D are mandatory
          ; F = Bed temp during hotend tuning - default is off
          ; G = ambient temp at start of autotune - default is 20 deg C
          ;Filename templates
          var hotfile =  "0:/macros/PID_Tuning/PID_T"
          var bedfile =  "0:/macros/PID_Tuning/PID_Bed.g"
          var file = ""
          ; Set some safe defaults
          var hotEnd = "hot"
          var tool = 0
          var heater = 1
          var tuneTemp = 0
          var pwm = 0.8      ; optional
          var bedTemp = 0 ; optional - only used for Autotune Hotend
          var ambientTemp = 20
          if exists(param.A) & exists(param.B) & exists(param.C) & exists(param.D)
              if param.A = "hot" | param.A = "bed"
                  set var.hotEnd = param.A
              else
                  abort "Invalid value for A parameter"
              set var.heater = param.B
              set var.tuneTemp = param.C
              set var.tool = param.D
          else
              abort "PID_Tune.g is missing mandatory parameters"
          if exists(param.E)
              set var.pwm = param.E
          if exists(param.F)
              set var.bedTemp = param.F
          if exists(param.H)
              set var.ambientTemp = param.H
          T{var.tool}
          ; reset temps and turn heaters off
          M568  S0 R0 A0           ; Reset temps and turn off hotend
          M140 S0 R0               ; Reset bed temps
          M140 S-273               ; Turn of bed heater
          G28                         ; Home all - best if homing leaves the Hotend near the center of the bed
          if var.hotEnd = "hot"               ; Performing Autotune on Hotend
              G0 Z1.5                     ; Move Hotend close to bed
              echo "Heating bed to "^var.bedTemp^" deg"
              M190 S{var.bedTemp} ; wait for bed temp to stabilize
              M303 T{var.tool} P{var.pwm} A{var.ambientTemp} S{var.tuneTemp}
          else
              G0 Z25                      ; give some clearance from the Hotend during Bed autotune.
              M303 H{var.heater} P{var.pwm} A{var.ambientTemp} S{var.tuneTemp}
          ; Wait until autotune complete
          while heat.heaters[{var.heater}].state = "tuning"
              G4 S10
          ; Capture the tuned results
          var myR = heat.heaters[{var.heater}].model.heatingRate+0.001-0.001
          var myK = heat.heaters[{var.heater}].model.coolingRate+0.001-0.001
          var myF = heat.heaters[{var.heater}].model.fanCoolingRate+0.001-0.001
          var myD = heat.heaters[{var.heater}].model.deadTime+0.001-0.001
          var myE = heat.heaters[{var.heater}].model.coolingExp+0.001-0.001
          var myS = heat.heaters[{var.heater}].model.maxPwm+0.01-0.01
          var myB = 0
          if !heat.heaters[{var.heater}].model.enabled
              set var.myB = 1
          var myV = heat.heaters[{var.heater}].model.standardVoltage+0.01-0.01
          ; Assemble the results
          var myPid = "M307 H"^var.heater^" R"^var.myR^" K"^var.myK^":"^var.myF^" D"^var.myD^" E"^var.myE^" S"^var.myS^" B"^var.myB^" V"^var.myV
          echo "New PID settings = "^var.myPid
          ;write out to file
          var maxTemp = ""
              set var.file =  var.hotfile^var.tool^".g"
              set var.maxTemp = "M143 H"^var.heater^" S"^{var.tuneTemp+10} ;Set max hotend temp
          else
              set var.file =  var.bedfile
              set var.maxTemp = "M143 H"^var.heater^" S"^{var.tuneTemp+5} ;Set max bed temp
          echo "Saving to file "^var.file
          echo > var.file {var.myPid}
          echo >> var.file {var.maxTemp}
          G0 Z50
            CarlBosson @droftarts
            @droftarts ,
            Thank you for the help. Please forgive my ignorance. As I look over the document you refered me to
            "Result
            If successful, the firmware will report the parameters to use, and an M307 GCcode command e.g.:
            M307 H1 R7.046 K1.519:0.006 D3.58 E1.35 S1.00 B0 V23.9 (RRF 3.4 and later)
            M307 H1 B0 R1.839 C270.7:170.1 D8.10 S1.00 V12.1 (RRF 3.3 and earlier)
            Then, either:
            Copy this into your config.g, replacing the existing one for the heater, or
            If your config.g has M501 at the end, you can save the current heater settings by sending M500. This will save the current parameters to the sys/config-override.g on the SD card. M501 in config.g will load them at each reboot."
            I do not see a line of code in my config.g that looks like this to copy the info to? see config.g below. Do I need to create it? If so where?
            I also do not have a M501 in my config.g? again same as above, do I add it? where?
            Config.g
            SENDING:M503
            ; generated by RepRapFirmware Configuration Tool v2 on Sun Jun 16 2019 12:25:24 GMT-0400 (Eastern Daylight Time)
            M550 P"My Printer" ; Set machine name
            M552 S1 ; Enable network
            M586 P0 S1 ; Enable HTTP
            M586 P1 S0 ; Disable FTP
            M586 P2 S0 ; Disable Telnet
            M569 P0 S1 ; Physical drive 0 goes forwards
            M569 P1 S1 ; Physical drive 1 goes forwards
            M569 P2 S0 ; Physical drive 2 goes forwards
            M569 P3 S0 ; Physical drive 3 goes forwards
            M92 X80.58 Y80.58 Z400.00 E799.53 ; Set steps per mm
            M566 X900.00 Y900.00 Z12.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
            M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; Set maximum speeds (mm/min)
            M201 X500.00 Y500.00 Z20.00 E250.00 ; Set accelerations (mm/s^2)
            M906 X1450.00 Y1450.00 Z1450.00 E1450.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
            M208 X300 Y300 Z400 S0 ; Set axis maxima
            M574 X1 Y1 Z1 S0 ; Set active low and disabled endstops
            M558 P1 H5 F120 T6000 ; Set Z probe type to unmodulated and the dive height + speeds
            G31 P500 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
            M557 X15:6 Y15:195 S20 ; Define mesh grid
            M305 P0 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 0
            M143 H0 S200 ; Set temperature limit for heater 0 to 200C
            M305 P1 X200 ; Set to Pt-100 sensor
            M143 H1 S475 ; Set temperature limit for heater 1 to 475C
            M305 P2 X200 ;Set to Pt-100 sensor
            M143 H2 S200 ;Set temperature limit to 200c
            M106 P0 S1 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
            M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
            M563 P0 D0 H1 ; Define tool 0
            ;Automatic Power Saving
            M911 S21.0 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ;Set voltage threasholds and actions to run on power loss
            ok T0:23.6 /0.0 B:20.5 /0.0
              CarlBosson @stuartofmt
              @stuartofmt
              This looks great! But I do not know how to use it. I am a little over my head but trying to leaarn.
              Carl
                @droftarts
                I tried the M300 T0 S200 command but nothing happened. See what was returned below.
                M303 T0 S200
                SENDING:M303 T0 S200
                No heater has been tuned yet
                  @stuartofmt
                  Do I just copy and past the code
                  into a new Macro in the User interface?
                  stuartofmtundefined 1 Reply Last reply Reply Quote 0
                    stuartofmt @CarlBosson
                    @CarlBosson said in PID Tuning Procedure:
                    @stuartofmt
                    No, that would be a bad idea as the PID tuning parameters (in the first macro) depend a lot on your printer.
                    I offered up the macro as a way of assisting in understanding some of the parameters, assuming you may have been familiar with running macros.
                    Can you descibe your machine ? From the config file it looks to have two different hotend heaters (H1 and H2) and a bed heater (H0) ? If so, how do you switch between the two different hotends?
                    Also - it looks like you may be running old versions of the firmware and DWC - can you comfirm by posting the output of M122
                      @stuartofmt said in PID Tuning Procedure:
                      This is a custom Machine. It used to be a Folger Tech FT-5 large volume printer 300mm X 300mm X 300mm. The only thing original now is a few stepper motors and the frame. We are running the Duet E3D mother board and E3D Titan Aqua extruder. There is a 110Vac heated bed controlled by the use of an SSR. This also has a custom built enclosure and heaters controlled by an externally mounted din rail Watlow controller. Early on I tried to use the Duet to control the chamber heaters but I ran out of time. I may come back to this.
                      There should only be two heaters. The hot end and the heated bed. If there are more, then this might be a hold over from the chamber heating attempt.
                      I am sure I have not upgraded the firmware since the original install so I am sure it is old.
                      I had never seen a 3D Printer when I was tasked too build this one, and now have a few Enders at home to learn on. I could use some help making this printer what I know it can be.
                      I will get you the M122 next.
                      Carl
                        @stuartofmt
                        SENDING:M122
                        RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
                        Board ID: 08DGM-917DA-G4MSD-6J1FA-3SJ6N-T8T39
                        Used output buffers: 1 of 24 (13 max)
                        Static ram: 25712
                        Dynamic ram: 93344 of which 484 recycled
                        Exception stack ram used: 496
                        Never used ram: 11036
                        Tasks: NETWORK(ready,628) HEAT(blocked,720) MAIN(running,3760) IDLE(ready,160)
                        Owned mutexes:
                        Last reset 05:04:57 ago, cause: power up
                        Last software reset at 2023-06-16 10:27, reason: User, spinning module GCodes, available RAM 11592 bytes (slot 2)
                        Error status: 10
                        [ERROR] Error status: 10
                        Free file entries: 10
                        SD card longest block write time: 504.0ms, max retries 0
                        MCU temperature: min 26.7, current 44.1, max 48.3
                        Supply voltage: min 0.9, current 24.6, max 24.8, under voltage events: 2, over voltage events: 0, power good: yes
                        Driver 0: standstill, SG min/max 0/361
                        Driver 1: standstill, SG min/max 0/232
                        Driver 3: standstill, SG min/max 0/1023
                        Date/time: 2024-02-20 15:37:13
                        Slowest loop: 47.05ms; fastest: 0.05ms
                        Hiccups: 0, FreeDm: 160, MinFreeDm: 140, MaxWait: 12289133ms
                        === DDARing ===
                        Heater 0 is on, I-accum = 0.1
                        Heater 1 is on, I-accum = 0.9
                        Segments left: 0
                        Stack records: 4 allocated, 0 in use
                        Movement lock held by null
                        http is idle in state(s) 0
                        telnet is idle in state(s) 0
                        file is idle in state(s) 0
                        serial is ready with "M122" in state(s) 0
                        aux is idle in state(s) 0
                        daemon is idle in state(s) 0
                        queue is idle in state(s) 0
                        Code queue is empty.
                        === Network ===
                        Slowest loop: 505.69ms; fastest: 0.00ms
                        HTTP sessions: 0 of 8
                        • WiFi -
                          Network state is running
                          WiFi firmware version 1.21
                          WiFi MAC address cc:50:e3:0d:29:ce
                          WiFi Vcc 3.40, reset reason Turned on by main processor
                          WiFi flash size 4194304, free heap 17096
                          WiFi IP address 192.168.1.151
                          WiFi signal strength -61dBm, reconnections 0, sleep mode modem
                          Phaedrux Moderator @CarlBosson
                          Your firmware versions are very out of date. Most of the code suggestions you will get here likely won't work as expected.
                          I suggest you update your firmware. You'll need to generate a fresh config set for RRF3. https://configtool.reprapfirmware.org/
                          If you still have access to DWC. Upload these zip files, one at a time in the system tab. Don't extract them first. Reboot after each. Use M115 in the gcode console to verify the firmware has been applied.
                          https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
                          https://github.com/Duet3D/RepRapFirmware/releases/download/3.3/Duet2and3Firmware-3.3.zip
                          https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.5/Duet2and3Firmware-3.4.6.zip
                          CarlBossonundefined 3 Replies Last reply Reply Quote 0
                            @CarlBosson If you don't want to update the firmware, you can still tune the heaters. You just can't tune them as a tool. Use M303 H1 S200 instead.
                            CarlBossonundefined 1 Reply Last reply Reply Quote 0
                              CarlBosson @Phaedrux
                              This post is deleted!
                                @Phaedrux
                                Thank you for all your help. Sorry for the late response, I have been out sick. Things are a little busy now and I have playing catch up, I may have to take this machine home to work on it. I am sure I will have questions as I go. Thanks and have a great day.
                                Carl
                                  @droftarts said in PID Tuning Procedure:
                                  Thank you for your input and the option that you offer. I think I will try to fix it once and for all. "I know that is a fantasy".
                                  Carl
                                    @Phaedrux I have updated to firmware Ver 3.3.
                                    But the kink you sent to Ver 3.4.6 says file not found?
                                      @CarlBosson sorry typo
                                      https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.6/Duet2and3Firmware-3.4.6.zip
                                        @Phaedrux Ok I have that done.
                                        I need to be honest. I am in way over my head! Thank you for all the help.
                                        Yesterday I connected to my home network and had access to the DWC but now it will not connect to the same IP address. When I enter M587 via YAT I get the following message?
                                        M587
                                        Failed to retrieve network list: another SPI transfer is pending
                                        ok
                                          @Phaedrux Current M122
                                          M122
                                          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later
                                          Used output buffers: 1 of 24 (4 max)
                                          Static ram: 23876
                                          Dynamic ram: 73796 of which 84 recycled
                                          Never used RAM 16660, free system stack 170 words
                                          Tasks: NETWORK(ready,7.7%,521) HEAT(delaying,0.0%,386) Move(notifyWait,0.1%,364) MAIN(running,92.1%,461) IDLE(ready,0.1%,29), total 100.0%
                                          Owned mutexes: USB(MAIN)
                                          Last reset 00:21:12 ago, cause: power up
                                          Last software reset details not available
                                          Error status: 0x00
                                          Step timer max interval 0
                                          MCU temperature: min 37.0, current 40.3, max 40.8
                                          Supply voltage: min 0.3, current 24.6, max 24.7, under voltage events: 1, over voltage events: 0, power good: yes
                                          Driver 0: position 0, standstill, SG min/max not available
                                          Driver 1: position 0, standstill, SG min/max not available
                                          Driver 2: position 0, standstill, SG min/max not available
                                          Driver 3: position 0, standstill, SG min/max not available
                                          Driver 4: position 0, standstill, SG min/max not available
                                          Driver 5: position 0
                                          Driver 6: position 0
                                          Driver 7: position 0
                                          Driver 8: position 0
                                          Driver 9: position 0
                                          Driver 10: position 0
                                          Driver 11: position 0
                                          Slowest loop: 101.25ms; fastest: 0.13ms
                                          === Storage ===
                                          SD card longest read time 0.9ms, write time 0.0ms, max retries 0
                                          === MainDDARing ===
                                          === AuxDDARing ===
                                          Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
                                          Segments left: 0
                                          HTTP is idle in state(s) 0
                                          Telnet is idle in state(s) 0
                                          File is idle in state(s) 0
                                          USB is ready with "M122" in state(s) 0
                                          Aux is idle in state(s) 0
                                          Trigger is idle in state(s) 0
                                          Queue is idle in state(s) 0
                                          LCD is idle in state(s) 0
                                          Daemon is idle in state(s) 0
                                          === Network ===
                                          Slowest loop: 0.33ms; fastest: 0.00ms
                                          • WiFi -
                                            Network state is starting2
                                            WiFi module is disabled
                                            Failed messages: pending 0, notready 1, noresp 0
                                            ok
                                            @Phaedrux Here are my attempts to restart the wifi below
                                            • WiFi -
                                              ok
                                              M552
                                              WiFi module is being started
                                              ok
                                              M552
                                              ok
                                              M552
                                              ok
                                              M552 S-1
                                              WiFi module stopped
                                              ok
                                              M552
                                              ok
                                              M552 S0
                                              ok
                                              M552
                                              ok
                                              M587
                                              ok
